Official STS Rear Mount Turbo Discussion Thread
Old May 28, 2009 | 05:35 PM
  #2001
goosegoose's Avatar
goosegoose
Originally Posted by Boozt
OK boys.....I spoke with STS they quote the stock kit will max out at 550 crank HP at 15 psi with the standard turbo and 440 injectors. Anybody care to comment on the loss of low end grunt with the change over to low compression pistons? My dilema is two types of racing.....I AutoX 10 times/year and large track 8-10X/year. Kinda looking for the best of both worlds.....with an occasional drive on the public twisties. Input?
I forgot to comment about the injectors. I'm running 600cc Deatchwerks with a CJM Stage 1 fuel return. My IDCs are in the mid 90s by 16psi. I don't think you want to keep the 440ccs.
Old May 29, 2009 | 05:17 AM
  #2002
Boozt's Avatar
Boozt
Thanks for the info. My budget is getting stretched out pretty far on this.....I will have to keep the 440's for now then switch them out when I go to GTM for the OSIRIS tune. GTM does offer a 9:1 ratio....and this might work out well for me since I don't plan to go over 12 psi....but I am a driver not a builder. In the end I am going to have to refer to GTM to set me up with the most reliable motor I can get for as hard as I run the car. Truth be told...If I make more power than I did (I would think that I would have to an extra 5psi and proper tune) I am good with the current turbo etc. I have a decent base to work with so I will run it as for now and play with my budget later. Thank you for all your help.
Old May 29, 2009 | 02:13 PM
  #2003
skn5002's Avatar
skn5002
Default Oil in exhaust...
I made a separate thread about this but thought I would post it here as well for your input. I have only driven the car once since everything has been installed and never really gotten into boost. Today I idled my car to move it into my garage. I noticed oil in the exhaust. What is causing this? I did a boost leak test a few days ago, which yielded good results. Could have pressurizing the system somehow force oil into the exhaust? Another thing to note is that I am using an oil filter sandwich plate rather than the oil sensor tap STS includes. Could this be creating higher than normal oil pressures? Any input would greatly be appreciated. Pics are below.
[IMG]<a href="http://s240.photobucket.com/albums/ff309/skn5002/?action=view&current=phpsqQFYPPM.jpg" target="_blank"><img src="http://i240.photobucket.com/albums/ff309/skn5002/phpsqQFYPPM.jpg" border="0" alt="Photobucket"></a>[/IMG]
[IMG]<a href="http://s240.photobucket.com/albums/ff309/skn5002/?action=view&current=phpTBRrmJPM.jpg" target="_blank"><img src="http://i240.photobucket.com/albums/ff309/skn5002/phpTBRrmJPM.jpg" border="0" alt="Photobucket"></a>[/IMG]
Old May 29, 2009 | 02:29 PM
  #2004
DudeMan's Avatar
DudeMan
idk but that looks like coolant mixed with oil
Old May 29, 2009 | 06:04 PM
  #2005
goosegoose's Avatar
goosegoose
If it's only oil, no coolant, check if the oil drain for your turbo is working properly. If the oil drain is not clocked PERFECTLY downwards, it could cause oil to come out of your passenger tailpipe only.
Old May 29, 2009 | 06:05 PM
  #2006
goosegoose's Avatar
goosegoose
You're very welcome. Please keep me posted on your results.
Old May 29, 2009 | 07:39 PM
  #2007
skn5002's Avatar
skn5002
Here is a pic of the oil return line. Is it clocked correctly? Thanks
[IMG]<a href="http://s240.photobucket.com/albums/ff309/skn5002/?action=view&current=phpM9JZfSPM.jpg" target="_blank"><img src="http://i240.photobucket.com/albums/ff309/skn5002/phpM9JZfSPM.jpg" border="0" alt="Photobucket"></a>[/IMG]
Old May 29, 2009 | 08:11 PM
  #2008
DudeMan's Avatar
DudeMan
just curious whens the last time you got an oil change? because if thats not coolant thats some oldddd *** oil
Old May 29, 2009 | 09:32 PM
  #2009
skn5002's Avatar
skn5002
That's brand new oil that just has been changed. I bought the kit used so the exhaust was pretty carbon coated to begin with. Maybe it mixed in with that. I have no idea how long the oil has sat there, I am guessing that oil has sat in there for a while; the last time I started it up was almost a week ago. It has rained the past few days, so perhaps water mixed in with it.
