Official STS Rear Mount Turbo Discussion Thread
Old Aug 11, 2007 | 05:50 AM
athenG's Avatar
athenG
Originally Posted by Conceyted
Who will be the first to blow up their stock motor on the STS kit?
Cube's Avatar
Cube
Ionno but I might blow my stock tranny on it
They say they won't guarantee ANYTHING past 10 psi...
Originally Posted by NA&CH
I just got an email for 4995... with utec?
Where'd you hear this from?
Edit: Oh I just remembered why I came here... will the Nismo exhaust fit at the end? Will the exhaust manifold supplied bolt up to the Nismo exhaust piping?
I'm thinking of getting the Nismo exhaust and selling the muffler...
Old Aug 11, 2007 | 06:04 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I was considering buy this kit but 5500 without install is def pricey for me. Much rather have a TN or a TT kit, but thats me call me crazy. all that money for 350hp But Ill give u STS guys 1 thing your cars sound INSANE!!
Old Aug 11, 2007 | 06:29 AM
Conceyted's Avatar
Conceyted
Originally Posted by athenG
Oh come on, is the question really that absurd? If people can run this kit safely on a stock motor forever then this will be the new flavor or the month/year. I guess only time will tell.
Old Aug 11, 2007 | 06:37 AM
Cube's Avatar
Cube
Is this kit really worth it potential-wise? I have a big fat heavy FX35 with AWD and 5AT losses. My goal is to break 400 whp and wtq, which will require alot more than usual at the crank to overcome the losses. Will this kit be able to do it?
Keep in mind, I have a built motor (9.0:1 Arias ED, H-beam, ARP, etc), so my block isn't what's holding me back from the hp/tq goals.
Old Aug 11, 2007 | 09:20 AM
DanielW's Avatar
DanielW
Originally Posted by Cube
What makes this thread official?
Btw, Daniel, when I just saw Bourne Ultimatum, they mentioned his real name and I was thinkin "That's where that dude w/ the STS got his name... oh wait, DAVID Webb..."
And lastly:
Who is that?
thats insane i was watching the bourne supremacy last night and I reallized the same thing. But they go DW from me not the other way around
Old Aug 11, 2007 | 09:21 AM
DanielW's Avatar
DanielW
And someone said it. Wheres the vids and pics. From you guys not STS
Chris
search titles only for sts and look at the sts vid thread posted by either dj smitty or cin motorsports. there is a compilation they did as well as a video i made on youtube. you can also just go to youtube and type in daniel sts 350z
Old Aug 11, 2007 | 09:26 AM
DanielW's Avatar
DanielW
I'm not sure what the efficiency of this turbo is as far as what kind of psi its good till but I'm thinking if you got most of the bolt ons, a good tune (mine could be better), and turned the boost up to 11 or 12psi you should have no problem hitting 400 to the wheels even with the auto.
Old Aug 11, 2007 | 09:29 AM
DanielW's Avatar
DanielW
http://youtube.com/watch?v=Z47z7OCHti8
thats a video i made on a back road when i first got the kit
Old Aug 11, 2007 | 09:56 AM
Conceyted's Avatar
Conceyted
Assuming you are running a stock block, how long do you estimate your engine will last?
Old Aug 11, 2007 | 11:14 AM
athenG's Avatar
athenG
Pricey? Name me a kit that you can get for $5500 with Utec+Map Sensor, spark plugs, injector the size of what STS is giving. Tial BOV and Wastegate are not that cheap either. News flash... TN also out of the box is around 360-380 with 8-9PSI, STS is making 350-360 with only 7.5 PSI and stock exhaust and with CAT.
you can get a TN (G35 ver.) Kit for 5000 complete but with a reflash and 380 injector.
Old Aug 11, 2007 | 11:19 AM
athenG's Avatar
athenG
Same as any other kit out there... boost is boost and there is nothing different with Rear-Mount Turbo.
Old Aug 11, 2007 | 11:23 AM
plumpzz's Avatar
plumpzz
STS turbo is an AWSOME deal. No flash is as good as a nice tune on UTEC also. Many people run turbonetics with the base flash but the flash is 'too conservative' and may not be right for everyone. UTEC alone is 1000 bucks, the tial blow off valve and EWG is also around 500 bucks. STS turbo kit is a great deal..
Old Aug 11, 2007 | 02:27 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Can someone take a picture of where the 3/8" hose goes from the 1 psi switch please? A line comes off the the drivers side of the PCV valve and goes into the switch. The outlet of the switch goes.....???????
The install manual leaves that part out...
Old Aug 11, 2007 | 05:50 PM
aarantes's Avatar
aarantes
It's FI your engine will go sooner or later... How long it will last depends on a number or things but mainly tune.
As for how long it will last I am getting mine done at the end of august and I drive about 100 miles a day so I will keep you updated.
Old Aug 11, 2007 | 08:12 PM
DanielW's Avatar
DanielW
I think running at 7.5 psi the engine will be good for a lot longer than most kits on the market
Old Aug 12, 2007 | 05:46 AM
Cube's Avatar
Cube
I think
All speculation. You're brand new to FI. I've already blown my stock motor at 6.5 psi...
You might be cruising along, 2200 rpm on a hot, semi-humid day and feel like having a little fun and get up to maybe 3400 rpm (which is probably when your turbo starts spoolin anyways) and POP! Completely unexpected time
Good luck, and I hope you have a backup plan.
Now as for the kit, how hard do you think it would be to customize this into a TT setup? Maybe get a Borla exhaust and throw another turbo on that beeyotch?
Old Aug 12, 2007 | 07:59 AM
  #38
DanielW's Avatar
DanielW
I don't know I'm new to FI you know.
I think when you're just cruisin alon and "pop" goes the engine is the product of prior abuse. You could say the straw the blew your engines block
Old Aug 12, 2007 | 08:19 AM
  #39
Conceyted's Avatar
Conceyted
While that is generally the case, no one really has a way of knowing exactly when their engine started to break down. The time it happens is just when it finally failed, but prior abuse or just too much for the engine to handle can slowly deteriorate and blow an engine. Tauran ran a Turbonetics kit on his Stock block for a good two years and it finally ended up blowing up. Like Cube said, I hope you do have the money to build your engine. I would never ever go FI before saving enough to build an engine in case of failure (which appears to be inevitable for our engines)
Old Aug 12, 2007 | 08:55 AM
  #40
i8acobra's Avatar
i8acobra
Gotta call tomorrow and see if they have any plans to offer a "tuner" kit with out the UTEC or fueling parts.
