450WHP on 14 PSI APS TT - Is this normal?
Old Jul 17, 2007 | 04:47 AM
DRE350's Avatar
DRE350
Default 450WHP on 14 PSI APS TT - Is this normal?
Baseline 207 WHP. Not sure what type of dyno.
Now basic built block, making 450WHP on 14 PSI. People on this forum seem to be making much more power than this on this boost level. Is there something wrong with my engine?
Old Jul 17, 2007 | 04:50 AM
RedBullRR's Avatar
RedBullRR
Making a Guess here but it might be the Dyno itself.
Old Jul 17, 2007 | 04:51 AM
Mike Wazowski's Avatar
Mike Wazowski
what dyno are you using? Baseline seems really low. Can you post your dyno graph?
Old Jul 17, 2007 | 05:07 AM
booger's Avatar
booger
More info ??? FI kit, exhaust, HFC's ? need info
Old Jul 17, 2007 | 05:20 AM
mforrest100's Avatar
mforrest100
We need details!!!!
Old Jul 18, 2007 | 05:25 AM
DRE350's Avatar
DRE350
Basic built block.
ARIAS ED Pistons 9.0:1
Eagle Rods
ARP Bolts
HKS Head Gasket
Cosworth Bearings
Valve springs and shim kit
Stock APS TT kit except for upgraded actuators (unichip, fuel system, etc)
I think that's it engine wise.
I'm not so concerned with the actual numbers as I know different dynos produce different numbers. I'm interested in the increase over stock levels.
So I've gone from 207 to 450 WHP on 14 PSI. This is an increase of 243 WHP - does this seem right?
Old Jul 18, 2007 | 05:34 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
seems a little low. What engine management and exhaust are you using?
Old Jul 18, 2007 | 05:36 AM
westpak's Avatar
westpak
SFZCC
Well from the 207 I would say it is a load based dyno so 450 is not bad it would be around 500RWHP on a dynojet, maybe a little low but not by much.
Old Jul 18, 2007 | 05:43 AM
DRE350's Avatar
DRE350
Engine Management - Unichip
Exhaust - APS True Dual 2.5 inch
Old Jul 18, 2007 | 06:19 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You still havent answered, what dyno is this on?
Old Jul 18, 2007 | 06:31 AM
synth19's Avatar
synth19
Agreed, REALLY low baseline.
Old Jul 18, 2007 | 06:33 AM
captj3's Avatar
captj3
Do you still have your cats installed?
Old Jul 18, 2007 | 06:35 AM
MUZZY's Avatar
MUZZY
seams real low
Old Jul 18, 2007 | 10:09 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It's probably kW not HP, the guy's an Aussie, explains the 207# baseline
by the same logic 450kW > 450hp, so maybe the car is fine
Old Jul 18, 2007 | 11:19 AM
rcdash's Avatar
rcdash
If it was really kW, that would be around 600 hp. that's too high.
Old Jul 18, 2007 | 11:52 AM
rocks's Avatar
rocks
I have read somewhere australian dynos read lower.
Old Jul 18, 2007 | 01:39 PM
DRE350's Avatar
DRE350
Dyno Dynamics - which is load based I believe
Those figures are in HP
Other things: high flow cats, APS Plenum
Whatever dyno you use shouldn't the increase in WHP be approximately the same?
So does a 243 WHP increase seem low to you guys?
Old Jul 18, 2007 | 01:49 PM
DMK's Avatar
DMK
It's a little low. Most guys here dyno around 230-240whp, so that comes to about ~490 whp with your increase.
Old Jul 18, 2007 | 03:39 PM
Zivman's Avatar
Zivman
Considering you are running cats, and stock heads, your numbers aren't terribly low - especially when you factor in your baseline.
I know aussi land has some killer unichip tuners, but IMHO you are beyond what the unichip can do for you... it 'may' be holding you back.
One other thing that came to mind is your fuel system. if you are running the out of box APS fuel system, you have all but maxed out those injectors and that also may be limiting your HP.
Old Jul 18, 2007 | 07:43 PM
Dubai's Avatar
Dubai
thats what I was thinking.
