Performance Factory special!! JWT 700 kit dyno/pics inside
Old Aug 14, 2007 | 07:15 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
Default Performance Factory special!! JWT 700 kit dyno/pics inside
and you thought we only built drag cars...
this car is a very special car to us. we took in basically a stock car and made it into a track monster. the car will be fully caged and gutted out very soon to complete its mission. also the utec will be ditched to add a FCon VPro and make it an all around perfect car!!
the car was built from the ground up, AP racing BBK, full engine overhaul/rebuild from PF. new exhaust, JWT cams, springs, etc and of course the JWT 700 bb kit.
Engine specs are as follows...
Engine teardown and inspection
Performance Factory "Untouchable" pistons
Eagle rods
1/2 inch head studs
hks headgasket
JWT S2 cams
JWT springs shims
mild clean up on the head ports
rev up oil pump
rear coolant bypass mod
complete balance and blueprint of entire engine
then we added
JWT 700 kit
Full evo tt exhaust
clutchmaster fx400 clutch / flywheel
autometer nexus gauges, wideband, fuel pressure, boost/vac
CJ motorsports stage two return fuel system
denso injectors
utec engine management
Blitz SBC ID boost controller
All redline fluids throughout
AP Racing Full big brake kit
Car runs very very strong, since it is an 05 , we have had some issues with the utec, we have had this in the past on the 05s, some of them just dont act very smooth on the engauge/disengauge part and some part throttle stuff.
we are adding a full VPro setup later on this month....
This car hauls A$$!!!
here is the wastegate springs boost level at right under 10.6 pounds with 15 psi overlayed.
have fun ben!!! be safe with all that new power....
Old Aug 14, 2007 | 07:19 AM
doug's Avatar
doug
nice numbers.. equally nicer torque numbers
Old Aug 14, 2007 | 07:23 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
very nice install. I like the tq curve great for track usage.
What is the deal with 05s and utec. was this a rev-up motor?
Old Aug 14, 2007 | 07:25 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Very nice, I like how the hp stays relatively flat past 6000rpm's, well done guys!
Ten to Four Z's Avatar
Ten to Four Z
I don't think it's a REVUP look at the TAC. 6600RPM
Another aswome Car coming out of PF!!!
Old Aug 14, 2007 | 07:26 AM
Jay'Z's Avatar
Jay'Z
I like the gauges......
Old Aug 14, 2007 | 07:28 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
Good catch. I didnt even notice.
Old Aug 14, 2007 | 07:31 AM
abyss's Avatar
abyss
Awesome numbers and great looking car!
Me too. Very nice guages
Old Aug 14, 2007 | 07:50 AM
TENGAI's Avatar
TENGAI
+1. That plus the cam covers on the engine give it away... Very nice car and very nice numbers/curve. Congrats guys. Looks like another nasty fast car from the boys in FL
Old Aug 14, 2007 | 08:01 AM
booger's Avatar
booger
Nice job Jeremy !!!!!!!!!!!
Old Aug 14, 2007 | 08:06 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
WOW!! Very nice numbers. Good Job PF
Old Aug 14, 2007 | 08:10 AM
rcdash's Avatar
rcdash
That plus using JWT S2 cams gives it away
Beautiful build - nice job PF! I think that's one of the highest power JWT 700bb kits I've seen. Was that on pump gas? Aggressive vs. conservative timing? Also why no heat shield on the intake - superfluous?
Old Aug 14, 2007 | 08:21 AM
Audible Mayhem
My350z
car started out with a carbon fiber hood that we had to redo the intake and move it so it sat lower to miss the cut outs on the hood. we made a new coupling work so it angled it down. we decided we liked it better this way and left it even though the stock hood went back on.
we are actually getting rid of the one filter, adding twin intakes and redoing the whole intake piping as soon as the fcon goes in...
Old Aug 14, 2007 | 08:33 AM
taurran's Avatar
taurran
Very impresive #s, especially the torque!
I wonder who's car will be done next?
Old Aug 14, 2007 | 08:34 AM
roncfpz's Avatar
roncfpz
Nice work guys! Starting to see many more JWT 700 kits now.
Old Aug 14, 2007 | 08:41 AM
Quamen's Avatar
Quamen
Great work just keeps coming from the guys at Performance Factory!
Old Aug 14, 2007 | 08:43 AM
chris'smax's Avatar
chris'smax
i've heard from a inside source that yours is like 7 out
Chucky's Avatar
Chucky
Excellent work Jeremy. Sick #'s
Old Aug 14, 2007 | 08:46 AM
Philthy's Avatar
Philthy
Boost Junkie
Great job Jeremy! It's great to see more road racing setups... Post up some pics of the suspension setup...
Old Aug 14, 2007 | 08:55 AM
Audible Mayhem
My350z
guess who's next??!!
