Split second box installed...VDC & SLIP light on
Old Jun 12, 2007 | 08:33 PM
moog's Avatar
moog
Default Split second box installed...VDC & SLIP light on
I'm going to recheck the wiring tomorrow night, but anyone have ideas which wires might be off in the wiring of a split second box w/ Vortech?
Old Jun 14, 2007 | 04:49 PM
moog's Avatar
moog
All wiring checks out okay. i'm using a harness to tap into all the wiring. The car won't drive over like 2400rpm w/o jerking, so I can't really drive over 60mph max.
Could it be a bad SS box? I unplugged the harness and the VDC/SLIP lights turn off if I just use the factory ECU w/o the split second.
thoughts?
Old Jun 14, 2007 | 05:00 PM
04treefiddy's Avatar
04treefiddy
sounds like the wires that go to the maf aren't right to me..
Old Jun 14, 2007 | 05:09 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
take it to the dealer and have them reset it.. i think sometimes this needs reset.
Old Jun 14, 2007 | 08:33 PM
NS_350GT's Avatar
NS_350GT
What all was installed with your kit?
Old Jun 14, 2007 | 09:41 PM
GTM's Avatar
GTM
Vendor - Former Vendor
Sounds like your in limp mode, did you reset the ecu yet?
-George
GT Motorsports
Old Jun 15, 2007 | 04:17 AM
moog's Avatar
moog
How do you reset? Dealer?
Old Jun 15, 2007 | 05:08 AM
04treefiddy
you can pull the battery cables off and then hit the brakes one time to discharge the rest of the electrical current or you can pull the ecm fuse for about 30 secs and that should do it. The ecm fuse is under the battery cover under the hood. Right next to the batter is a line of fuses under a cover. On the top of the cover is listed what fuses are there and the order.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
