vortech FAQ: read this before asking vortech questions
Old Jul 25, 2011 | 10:24 PM
  #1581
4SHIZZIL's Avatar
4SHIZZIL
Before accident, kids...two boys, and wife stayed home....lol
Now shes a sleeper in stockish clothing. Still not used to the boaring outter shell but shes stronger than ever!
Old Jul 26, 2011 | 05:34 AM
  #1582
Ruthless18x's Avatar
Ruthless18x
Originally Posted by binder
I'm not sure anyone has any data of dyno pulls with then without it on a boosted engine. It's going to flow better than oem but unless you are maxing out the cams, heads, exhaust system you won't need that extra flow. I think those things are what, 1300$? You can get much more for your money in other places.
If you are buying it just for looks in the engine bay then kudos. Buying it for an increase in power then you are spending way too much for the amount you will get back. I'd do cams/headers and even head porting before worrying about a cosworth.
Yeah they are pricey. Exhaust wise, I'm going to be running momentum headers, berk tps, and the Greddy turbo tic. I've got a plenum spacer on it now, so maybe spend the money on cams / springs instead.
I was just curious on the dyno, I don't think I've ever seen one with a Vortech.
Did you ever run e85 on your Vortech setup?
Old Jul 26, 2011 | 09:57 AM
  #1583
kyo350z's Avatar
kyo350z
my a/f reading is at 14.x a lot of the time, is that bad? lol
Old Jul 26, 2011 | 02:10 PM
  #1584
binder's Avatar
binder
cams and springs would probably be a better investment. You can up your rev limiter and the engine will breathe better.
No e85. My vortech wasn't on the built engine very long before i went turbo.
Old Jul 26, 2011 | 02:12 PM
  #1585
binder's Avatar
binder
cruising 14.7 is stoich so that's fine. in boost 14 is extremely lean.
Old Jul 26, 2011 | 02:14 PM
  #1586
binder's Avatar
binder
Originally Posted by 4SHIZZIL
Man i almost called you weekend of the 15th. I did drive the beast home. I had a dirty fuel system issue. I ran two cans of BG44k, the fuel one, and she runs like a champ!. So im seeing 15/16 psi now so ill add the 2.62 pulley and drop it back down to 7100 to play it safe? Are sure about float with a rev up at 7500 rpms? Although they have a few motors (non rev ups) to 7100 / 7200 with no problem.
I have a revup built 8.8 comp T Trim but i hear i do not have race bearings in blower because i upgraded my S blower to T. Next bearing swap ill ask to upgrade since im spinning her hard. Sept 12 i have appt for Final Tune! Shooting for 500 at around 17 psi!. No belt slippage yet, thank you rev up motor n kit!
you should have called!
****, i forgot you have rev up. Those already rev to 7100 so going higher shouldn't be an issue. No way could i confirm that a non-rev will float at 7500rpms but being that stock springs are very soft they would have a tendency to float at some point over the designed normal rev limit. I would just keep reving to 7500 if i was on the rev up then.
Old Jul 30, 2011 | 06:28 AM
  #1587
4SHIZZIL's Avatar
4SHIZZIL
so I guess the BG44K is more than the shizt! My car is running like a champ and I can only image what the 2lbs is going to add. She now is a beast beyond the normal SC threshold! TTs eat your heart out. lol
Never switchings over.
Old Aug 25, 2011 | 10:12 AM
  #1588
akks350z's Avatar
akks350z
ok guys want to replace my intercooler, i have v2 and intercooler is looking old, where can i get a direct fit polished replacement? anyone? i looked on vortech sites but no luck, i dont want the same one polsihed if possible, also called them and they want 877$ for a stock non polished replacment..lmao
Old Aug 25, 2011 | 11:45 AM
  #1589
str8dum1's Avatar
str8dum1
this is what comes with the kit
http://www.treadstoneperformance.com...R8+Intercooler
i also have my old one sitting around i'd sell
Old Aug 25, 2011 | 03:37 PM
  #1590
superchargedg's Avatar
superchargedg
Damn Noobs
Never...lol
Old Aug 26, 2011 | 12:27 AM
  #1591
4SHIZZIL's Avatar
4SHIZZIL
I have the mitz EVO 10 front mount upgrade on mine, its a beast, ill post pics. The deeper the IC the more efficent, however this one from turbo XS yields us keeping the front crash bar. If youre not concerned w crash bar get one the size of the one on the Greddy kit (not the greddy ic...one that size)
Str8 wont steer you wrong, he man sick hp on his SC set up too.
