Vortech Fuel problems....
Old Jun 5, 2007 | 07:43 AM
  #61
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Audible Mayhem
believe me man, i am very very pro turbonetics right now, we are pushing you guys kits like crazy and have installing tons of them that will flat out WALK any twin turbo stock motors setups, BUT, i have many many TN kits that we followed the instructions perfectly and even on flat ground while driving straight, when you get down under a 1/4 tank, the car does some weird stuff. i would kinda like to see the whole being drilled taken out of the instructions, we have had better luck without the holes in there...
thanks man!!
The ones in the surge tank? I believe last time phunk posted about this he suggessted to continue drilling the stock fuel pressure regulator and to drill the siphon jet orifice rather then removing it. Is that your recommendation as well? Just curious so I can pass it along.
Old Jun 5, 2007 | 07:57 AM
  #62
NS_350GT's Avatar
NS_350GT
I believe he is talking about the two 3/8" holes the instructions say to drill on the side.
Old Jun 5, 2007 | 07:58 AM
  #63
MIAPLAYA's Avatar
MIAPLAYA
Correct that is the surge tank. I'm aware of what he meant in that regard I just want to confirm his thoughts on the siphon jet. Remove or enlarge?
Old Jun 5, 2007 | 08:02 AM
  #64
NS_350GT's Avatar
NS_350GT
That is something i would also like to know about, we pulled that yellow piece out of G thizzles car and now are wondering if we should put that back and if we should have even drilled those two holes. Seems like we shouldn't have.
Old Jun 5, 2007 | 08:11 AM
  #65
MIAPLAYA's Avatar
MIAPLAYA
Well I have over 60,000 miles on my car including track days both drag strip and road course and have never run into an issue with this. I'm not saying others have but I have not. Several others will say the same. Mossy Performance car saw multiple track days and never had one issue. taurran, same thing. I would never personally going around full boosting that close to empty though. Just doesn't make a lot of sense to me.
Old Jun 5, 2007 | 08:14 AM
  #66
priscilla ls1's Avatar
priscilla ls1
MIA he is running very rich and is thinking about plugging up the 2 holes that he drilled in the surge tank and putting the siphen jet back in. Would this help his rich condition any?
Old Jun 5, 2007 | 08:31 AM
  #67
MIAPLAYA's Avatar
MIAPLAYA
Not likely. In theory the holes in the surge tank allow for additional fuel sourcability for the pump. But I don't see that making it run any leaner.
Old Jun 5, 2007 | 08:44 AM
  #68
priscilla ls1
I'm really stumped on this one also. He also seems to be running more rich on the drivers side.
Old Jun 5, 2007 | 10:59 AM
  #69
G Thizzle's Avatar
G Thizzle
so in conclusion the yellow siphon piece and the holes in the surge tank have nothing to do with fuel pressure...
Like i said before, when i was running lean i burnt out the cat on the driverside and now with the test pipes it is blowing cold and backfiring... which means i am getting tooo much fuel on that one side... which is also causing my car to shake at low idle.... which is making run too rich... sooooo confused!!!!
Old Jun 5, 2007 | 11:39 AM
  #70
priscilla ls1
Any fuel gurus out there?
Old Jun 5, 2007 | 12:25 PM
  #71
NS_350GT's Avatar
NS_350GT
Might really need just a good tune, and with some bigger injectors in there it will be easier also.
Old Jun 5, 2007 | 01:07 PM
  #72
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
That's not correct...it definately does effect fuel pressure.
Old Jun 5, 2007 | 01:24 PM
  #73
phunk's Avatar
phunk
CJ Motorsports
drilling the yellow jet will only effect fuel pressure if its too small of a hole for the pump and isnt allowing the regulator to function properly by backing up the internal return flow.
as for putting holes in the side of the canister like turbonetics says, that is just destructive and serves no purpose other than reducing fuel control and increasingly likelyhood of pickup starvation under lower tank and higher g conditions. the only reason you would put those holes in the side is it you were not thinking straight and you completely removed the yellow jet which would kill the venturi effect that draws fuel into the can to begin with, therefore you would need the large holes so fuel has an acceptable path in... but hopefully you would have never removed or over drilled the yellow jet to begin with.
Old Jun 5, 2007 | 01:49 PM
  #74
priscilla ls1
Now that the holes are drilled do you think we should just plug them back up?
