TT White Smoke Under Boost
Old Jun 2, 2007 | 10:57 AM
  #61
Havok_RLS2's Avatar
Havok_RLS2
Originally Posted by taurran
It's always been an option, actually. Turbonetics will sell a modified turbo with the kit but you have to go through them first to get it set up. All it is, is a new bearing housing and some braided water lines with fittings on the ends.
Yeah, But How much?
Old Jun 10, 2007 | 12:08 PM
  #62
michaelbrown13's Avatar
michaelbrown13
Originally Posted by MIAPLAYA
So I'm guess you are returning oil to the AAM pan spacer and not the tapped block?
Nope. Reggie sent another turbo unit and my guys at PTuning spoke to Reggie about the oil lines coming into the oil pan spacer and PTuning said the line should be taped into the block above the oil pan spacer. Reggie said yes, that's how the instructions from Turbonetics state to install them. So this whole problem goes back to the shop in Gaithersburg, MD that sold me the the TN, along with thousands of dollars of other parts and messed up installation of several different components, i.e. a/c coolant hose, mounted to close to the exhaust manifold, the oil lines, broken hanger on the custom exhaust they made and installed, a defective cat from day one and the tuning.........
Seems after Ptuning installed the new TN unit, installing the water coolant lines, as well as tapping the oil lines into the block, like TN said to from the beginning, the unit seems to be running strong.
It's back at PTuning getting a "good" tune this time. By the way, the shop in Gaithersburg, MD never could get the SES light to go off and stay off, but with just a minor adjustment to the UTEC map PTuning did. The light is off and has been for over a week.
This week in addition to tuning I'm also getting larger injectors, as the ones the other fellows sold me are maxed out, 95% duty cycle. Anyway, I'm getting 440cc injectors, new plugs and they're going to refabricate the hanger for the exhaust, and maybe I'll finally get to enjoy my Z350, 1 year later.
I will never go back to that shop in Maryland.
The guys at Ptuning are great. They don't charge for everything, and they really know what they're talking about.
Anyway, thanks for your input as well.
Old Jun 10, 2007 | 02:05 PM
  #63
35ounces's Avatar
35ounces
03 CS Track 6MT
In all fairness to them, back then most people were using the oil pan spacer for the return line rather than tapping the block. I remember when mine was tapped I was kicking myself for not getting a spacer.
kyin
Oct 15, 2015 05:54 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
codek
Sep 28, 2015 03:03 AM