Old Aug 26, 2011 | 12:29 AM
  #1592
4SHIZZIL's Avatar
4SHIZZIL
Originally Posted by superchargedg
Never...lol
ok ok i might add two small peanut size turbo to the rear of my g35 to go for the tri-factor! But SC remains!
Lmao!
Old Aug 26, 2011 | 12:45 AM
  #1593
4SHIZZIL's Avatar
4SHIZZIL
So the blurp, misfire, miss or whatever came back! I had a slight boost leak i guess, few clamps were loose. I tightened them now its back. The blurp is right at 14psi at 6900rpms. It powers throgh the blurp to put down about 485/490rwhp @7500pms.
Dropping it off at hills garage soon, they are soo fregging busy, its like 20 out for an oil change! Which is good I duess. Next up is the new 2.62 pulley and another look at cam and crank sensors, had we known this much psi and boost with an 8.8 compression engine, we could of easily upgraded springs when we built the block. Lol.
Also i put the stock headers back on, so maybe i should put long tubes on to lower the boost a bit. Test pipes and fast intensions true dual has very little back pressur so....that was the driver with the lower compression and stock headers.
Im happy as it is so more hp is sooo optional. Shifting at 6900 still enabled the new 5000lb v12twin turbo 600+hp cl amg to eat Falken 305/25/20 rubber bits on the track. I can live with that.
Old Sep 8, 2011 | 07:04 PM
  #1594
akks350z's Avatar
akks350z
ok i have problem thats been goin on two weeks, mabye one of you can help me out, car started stumbling at idle and bogging when given gas thru gears but does magically go away at times...a/f goes 17+ then off guage...at first it would clear its self up and run fine, but its gotten to the point that i cant drive car, if i do it will act up more then run right, at cold start it starts right up everything looks good, once warms up and idle gets to around 1k it starts stumbling and a/f slows goes up 14..15...16....17 car almost stalls, then it catches itself revs and does it over again...i had one guy over that had 12000 scanner and there were no codes and he thought it was plugs or throttle body since he couldnt get a reading on tb test, i changed both and no luck, brand new plugs and tb with sensor, any ideas?
vortech 3.12 tuned on ssbox, has been running perfect for over a year.
oh and it will clear up on occasion but comes back
Old Sep 9, 2011 | 05:50 AM
  #1595
str8dum1's Avatar
str8dum1
does the car run fine with the cog belt off?
Old Sep 9, 2011 | 06:58 AM
  #1596
jpc350's Avatar
jpc350
Check for a leak in a hose.
Old Sep 9, 2011 | 08:31 AM
  #1597
4SHIZZIL's Avatar
4SHIZZIL
lose hose
dirty maff
Old Sep 9, 2011 | 12:05 PM
  #1598
akks350z's Avatar
akks350z
hmm i will try that, that will eliminate leaks in vortech piping right?
Old Sep 10, 2011 | 12:31 AM
  #1599
JDMStanced's Avatar
JDMStanced
Where do superchargers make the swooosh sound like from BOV from turbo?
Here's what it sounds like. http://www.youtube.com/watch?v=_6MjJqFcfcA
Old Sep 10, 2011 | 07:09 AM
  #1600
jpc350's Avatar
jpc350
The BPV . By Pass Valve...Vents when off throttle..Air charge (boost ) is vented thru it protecting the Blower from surge/cavitation and damage..
