Official STS Rear Mount Turbo Discussion Thread
Old Jan 28, 2008 | 11:02 AM
  #1101
Ahsmo's Avatar
Ahsmo
Imakecopies
Originally Posted by DanielW
I think John may have dynamatted the inside of his rear and significantly reduced the cabin noise. Maybe he'll chime in here
I have three Dynamat Xtreme Bulk Paks(3x36ft^2) in my car now. Its still really loud. I don't really mind, it sounds exotic but ya can hear it 3 miles from my house and my girl friend said she could hear it like I was driving by
Old Jan 28, 2008 | 11:11 AM
  #1102
athenG's Avatar
athenG
Now I'm not sure if I should go ahead with my TP install. Mine is no louder than any aftermarket exhaust out there but I have stock Cat though.
Old Jan 28, 2008 | 11:58 AM
  #1103
TegraRacer134's Avatar
TegraRacer134
Every part from behind the seats in my car has been dynamatted and it doesnt sound nearly as loud as your car does daniel.
Old Jan 28, 2008 | 01:57 PM
  #1104
DanielW's Avatar
DanielW
do you have resonated or non resonated test pipes?
Old Jan 28, 2008 | 01:58 PM
  #1105
Ahsmo's Avatar
Ahsmo
Imakecopies
resonated
Old Jan 28, 2008 | 03:01 PM
  #1106
DanielW's Avatar
DanielW
hmmm... muffler maybe?
Old Jan 28, 2008 | 03:31 PM
  #1107
athenG's Avatar
athenG
Goosegoose's car got louder when he did the heat wrap so he replaced the mid pipe resonator with this http://www.magnaflow.com/02product/s...ne=main&id=845
He said It really brought the noise levels down. It is also a straight-through muffler so it does not inhibit flow.
STS also tried to replace the mid pipe with a straight pipe and that made the car unbearable.
Edit:
It is really getting difficult to find information on this thread. I took the liberty to update the first page with some of the parts that current STS owner have used for others to use as a reference.
Old Jan 28, 2008 | 04:18 PM
  #1108
TegraRacer134
Heres a video of my car with non resonated test pipes, invidias, and I straight piped the OEM resoator that came from the factory mid pipe so it wasnt resonated at all. It is no longer like this but it was stupid loud. It got annoying after a few months.
http://youtube.com/watch?v=7XhDTWhfB84
Old Jan 28, 2008 | 05:58 PM
  #1109
Ahsmo's Avatar
Ahsmo
Imakecopies
hahah where? Resonated tips?
Thats a great video
Thanks athenG. That helps a bunch.
Old Jan 29, 2008 | 07:59 AM
  #1110
DanielW's Avatar
DanielW
hey ahsmo, I was looking at your dyno graph, and like atheng said it looks like the power comes on kinda late. Did they do the dyno pulls without heating up the turbo first? Thats kinda what it looks like from the graph.
Old Jan 29, 2008 | 08:13 AM
  #1111
athenG's Avatar
athenG
we think it could be because he has the Nismo Y-pip, mid-pipe and Test Pipes... That is a lot of space to fill up. He's upgrading to an EBC so hopefully his spool will improve.
Old Jan 29, 2008 | 08:20 AM
  #1112
Ahsmo's Avatar
Ahsmo
Imakecopies
That is possible. The other thing was that SGP really didn't want to use the utec to control boost so that may play a factor. I am going to install my HKS EVC VI boost controller, center pipe, heat wrap, turbine blanket, and motordyne spacer and then have it all re-tuned this march.
I need to find someone around my area to give me a hand. Maybe the exhaust shop that I go to will let me use their lift...The dance with the jackstands and that side pipe is really a pain in the ***.
That added pipe diameter(added cross sectional area) will slow the exhaust gases down which will factor into the total work which the turbine gets out of the exhaust gases. However, this really is not a large factor, the difference at 3500 rpm is negligible. The equation for work out of a turbine is more impacted by the energy in the exhaust gases which is why I am so concerned about controlling heat in the exhaust piping. Larger exhausts on the cold side of the turbine help people by reducing back pressure on the outlet of the turbine which increases the work the turbine gets out of the exhaust gases. Larger piping on the hot side of the turbine may increase horsepower by helping in scavaging exhaust gases out of the engine...allowing the engine to breath more.
Old Jan 29, 2008 | 10:13 AM
  #1113
Fidanza's Avatar
Fidanza
https://my350z.com/forum/showthread....90#post5075190
STS compilation of videos and a great place to buy the kits from that you may not know about
Old Jan 29, 2008 | 11:26 AM
  #1114
Boozt's Avatar
Boozt
Here is a video of my STS Z at an autoX. At the time I was running 4-5 lbs boost...now running 9 lbs at peak.
http://s229.photobucket.com/albums/e...rent=Movie.flv
Old Jan 29, 2008 | 12:00 PM
  #1115
athenG's Avatar
athenG
that is the best STS video yet for our kit that really capture the sound. I have seen this video before and I'm glad that you finally posted. What have you done with the car and do you have any Dyno?
Old Jan 29, 2008 | 12:27 PM
  #1116
DanielW's Avatar
DanielW
Yeah thats a cool video for sure. Nice driving. Post some info about your setup if you don't mind. Since there's only a handfull of us on here who have it we're always looking for more info!!!
Old Jan 29, 2008 | 02:58 PM
  #1117
Fidanza's Avatar
Fidanza
group buy moved
https://my350z.com/forum/vendor-group-buys/331938-sts-rear-mounted-turbo-comp-and-group-buy.html
Old Jan 30, 2008 | 05:32 AM
  #1118
Boozt's Avatar
Boozt
Sorry for the delay. I'm running 9lbs a peak boost (4-5 in the video) with a manual boost controller. Mods include Light flywheel, 6 puck clutch and a tune. Gauges include Boost, AF wideband, and EGT (I track the car and AutoX quite a bit and like to know what the car is doing). Other mods are Hotchkis sways, Wilwood BBK (6 pot and 4 pot). I have recently added Koni with Eibachs and Forged NISMO's with RA1's (done after the video). No Dyno pulls yet....High cost for bragging rights and no good dyno's in my area.
Old Jan 30, 2008 | 07:11 AM
  #1119
Fidanza's Avatar
Fidanza
simply NICE
Old Jan 30, 2008 | 07:40 AM
  #1120
Sub zero's Avatar
Sub zero
thanks for giving those lotus a run for their money
