Having Problem With Starting.when I First Start The Engine It Fires Wright Up Then Dies Wright Out And Won't Restart I've Changed Crank And Cam Sensors And Nothing.seems Like Some Kind Of Security Issue.when It Dies Out I Loose Spark. Had Motor Fully Built And Heads.car Ran Fine Four Like 30 Miles.ihave The U-tec Set At 0 Four Wright Now I Am Using The Turbonetics Reflash And The 380 Inj To Break The Motor In.i've Checked For Loose Connections And There Is None.i've Even Changed The Plugs.and I Keep Getting #6 Missfire.
gap plugs to .025 and use ngk iridium works good with turbo apps i would personaly contact pro shop and see whats up or by a cheap scanner and find out if there are any bcm codes
[QUOTE=sam-z]Having Problem With Starting.when I First Start The Engine It Fires Wright Up Then Dies Wright Out And Won't Restart I've Changed Crank And Cam Sensors And Nothing.seems Like Some Kind Of Security Issue.when It Dies Out I Loose Spark. Had Motor Fully Built And Heads.car Ran Fine Four Like 30 Miles.ihave The U-tec Set At 0 Four Wright Now I Am Using The Turbonetics Reflash And The 380 Inj To Break The Motor In.i've Checked For Loose Connections And There Is None.i've Even Changed The Plugs.and I Keep Getting #6 Missfire.
