vortech FAQ: read this before asking vortech questions
Old Jan 6, 2011 | 05:10 AM
  #1501
350Z_Al's Avatar
350Z_Al
Originally Posted by maXmood
after rebuilding it again probably..
Hopefully
Old Jan 6, 2011 | 05:16 AM
  #1502
Erdem's Avatar
Erdem
Originally Posted by al@phatrides
Hopefully
are you the buyer?
Old Jan 13, 2011 | 01:14 AM
  #1503
scenehouser's Avatar
scenehouser
guys is there a diy on changing the vortech pulley? i did some searches but couldn't find anything. thnx.
Old Jan 13, 2011 | 02:23 AM
  #1504
maXmood's Avatar
maXmood
Under Boost!
^which pulley? even tho they're all pretty much straight forward.
Old Jan 13, 2011 | 02:31 AM
  #1505
scenehouser
3.33 to 3.12
need torque specs and maybe there are other things i need to keep in mind.
i'm a real a pansy when it comes to working on my car without a manual or guide (:
Old Jan 13, 2011 | 02:39 AM
  #1506
maXmood's Avatar
maXmood
Under Boost!
i can send u the installation manual, but i don't remember torque specs were mentioned.
Old Jan 13, 2011 | 08:23 PM
  #1507
- bigc -'s Avatar
- bigc -
there's no torque specs. just get everything tight...but not too tight. you'll have to remove the cog pulley on the back as well since you need to slide the jackshaft back a little to get enough clearance to pull off the serpentine pulley.
Old Jan 14, 2011 | 01:43 AM
  #1508
scenehouser
strange that there are no torque specs...
Old Jan 14, 2011 | 02:32 AM
  #1509
maXmood's Avatar
maXmood
Under Boost!
here you go:
http://www.vortechsuperchargers.com/...ed%20Questions
if anything, give them a buzz.
Old Jan 14, 2011 | 05:00 AM
  #1510
scenehouser
thnx (:
Old Jan 14, 2011 | 04:14 PM
  #1511
Silencer_0's Avatar
Silencer_0
Hey guys. Is an oil cooler still recommended if you have the V3? I know it'd be good if you have the V2 since it shares the oil, but since the V3 has its own oil, will the engines oil still be impacted enough to warrant an oil cooler?
Old Jan 14, 2011 | 07:18 PM
  #1512
- bigc -'s Avatar
- bigc -
you should get an oil cooler, especially with the heat out in the IE
Old Jan 14, 2011 | 08:22 PM
  #1513
str8dum1's Avatar
str8dum1
I never ran an oil cooler on my V3 making good power, but like all things, its not a bad idea, but not 100% required.
You can piece one together for ~200$
Old Jan 15, 2011 | 02:03 AM
  #1514
scenehouser
I've asked myself the same question so I've just installed an oil temp gauge and once I install my Vortech I will know if it's needed or not.
Old Jan 15, 2011 | 07:02 AM
  #1515
binder's Avatar
binder
i use an anchient german technique called "guten tite"
Old Jan 15, 2011 | 07:07 AM
  #1516
binder's Avatar
binder
The oil that lubricates a vortech is different than oil that goes in a turbo.
The vortech oil just lubricates the gears and some of the bearings. On a turbo the oil lubricates a journal. The turbo is roughly 1200* verses a 200* vortech. I tested temps on my vortech wihle on the dyno and i also have temp gauges we use on race engines on the vortech. It never broke 300*. Huge difference in heat transfer into that oil.
Because of that you can run self contained oil in teh vortech. If that oil was getting super hot they couldn't use a self contained oil because it would cook the oil.
Old Feb 2, 2011 | 08:08 PM
  #1517
adiddyrundacity's Avatar
adiddyrundacity
Well after reading about 30 pages, including the intro i have a serious headache and i think i also got diarrhea , but that could be dinners fault.
Anyways looking to step into this set up
have a 2005 g35 coupe ie revup
5/16 spacer, nismo headers, fast intentions cats and exhaust. I also have a unorthodox pulley set and car is tuned with uprev.
I am looking to buy the tuner kit and get the walbro fuel pump, 550cc injectors.
I am also looking to buy an upgraded radiator ie the koyo 53mm . Will this kit fit with a slight bigger radiator? After that i am looking at oil pan spacer and oil cooler.
This car will be used for track purposes. That is why i wanted to ask ppl with experience with this kit on the track what their experiences were??? heat? longevity?
I also wanted to ask people who are using uprev to tune how their experiences were going or have gone ???
Lastly i was going for the V3 sc rather than the v2. Is the v3 the route to go???
Thank in advance
Old Feb 3, 2011 | 05:01 AM
  #1518
4SHIZZIL's Avatar
4SHIZZIL
quick question for Sentry or Binder
I have the T Trim on a Rev Up runing 2.87 pulley. I just added a huge IC and dropped a bit of psi.
what cog would help me gain a lbs or two? I have no idea what the TTrim is vs SC or my RevUp Cog (first Cog) vs the others. lol
im going to call Vortech later today but they are closed until like 11 or noon East Coast time.
LMAO!
Old Feb 3, 2011 | 05:07 AM
  #1519
Erdem's Avatar
Erdem
just buy a 2.60 pulley
Old Feb 3, 2011 | 06:31 AM
  #1520
str8dum1's Avatar
str8dum1
weird you dropped some PSI. i didnt lose any. Must be a poor IC design. but ya. 2.60 pulley with the GTM tensioner mod on a 34/28 cog setup would be ideal for that blower.
LMAO!
