Official STS Rear Mount Turbo Discussion Thread
Old Jan 13, 2008 | 01:11 PM
  #1021
TheProfessional's Avatar
TheProfessional
*Edited* pending recourse
Old Jan 13, 2008 | 01:13 PM
  #1022
TheProfessional
Originally Posted by QuadCam
I am curious what is going on with all those PCV lines and accessories?
Professional,
How is the Revup PCV system different from the standard 287? My Revup has all the same parts and locations as the regular VQ35DE. The PCV is located in the screwed into the top of the passenger side valve cover and connects to the intake manifold. there is a crossover tube that connects the 2 valve covers together, and the back of the driver side valve cover has the breather port, which is conencted to the intake tube via a rubber hose.
BTW, Does STS have online instruction manuals?
No online manuals, and trust me I was pissed yesterday when I couldn't get any answers.
The reveup valve cover on my car does not have the same location to mount the housing.
Old Jan 14, 2008 | 03:34 AM
  #1023
App6MT's Avatar
App6MT
Any updates?
Old Jan 14, 2008 | 07:56 AM
  #1024
TheProfessional
Originally Posted by App6MT
Any updates?
I am not making any public updates right now, but if you PM me I will copy where I am with this.
Old Jan 14, 2008 | 08:00 AM
  #1025
synth19's Avatar
synth19
Guys, I'll PM him, get the latest info.. and then update the thread. LOL! (jk)
Old Jan 14, 2008 | 08:12 AM
  #1026
Ahsmo's Avatar
Ahsmo
Imakecopies
thank you
Old Jan 14, 2008 | 08:35 AM
  #1027
synth19's Avatar
synth19
^ +1
Old Jan 14, 2008 | 09:22 AM
  #1028
QuadCam's Avatar
QuadCam
the PS cooler can be moved. My Revup G had a 2-piece bracket. I ended up using one of the brackets and relocated the PS cooler up into the passenger side fender well for my TN ST install. When I went with the Greddy Twins, I moved the PS cooler back to its normal spot.
Old Jan 14, 2008 | 06:06 PM
  #1029
DanielW's Avatar
DanielW
just wanted to let everybody know that when I turned the duty cycle up on the turbo (I've since backed it down a little due to boost spikes between shifts on the auto) with the AVC-R I was able to fully spool up by 3500-3550 rpms in 4th gear. That beats the 4000 that most of us started out experiencing
Old Jan 14, 2008 | 06:07 PM
  #1030
App6MT's Avatar
App6MT
I love it. Are you running TPs?
Old Jan 14, 2008 | 06:21 PM
  #1031
Ahsmo's Avatar
Ahsmo
Imakecopies
At 8 psi?
Old Jan 14, 2008 | 06:47 PM
  #1032
athenG's Avatar
athenG
What RPM did you started the Pull?
I still have my stock CAT and maybe it is the colder weather but I hit 8psi at around 3400rpm on a 5th gear pull (I have a 6mt) and starting my pull around 2500rpm with just the Utec BCS. I think with a Test Pipe and a good EBC then I hope I can get some better result.
Edit:
I just looked at my logs and I started the Pull at 2800rpm and hit 8psi at 3200rpm.
Old Jan 15, 2008 | 03:38 AM
  #1033
App6MT's Avatar
App6MT
Originally Posted by athenG
Edit:
I like it
Lag was my only concern (and it wasn't that big of a deal) but it seems the kit is able to make power earlier with a few modifications.
Old Jan 15, 2008 | 07:15 AM
  #1034
DanielW's Avatar
DanielW
yeah about 8 psi. And I could deffinitely do better. That was on a pull where the turbo hadn't really been heated up yet. If I did a few back to back pulls I could probably get it down to 3200
Old Jan 15, 2008 | 07:16 AM
  #1035
DanielW's Avatar
DanielW
the main thing with the EBC though is the spool characteristics of 1st and second are completely different
Old Jan 15, 2008 | 07:49 AM
  #1036
EnjukuBG's Avatar
EnjukuBG
Enjuku Racing
Hey bud, ill let you know today, when we can set up you up.
Old Jan 15, 2008 | 10:24 AM
  #1037
DanielW's Avatar
DanielW
Muy Excellente Mi Amigo
Old Jan 15, 2008 | 10:26 AM
  #1038
DanielW's Avatar
DanielW
Edit:
I was thinking too (just thinking) maybe the difference comes because of the TQ converter on my auto. When I punch the gas the RPM's immediately "slip" up to wherever the stall is set where as when you punch the gas it starts from the rpm your at. Just a thought.
Old Jan 15, 2008 | 10:43 AM
  #1039
copec's Avatar
copec
what kind of boost do you see in first and second gears?
Old Jan 15, 2008 | 10:44 AM
  #1040
App6MT's Avatar
App6MT
Daniel sees full boost (think he's running 7.5 now)
