Somethings wrong...
Old Aug 15, 2007 | 09:39 AM
IlirG's Avatar
IlirG
Default Somethings wrong...
Last week I went to start my car (05A G35 w/ Vortech, 440 FI, Walbro pump, 1/2 inch plenum spacer, headers, test pipes, td exhaust) and it would start, putter for a second or two then turn off, happened repeatedly. So brough it to my mechanic, he did a scan and it was coming up as a Airflow temperature senson problem, so after trying numerous things and finally changing out the MAF sensor the problem persists, and there are no other CEL codes or any codes for that matter coming up... Anyone have any idea WTF can be wrong???
Old Aug 15, 2007 | 09:50 AM
go-fast's Avatar
go-fast
check the fuel pump relay, to test it swap it out with another relay,i think a/c is the same.also see if the relay gets power for prime(key on)and running.
Old Aug 15, 2007 | 09:58 AM
JoeDirtPharmD's Avatar
JoeDirtPharmD
+1 - also check the fuse block behind the battery - I've blown the fuel relay fuse before (10A fuse, I believe) with the same symptoms as you've listed.
Old Aug 15, 2007 | 10:12 AM
IlirG's Avatar
IlirG
ok thanks guys, Ill try these!
Old Aug 15, 2007 | 04:10 PM
majik16106's Avatar
majik16106
Is there a banana in your tail pipe? that happened to me once and it was because there was a banana in my tail pipe. always happy to help
Paul
Old Aug 16, 2007 | 05:17 AM
IlirG's Avatar
IlirG
That would have to be one big f****n banana
Old Aug 16, 2007 | 06:01 AM
pure's Avatar
pure
That made me lol.
Old Aug 16, 2007 | 09:18 AM
theking's Avatar
theking
http://youtube.com/watch?v=aqzNFnEjr_c
Old Aug 16, 2007 | 05:44 PM
majik16106's Avatar
majik16106
are you making fun of my mad diagnostic skillz?
Old Aug 20, 2007 | 12:26 PM
IlirG's Avatar
IlirG
Still no luck
Old Aug 20, 2007 | 12:33 PM
GTM's Avatar
GTM
Vendor - Former Vendor
If you aren't too far from MRC maybe take the car over there and have them check it out, Julian is a good guy. It is really hard to diagnose problems over the internet
So this problem happened out of no where? No variables changed on the car before this?
-George
GT Motorsports
Old Aug 20, 2007 | 05:49 PM
majik16106's Avatar
majik16106
maybe its a REALLY small banana and you cant see it?
ok ill stop
Old Aug 20, 2007 | 07:33 PM
nomyth46's Avatar
nomyth46
does it run when you give it gas? or still just stumbles and cuts off
Old Aug 21, 2007 | 09:38 AM
IlirG's Avatar
IlirG
-George
GT Motorsports
Yeah was running fine, drove some where about 2 hours from my house, spent the night, went to turn the car on in the morning and bascially it would start, stay started for about 5 seconds idiling like crap then just shut off. Will not respond when I give it gas either. I have it at ATX motorsports right now, and they are pretty good, and have been trying everything to figure it out with no success. At this point Im ready to jusy go back stock and bring it to the dealer....
Old Aug 31, 2007 | 06:09 AM
IlirG's Avatar
IlirG
WTF? So a few days ago they call me and say that the Throttle Body needs to be replaced cause it seems that it was the problem. SO they changed it out, and the car IS running now, fine from 1000-3000RPM, but after 3000 it mis fires, and under 1000 it stumbles and turns off. This is so frustrating, I think its time to go back to stock and just send her to the dealer...
Old Aug 31, 2007 | 06:23 AM
go-fast's Avatar
go-fast
did you stop for gas?
Old Aug 31, 2007 | 06:43 AM
IlirG's Avatar
IlirG
Yeah put about 5 gallons before leaving
Old Aug 31, 2007 | 06:48 AM
Julian@MRC's Avatar
Julian@MRC
What do you have as far as engine management in it? I think Narvin had that car down here a while ago on our Dyno..Was running really lean up top.Did you ever put larger injectors in?
Old Aug 31, 2007 | 08:43 AM
go-fast's Avatar
go-fast
maybe you have skunked fuel.
Old Aug 31, 2007 | 08:47 AM
failsafe306's Avatar
failsafe306
It's happened to me before...
