Any one Running APS ST with UTEC??
Old Jun 16, 2007 | 06:50 AM
original786's Avatar
original786
Default Any one Running APS ST with UTEC??
i was debating on switchin out my unichip for the Utec, i was wondering if any one is running the Utec on a APS ST.
let me know,
any advice would be helpful
how reliable will it be?
and what is my hp increase potential??
right now im tuned at 9lbs on a unichip
at 360hp, and 360tq
i just think i might be able to increase my number going to Utec.
thanks in advance for any input..
Old Jun 17, 2007 | 07:52 AM
original786
any one??
Old Jun 17, 2007 | 08:16 AM
Zivman's Avatar
Zivman
let me know,
at 360hp, and 360tq
With the setup you have now and the boost you are running, you will see absolutely nothing moving to the utec. The unichip controls everything you need it to with your current setup. If you want more power, up the boost and retune with the unichip. there would be no reason to spend the extra money on the utec at this point. Down the road, that may be a different story, but in that case, I would save that money and put it towards an Fcon Vpro when the time comes
Old Jun 17, 2007 | 09:01 AM
westpak's Avatar
westpak
SFZCC
^+1
Old Jun 17, 2007 | 09:09 AM
kostat26's Avatar
kostat26
let me know,
at 360hp, and 360tq
Damn 9 pounds and only 360? what kinda dyno was it?. i would get the utec though, you could get a map selector and all the other goodies and have a DD map and a Fast map, if u want more power
Old Jun 17, 2007 | 12:54 PM
InZomniac's Avatar
InZomniac
The Utec has a higher resolution though right?
Old Jun 17, 2007 | 01:17 PM
Zivman's Avatar
Zivman
if it does, it isn't by much. From my research, the utec has very limited resolution. IMHO, the main reason to move to an Fcon over a Utec
Old Jun 17, 2007 | 02:40 PM
westpak's Avatar
westpak
SFZCC
The Unichip has a couple of more load columns and just a little over 1/2 of the rpm rows that the Utec has.
For the boost settings you are at I would stick with the unichip and just get it tuned, it sounds like it is stock tune from the dyno results or a function of your exhaust which the APS ST is very dependent on.
So get it tuned if you want more power and save the money for later on if you want to go Fcon, it has 3 times the amount of load columns which is what makes it so smooth in the low boost and driveability areas as opposed to the other EMS' currently out for the Z.
Old Jun 17, 2007 | 02:41 PM
original786
basically i want more power to tell you the truth!
i was thinking of going to UTEC only becuase i want maybe build my motor hopefully, if all plans out!
Old Jun 17, 2007 | 02:42 PM
original786
if fcon is the same system as a utec, or unichip???
wat are the advantages over another
Old Jun 17, 2007 | 02:43 PM
Zivman's Avatar
Zivman
If you build your motor, spend the money on the Fcon. The utec isn't all that IMHO. From what I researched, the limited resolution limits it. Stick with the unichip until you decide specs on a build
Old Jun 17, 2007 | 03:03 PM
original786
so if i just get a fcon, i can get it tuned with my aps st? at this time
Old Jun 17, 2007 | 03:07 PM
Zivman's Avatar
Zivman
yes, but at this time, the Fcon would be major overkill.
hold onto the unichip and just get it retuned. When you build the motor, tackle the new EMS then. Until then, if you have money burning a whole in your pocket, you are welcome to send it my way. I have a set of cams and other goodies I just recieved an invoice for
apex locator
Jul 23, 2021 02:27 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
