Official STS Rear Mount Turbo Discussion Thread
Old Jan 12, 2008 | 03:04 PM
  #1001
str8dum1's Avatar
str8dum1
nice, you'll have to let me know when everything gets installed so we can go for some runs. TOrqueless SC vs a STS turbo
Originally Posted by App6MT
athen, good choice on the cooling mist. I am definitely planning on some sort of water/meth setup when the STS comes.
Have you thought about a EBC, especially with daniel's results?
Game plan is to get the body kit put on and painted at the end of the month and try to us STS down to $4000 for the kit. They offered it for me for $4500 (side piping) so we'll see what happens. After that, a trip down to PF for a retune, EBC setup and water/meth around May or so, maybe April when all the HS/college girls are on spring break
Old Jan 12, 2008 | 03:07 PM
  #1002
TheProfessional's Avatar
TheProfessional
*Edited* pending recourse
  #1003
TheProfessional
Now my problem is I can not find the fuel pump relay wire.
The manual says its the black with yellow stripe, but neither test correctly.
Can anyone tell me what the 2006 fuel pump relay wire is?
Old Jan 12, 2008 | 05:19 PM
  #1004
App6MT's Avatar
App6MT
Hey sorry Professional about the PM earlier, haven't been following the thread today, was busy putting in the coil overs...
Anyhoo, I am looking at the 05-06 G Repair Manual and according to it the Fuel Pump Relay wire is B/Y (black/yellow) and the wire going to the ECM is B/OR (black/orange).
Hopefully someone with more knowledge can chime in here and save the day. And if you figure it out, I would like to know cause I have a revup too
Old Jan 12, 2008 | 05:22 PM
  #1005
App6MT's Avatar
App6MT
So I should have went to the next page...
Terminal No.: 113
Wire Color: B/OR
Item: Fuel pump relay
Condition:
1) Ignition Switch: ON Result: 0-1.5V (for 1 second after turning ignition switch ON)
HOPE THIS IS RIGHT!!!
Old Jan 12, 2008 | 06:10 PM
  #1006
athenG's Avatar
athenG
I hope you checked every parts before you start the install. I'll admit that they do ship missing parts so just make sure you have everything so down time will be minimal You are probably the first Revup to do a self install so it may be a little tricky. I do have a revup but MRC did mine.
Old Jan 12, 2008 | 10:18 PM
  #1007
TheProfessional
Old Jan 13, 2008 | 05:57 AM
  #1008
App6MT's Avatar
App6MT
How's the install going???
Wish more of us could help but you are the first RevUp to do it.
I know I am going to run into problems already because of the Rear Active Steer. The air filter runs right into it. Haven't thought about it too much but need to come up with a game plan of what to do, probably going to involve some sort of flex piping.
Did you figure out the fuel pump relay wire?
Old Jan 13, 2008 | 07:05 AM
  #1009
TheProfessional
Old Jan 13, 2008 | 07:30 AM
  #1010
Ahsmo's Avatar
Ahsmo
Imakecopies
That goes into the fitting on the charge air pipe.
The way STS has their oil and pcv lines run made my hood hit so I did it this way:
Old Jan 13, 2008 | 07:54 AM
  #1011
athenG's Avatar
athenG
Here's mine.
Old Jan 13, 2008 | 08:11 AM
  #1012
TheProfessional
Here's my biggest concern right now, the entire system in the rear is too far forward by at least 2 inches.
Old Jan 13, 2008 | 08:22 AM
  #1013
athenG's Avatar
athenG
Do you have a stock Rear Bumper? My tip was also short but because I have the ING Rear Lip so I ended up melting it before I got some Exhaust tip from Magnaflow. double check your everything and your turbo Cold side should be point down.
Old Jan 13, 2008 | 08:33 AM
  #1014
TheProfessional
One other question. I can not figure out what this green wire is in the harness. Is this for the optional meth/water injection??
Old Jan 13, 2008 | 08:42 AM
  #1015
Ahsmo's Avatar
Ahsmo
Imakecopies
that wasn't on mine. Dont worry about it. As long as all the of the solenoids are working, you should be fine. Check the eletrical system at the end.
Old Jan 13, 2008 | 09:43 AM
  #1016
DanielW's Avatar
DanielW
maybe its a ground?
Old Jan 13, 2008 | 09:46 AM
  #1017
Ahsmo's Avatar
Ahsmo
Imakecopies
Originally Posted by DanielW
maybe its a ground?
There is one up in the battery area.
Edit**
AthenG, I see that you have your oil lines low rather than high. Does that really matter? I ran mine up as high as I could.
Old Jan 13, 2008 | 10:08 AM
  #1018
TheProfessional
Old Jan 13, 2008 | 12:57 PM
  #1019
athenG's Avatar
athenG
Edit**
Stick to what you have. follow the manual, if you don't then you might leak some oil when parked on an incline. Me and goosegoos had the same routing and he had problem with it.
Old Jan 13, 2008 | 01:03 PM
  #1020
QuadCam's Avatar
QuadCam
I am curious what is going on with all those PCV lines and accessories?
Professional,
How is the Revup PCV system different from the standard 287? My Revup has all the same parts and locations as the regular VQ35DE. The PCV is located in the screwed into the top of the passenger side valve cover and connects to the intake manifold. there is a crossover tube that connects the 2 valve covers together, and the back of the driver side valve cover has the breather port, which is conencted to the intake tube via a rubber hose.
BTW, Does STS have online instruction manuals?
