Sheetmetal Intake For Forced Induction
Old May 15, 2007 | 12:56 AM
JETPILOT's Avatar
JETPILOT
Default Sheetmetal Intake For Forced Induction
Has anyone experimented with a custom sheet metal intake and forced induction? I am thinking of having one made. They look sick!
JET
Old May 15, 2007 | 02:15 AM
Mike Wazowski's Avatar
Mike Wazowski
wasnt Julian working on something like this?
Old May 15, 2007 | 02:41 AM
Devil Z's Avatar
Devil Z
What are the benefits?
Old May 15, 2007 | 03:10 AM
saberphx's Avatar
saberphx
I'm interested too, anyone do this besides that funny diamondplate one?
Old May 15, 2007 | 06:01 AM
THE TECH's Avatar
THE TECH
Sheet metal intakes are cool looking, but will need a lot of R&D to provide performance.
Old May 15, 2007 | 06:26 AM
Gary Evans's Avatar
Gary Evans
A rectangular air box isn't made for efficiency it’s made for ease of fabrication.
Old May 15, 2007 | 06:35 AM
QuadCam's Avatar
QuadCam
Larry,
Wilsonmanifolds.com
you can't get any better than that!!! and they are in Ft. Liquordale. I think their manifolds start at $3000.
Old May 15, 2007 | 10:13 AM
turismo's Avatar
turismo
+1
Old May 15, 2007 | 01:05 PM
JETPILOT's Avatar
JETPILOT
The rectangular air box example was merely an illustation of a sheet metal intake. Forced induction does not require a larege plenum since the runners are obviously pressurized. Efficiency in a forced induction intake is more dictated by runner diameter than shape of the plenum.
With FI the shorter most direct route wins every time.
Thanks for the link Andrew. I was looking at their website the other day when you mentioned it.
JET
Old May 15, 2007 | 06:14 PM
vqturbotec's Avatar
vqturbotec
Talking
i seen one at bw a couple of weeks ago. the guy said it was a prototype. im not sure who made it but he said it improved acceleration and throttle responce with no flat spots. if anyone knows about it let me know. does anyone know the benifits of the wilson plenum
Old May 16, 2007 | 08:21 AM
phunk's Avatar
phunk
CJ Motorsports
Plenum displacement is extremely important to get right in any application. Inadequate displacement and plenum shape causes uneven air distribution into the cylinders. Just because the plenum is under pressure does not hide these flaws. NA or FI, there is a pressure transfer taking place, uneven transfer will cause individual cylinder tuning issues. Also, the plenum is often referred to as a surge tank; because it is an air surge tank of course. Larger displacement will stabalize pressure in the manifold increasing air transfer into the cylinders, as the pressure drop (that takes place every time a set of valves open) inside the plenum will be reduced due to the more plentiful volume of available air.
Runner shape and volume is where most of the tuning is done, yes, however that tuning goes out the window if you dont have plenum displacement and shape to support it.
Old May 17, 2007 | 01:17 AM
Eazzy's Avatar
Eazzy
Jet ---so many factors as Tech said, That one you illustrated, is off a small Block Ford I believe but, no matter. Flow characteristics are what it's all about and there would have to be a lot of time involved in making inexpensive prototypes to test on a Flow machine, By rights, set up for your individual requirements, (CFM/RPM, Velositys,Fuel/Air Paths@different RPMs)
Be fun to play with if you had the time and the Money
Old May 17, 2007 | 01:20 AM
JETPILOT's Avatar
JETPILOT
I have both. Wilson manifolds said they would like to work with me to design an intake for my needs.
JET
Old May 17, 2007 | 01:25 AM
Eazzy's Avatar
Eazzy
Thumbs up
JET
Then your 10% there !!!!!
Old May 17, 2007 | 01:36 AM
k0ukim0nst3r's Avatar
k0ukim0nst3r
Hmm. What would be even cooler if each runner had a velocity stack. I plan on fab'in a custom plenum for myself someday. Just need to take a welding class of some sort and I'll be on my way
Old May 17, 2007 | 02:02 AM
Eazzy's Avatar
Eazzy
Then your 1/2 of 1% there !!!!
Old May 17, 2007 | 10:15 PM
NoLimit's Avatar
NoLimit
LOL! custom manifold?? what's wrong with SFR's??
Old May 17, 2007 | 11:34 PM
JETPILOT's Avatar
JETPILOT
SFR??? LOL !!! I don't feel like doing any customizing of my Greddy kit to feed 2 TB's. Plus... It's really really ugly.
JET
Old May 17, 2007 | 11:38 PM
NoLimit's Avatar
NoLimit
JET
Ugly, as compared to the 'thing' you posted a pic of?? come on......
to each his own, but it's (SFR's) by No means ugly ...
you don't need to 'adapt' the twin throttle bodies into your setup, so no big changes needed, ... you can buy the single throttle body design...i have it on my car atm... going back to stock...wanna buy it?
...beautiful...
Old May 18, 2007 | 04:14 AM
QuadCam's Avatar
QuadCam
JET
very nice!!!! They might need to make 2 of them.
