Is it something that can be replaced with different brand for..let's say..harder sound of air venting off?? like changing to Tial BOV on turbo
i guess some people modify an HKS unit to fit on there but a BPV does a completely different job than a BOV. BPV is open in vac and only closes when you push the throttle to build boost. A bov is closed all the time and only opens in response to a drop in pressure that happens when the throttle plate slams shut when going from boost to vac (letting off the throttle).
are you using a walbro or the FMU booster thing with the stock pump?
he's using FMU with stock pump
it's almost never the injectors so after i found out it was still a stock pump my guess is the stock pump is finally calling it quits after being boosted for over a year.
ive notice to clear it up i have to give half throttle and it clears up, bogs with anything less then that, still sound like fuel pump? it doesnt always bog, seems like tune or fuel to me. ordered a walbro anyway.
going to throw in walbro regardless, and does the volt gauge on my dash being above 14 at all times indicate my voltage is fine?
no. It means your alternator is putting out the voltage but that doesn't 'mean it's getting back to the fuel pump. There can be corrosion or problems with the connectors between alternator/battery/fuel pump causing issues which could lead to a drop in voltage by the time it gets to the pump.
rich is correct, 13v is a more realistic number at the pump with stock wiring verses my statement of 14v at the pump.
