Update on the Brian Crower Stroker kit.
Old Jun 5, 2007 | 09:14 AM
  #61
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by MIAPLAYA
Wow Greg thats some serious redesign there... Can't wait to see the results..
+100000
Old Jun 5, 2007 | 09:47 AM
  #62
MIAPLAYA's Avatar
MIAPLAYA
Mia that teh car walds Z... its the one that has INtense/powerlab twin GT35 turbo kit
Interesting. Last I saw he was going to use the Speed Force Racing twin turbo kit. Guess he switched.
Old Jun 5, 2007 | 10:22 AM
  #63
IIQuickSilverII
he actually had it and switched... ill leave it at that so we can be back on topic
Old Jun 10, 2007 | 07:40 PM
  #64
Julian@MRC's Avatar
Julian@MRC
Here are some pics of the lots of machining we had to do..
Old Jun 10, 2007 | 08:35 PM
  #65
IIQuickSilverII
damm, nice progress
Old Jun 10, 2007 | 10:52 PM
  #66
thawk408's Avatar
thawk408
Originally Posted by InjectedPerf
Went with the GT47-88 (1500hp turbo). Car is done, just waiting on the ECU which I am being told next week (crosses fingers).
We had to flip, rotate, everything possible to get the turbo to fit. Installing it, removing it, installing it, back and forth got tiresome. I swear this thing weights 75lbs.
Need more pictures
Old Jun 12, 2007 | 06:28 AM
  #67
Julian@MRC's Avatar
Julian@MRC
I want to go ahead and say this whole ordeal has been a PITA thus far...We need to remove the oil squirters, however you NEED to utilize a hex head "SET Screw" that sits flush with the block, or the rod bolts only clear by 10 thousandths.. However the thread pitch we need are a very uncommon one..Brian Crower sent us 12x.25x12 mm screws, and the thread we need is way finer that that..I am beginning to wonder if Brian Crower has even done one of these motors yet
I honestly am starting to get angry with having to do their R&D for them..
Old Jun 12, 2007 | 06:45 AM
  #68
thawk408's Avatar
thawk408
If it was me I would charge them by the hour.
Old Jun 12, 2007 | 07:03 AM
  #69
IIQuickSilverII
it woudlnt hurt to ask some other shops who have tackled this stroket kit already. Of the top of my head, injected and i think spg have a few BC stroker kits build, that whay you dont have to "reinvent the wheel"
Old Jun 12, 2007 | 07:37 AM
  #70
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Julian,
We checked the part number for the plugs we use, and it is a 12x1.25.
Furthermore, I just opened a motor and removed one to verify that the stock bolts are 12x1.25 - they are. Could you have received something mislabeled - have you verified the plugs you have as truly being a 1.25 thread? If you need a set, let us know.
Old Jun 12, 2007 | 08:28 AM
  #71
Tuning Factory's Avatar
Tuning Factory
We have used their stroker kit a few times now and with any kit stuff has to be clearanced.....sorry it wasn't OUT OF THE BOX ready.
Old Jun 12, 2007 | 10:56 AM
  #72
Julian@MRC's Avatar
Julian@MRC
Oh really..We knew it was not "OUT OF THE BOX READY" However when your told by the manufacturer that you can in fact RETAIN the oil squirters, and you CAN IN FACT NOT retain the oil squirters..This is a bit discouraging at least...
The fact of the Matter is we have to date , besides Team Falcon Drift, we have yet to see one of these strokers up and running..I certainly have not heard of any stroker kit to leave YOUR facility..
Old Jun 12, 2007 | 10:58 AM
  #73
Julian@MRC's Avatar
Julian@MRC
Originally Posted by Hal@IP
Julian,
Actually, they were the correct thread pitch..I stand corrected at this point. I posted bad information given to me by my technitian, I would like to correct that on the record...
Old Jun 12, 2007 | 11:05 AM
  #74
IIQuickSilverII
The fact of the Matter is we have to date , besides Team Falcon Drift, we have yet to see one of these strokers up and running..I certainly have not heard of any stroker kit, or any worthy car for that matter to leave YOUR facility..
lets not get carried away on indirect attacks J ....
I know first hand form a friend doing an engine build with the BC stroker kit and a bunch of other stuff on a greddy kit, i think its being build by SGP, and he should have his car shipped to him too.... from what i understood sgp had done a few of stroker kit already so they knew what to do and probably had some of the stuff liek the gridles all ready probably.
I am sure next time , just as injected has for example, you build a BC stroker kit you know what to expect and it will be much less time consuming.
keep us posted on the progress
Old Jun 12, 2007 | 11:12 AM
  #75
Julian@MRC's Avatar
Julian@MRC
Got it..Sorry..
BC did provide us with some pictures of the build that required further grinding of the piston skirts and rods..This would be great, however we purchased a kit dynamicly balanced from BC. So removing material from pistons and rods at this point would most likely throw off the balance..Therefore this is not feasable..
And on a side note, Look at pic #2.....Look at all those metal shavings in that dudes assembled motor...That is horrid..
Old Jun 12, 2007 | 11:15 AM
  #76
meatbag's Avatar
meatbag
Sounds like BC needs to get their **** together.
  #77
IIQuickSilverII
Did that technician just scaped prision lol
he needs to wear gloves
so if you do some grinding you will have to re-balance everything again?
Old Jun 12, 2007 | 11:17 AM
  #78
IIQuickSilverII
it appears its all fine as far as teh kit goes, but as Julian pointed out the problem was the lack of "comunication" in the instructions provided which cause some down time having to redo some stuff, etc etc
Old Jun 12, 2007 | 11:20 AM
  #79
meatbag's Avatar
meatbag
The lack of communication was BC telling everyone it was a drop in kit and its not. Im not saying its a bad kit or anything but telling people one thing when its really another is just cheesy.
Old Jun 12, 2007 | 11:24 AM
  #80
Julian@MRC's Avatar
Julian@MRC
Well a few grams here, a few grams there, and YUP you throw off the balance...