Old May 29, 2009 | 09:43 PM
  #2010
skn5002's Avatar
skn5002
I don't think the STS kit comes with an oil restrictor... is there a reason for this? Will adding a oil restrictor to the oil feed line starve the turbo in any way?
Old Jun 4, 2009 | 11:46 AM
  #2011
skn5002's Avatar
skn5002
Default HKS EVC VI Issues....
I had my car tuned a few days ago. I installed the EVC but never really looked into setting it up since I thought my tuner would be able to do that all for me. However, the tuner was having problems getting the EVC to work right. The motor was unable to hold the desired boost levels. The controller would be set for 8.5 psi, but the turbo would only make 6.5-7.0 psi and gradually decrease.
How did you guys install the EVC? I tapped 62 yellow/red on the ecu for the rpm signal and 50 green for the throttle position sensor. Did you T a line from the compressor housing of the turbo to the boost reference line that runs from the wastegate and connects to the main vacuum line in the motor? Did you mount the boost controller actuator in the rear to be closer to the turbo?
Old Jun 15, 2009 | 07:23 PM
  #2012
harvin350z's Avatar
harvin350z
Default Finally took some videos
Got around takinsome videos of the car with the hks bov...every thing else is stock..even the boost for now (5.5 psi)
http://www.youtube.com/watch?v=9TSXJ0Vh6FM
http://www.youtube.com/watch?v=7FtNnYYBTBM
http://www.youtube.com/watch?v=-SlV6_5gRp0
Old Jun 18, 2009 | 04:59 PM
  #2013
athenG's Avatar
athenG
Is this with stock cat? Is that the bov flapping on your second video? I can hear your turbo/bov with just a little blip on the thorttle which I like. Are you building boost early on 1st and 2nd gear? Nice video!!
Old Jun 18, 2009 | 05:13 PM
  #2014
Z33_kid's Avatar
Z33_kid
looks like coffee but wow it doesnt look good
Old Jun 18, 2009 | 05:33 PM
  #2015
DudeMan's Avatar
DudeMan
compressor surgeeeeee is not good
Old Jun 18, 2009 | 06:44 PM
  #2016
athenG's Avatar
athenG
/\ HKS is known to flap at low boost but it do hear some compressor surge. I was asking about the second video because it is the first time I hear a Bov flap like that with just a litttle rev (unless he's really using a light bov spring) and if it is a surge the it will be the first time I hear an STS getting a compressor surge with just a blip on the thottle. Heck I can rev my car all the way to redline all day and not hear my BOV flap nor get that kind of a compressor surge
Old Jun 18, 2009 | 08:11 PM
  #2017
DudeMan's Avatar
DudeMan
i had an hks on my sti theres no spring its not like the tial
Old Jun 19, 2009 | 07:44 AM
  #2018
athenG's Avatar
athenG
Isnt there a tention adjuster on the HKS you can tighten for different vacuum? I definitely hear some kinda of surge but that second video really got me confuse. The STS is not a fast spooling turbo so I doubt it will get that kind of surge on such a low load. I do get a surge at 1-3psi below 3700rpm and above 3rd gear (never on 1st and 2nd gear). I remember him posting that his spool isnt great on 1st gear but got better with the TP. That is why I asked if he's building boost early on 1st gear.
Old Jun 19, 2009 | 01:15 PM
  #2019
DudeMan's Avatar
DudeMan
the fake ones have screws the real ones are non adjustable
Old Jun 19, 2009 | 02:58 PM
  #2020
athenG's Avatar
athenG
So how do you compensate for vacuum difference between cars?
