Forced Induction Cooling: Upgraded Fan Results..wow
Old Jul 11, 2007 | 12:36 PM
taurran's Avatar
taurran
Originally Posted by Sharif@Forged
Believe or not, the footprint is actually shallower than stock. 4 1/4 inch total depth. We have more clearance now, vs. the stock fan/shroud setup.
Damn.. nice... So here's the question I have now: Will this shroud allow you to run the thicker core Koyo setup and clear the turbonetics intake pipe??
That would be awesome if so.
Old Jul 11, 2007 | 12:37 PM
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
See the power of the aftermarket fans! We run those Spals and Permacool fans on alot of cars.Typically with shrouds when there is enough space.We put the same size fans on a G we did about a year ago.We noticed the temp will never climb over 195f.We didnt build a shroud for it though because it had a custom intake and there was no room for the piping so we just bolted the fans to the radaitor.Coolant temps were still very good.Thereis probabl another 10F cooler with the shroud according your results with shroud vs. our results with no shroud.Which radiator were you running there.We had the 54mm Koyo in the G.
We also tried to get the factory fan circuit to control the aftermarket fans and didnt have too good of luck.I figured if I could wired up some factory HIDs to a halogen equipped Z,then it should be not problem.Boy was I wrong.
Old Jul 11, 2007 | 12:39 PM
TurboTim's Avatar
TurboTim
I can anwser this, no. You can run two of these fans on the 54mm Koyo with no shroud but you will have to do some grinding on the fansYou know I was thinking about this so more and we did this on a rev-up which has large covers for the cam sprockets so it might work with a shroud but the shroud would have to very shallow.
Old Jul 11, 2007 | 12:49 PM
MIAPLAYA's Avatar
MIAPLAYA
True but couldn't you run a thinner core radiator and use the Spearco IFC like I referenced earlier with this so you could have a shroud still. If the fans run all the time at 6 volts and 12 volts under boost it should keep the motor cool enough. At any rate it would be better then the on again off again setup the stock fans use.
Old Jul 11, 2007 | 12:56 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by Zivman
Those look great.
I have to know though; my buddy runs those spal fans on his car - not a Z, and they are INSANELY loud. When at idle, that is about all that can be heard.
How loud are they in this setup?
They loud when the engine is not running, with the engine running, you can just barely here it.
Old Jul 11, 2007 | 01:02 PM
Philthy's Avatar
Philthy
Boost Junkie
Very Nice!
Sharif@Forged
Forged Performance
We are running the large koyo core in the pictures, but the shroud will work on both thin and thick core rads. The thin, will obviously give you more clearance. It really cleans up the engine bay nicely too. I forgot to snap pics of Brent's installed, but I will take pics of mine in two days.
Old Jul 11, 2007 | 01:18 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
can you pm me price for the shroud and fans?
Zivman's Avatar
Zivman
Originally Posted by MIAPLAYA
That can be adjusted too. You can run a voltage step relay. Basically it will keep the voltage for the vans lower then 12 at idle if you want it to and then at a preset point (referenced by load, MAP, MAF, etc) it will kick the voltage up to 12 volts. If you have the fans always on at say 6 volts at idle you won't hear them and under load the exhaust will be louder then the fans. Its exactly the way Turbonetics set up the Spal fans on the G35 intercooler. In fact you could probably get just that controler box (IFC) from someone or from a dealer. It already has the Spal Connectors attached so all you need to do is wire it in. It should work just the same and as well for those that don't want to hear the Spals at idle. If the fan is constantly running at idle at 6 volts as opposed to switching on and off based on temp your coolant temps should always be low.
awesome - thanks
Old Jul 11, 2007 | 01:19 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
and are you going to maybe creat a DIU writeup?
Old Jul 11, 2007 | 01:25 PM
Sharif@Forged
Forged Performance
It's not really a DIY project, since you need a tig welder, and a brake, which most home shops will not have.
But physically, its not hard at all. It's basically a aluminum metal box, formed from aluminum sheets, with holes cut out for the fans, and brackets welded to it. It's a lot easy said than done.
Old Jul 11, 2007 | 01:27 PM
Blackbird CPV35's Avatar
Blackbird CPV35
Originally Posted by Barzten1
Will it clear the Vortech piping? Im down for one.
+1
Old Jul 11, 2007 | 01:44 PM
Navygolf13's Avatar
Navygolf13
Looks good, what is the cost and will it work with the JWT kit?
Old Jul 11, 2007 | 01:48 PM
Sharif@Forged
Forged Performance
Yes it will.
Vortech....thats a tough one...not sure.
Old Jul 11, 2007 | 01:53 PM
Navygolf13's Avatar
Navygolf13
Yes it will.
Thats good to hear, what about cost? I am sure you dont know for sure, but maybe a ballpark?
Old Jul 11, 2007 | 01:55 PM
overZealous1's Avatar
overZealous1
running a set of 12" fans on a custom 3" rad here. still was not keeping the temp where i wanted it with them bolts to the rad. left to much open space. will be making a shroud and possibly adding 2 10" pushers too.
the shrouds help tremendously in pulling air through the entire rad!!
Old Jul 11, 2007 | 02:12 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
that is a nice looking piece sharif. It is funny, how some of the tips and tricks from long ago... other cars I have owned come back and do similar things on these cars.
my mr2 had a custom shroud and spal fan on a stock IC and performed as well as the greddy unit w/o a fan.
+1 keep up the great work.
Old Jul 11, 2007 | 02:16 PM
  #38
Blackbird CPV35
Yes it will.
what about with a Koyo Slim or a Stock radiator?
Old Jul 11, 2007 | 02:21 PM
  #39
Gumpdriver's Avatar
Gumpdriver
Bro Chris did one great job making that it looks awsome happy to know it really works.
Old Jul 11, 2007 | 02:48 PM
  #40
__jb's Avatar
__jb
Z + Rear Seat
Very nice, Sharif...
Perfect time for that mod down here in Florida... High nineties every day... except when raining of course.
Very nice craftsmanship on the welds, too!
