Fitting cams
Old May 9, 2007 | 06:27 AM
THE TECH's Avatar
THE TECH
Interesting.
Old May 9, 2007 | 07:31 AM
Eazzy's Avatar
Eazzy
Also ------When you compress the spring and have access to the locks for removal, dont use your fingers to grab them, use a strong magnet, if those little rascals fall where they shouldnt, you WILL be pulling the motor.
Old May 9, 2007 | 07:45 AM
baptist's Avatar
baptist
This sounds like far more hassle than its worth with the engine in situ.
Old May 9, 2007 | 08:03 AM
overZealous1's Avatar
overZealous1
+1 i would not attempt the socket method for removal with heads on car as the locks can fly anywhere. i actually made a spring compressor for the vq35 that makes quick work of spring removal and install.
Old May 9, 2007 | 08:07 AM
Eazzy's Avatar
Eazzy
If you take a socket the size of the retainers (slightly smaller) place it on the retainers and give each a quick short lick with a hammer, it will free up those locks.
Christ, dont slam them
Old May 9, 2007 | 08:10 AM
NA350Z's Avatar
NA350Z
It makes doing this on an Integra look so easy.
350z82
Oct 1, 2015 06:25 PM
