APS TT Install: Oil Leak + Broken Wrench = F*cked
Old Aug 21, 2007 | 01:06 AM
jining's Avatar
jining
Default APS TT Install: Oil Leak + Broken Wrench = F*cked
Well well well... fired up my motor today, it turned on... that was a good sign, then my buddy says oh **** oil leak so we cut it off. Seems to be the LHS banjo bolt is leaking on the top of the turbo... wrong washer perhaps..(spectacular)
Anyways, upon dissasembly to take off my LHS turbo in order to see what caused the leak(wanting to commit suicide in the process), I have just broken the special little short skinny 12mm wrench that aps provided to unscrew the PITA bolts, so now I cannot remove the inner frontmost bolt that mounts the turbo to the exhaust manifold...
Any suggestions? I guess all I can do is find a skinny 12mm and cut it and bend it...
Damnit. Tuner date was tommorow (tuesday).. looks like im waiting. I knew things were going too smoothly.
Ok thanks for listening im tired.
Old Aug 21, 2007 | 04:58 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
we always pull the motor to do those kits.
you cant tq everything down to spec inside the car...
Old Aug 21, 2007 | 05:53 AM
Nismo350ZRT's Avatar
Nismo350ZRT
Dude, that sux! I had an oil gusher on the RHS side when I fired up my car. I forgot to tighten the bolt. I'm pretty sure I still have my skinny little wrench in the garage.
BTW are you planning to get tuned at CarbConn?
Old Aug 21, 2007 | 10:12 AM
failsafe306's Avatar
failsafe306
My aps supplied wrench broke halfway through the install...pos lol. Yeah man you'll just have to make your own wrench. That bolt you're stuck on just happens to be the hardest one on the entire kit to access too!
Old Aug 21, 2007 | 10:42 AM
TENGAI's Avatar
TENGAI
1. pull motor
2. problem solved
J/K Sorry to hear about the problems, but keep your head on. DIY installs are always a bit of a pain in the ***, but well worth the blood, sweat, and alchohol afterwards...
Old Aug 21, 2007 | 11:13 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I went and bought some cheap wrenches at harbor freight and ground the **** out of them....but even I did it with the motor out of the car.
Old Aug 21, 2007 | 12:04 PM
jining's Avatar
jining
I plan to get it tuned at Kito Autosport by Dominic, he tunes WRX's mainly, ive heard some good things and hes very familiar with utec.
My leak seemed like a gusher too... not sure how much oil could come out so fast, was like half a quart in 8-10 seconds.. it seems that the banjo bolt is tight from what I can feel in that tiny space lol.. im hoping its either loose or the washer is too big that we used... otherwise I have no idea where that oil came from. Theres not really any other place but that and the oil return line right? It definitely came from the top of the turbo somewhere.
Anyways... im off to sears to find a wrench. Damnit! it wasnt that hard to put on but to get it off seems much harder!
Old Aug 21, 2007 | 02:07 PM
justusS's Avatar
justusS
First starting up (specially after having oil out) is when you'll have some pretty high oil pressure. Doesn't take much of a leak for oil at 100+ psi to start coming out fast.
APS uses banjo for the oil send lines? Seems kinda wierd
I don't think it would have been as much if you had a leak on oil return. Have any pictures? or where you able to see roughly where it was coming from?
Old Aug 21, 2007 | 03:17 PM
Julian@MRC's Avatar
Julian@MRC
You can make that wrench out of an old 12mm and a gridning wheel.
Old Aug 21, 2007 | 03:29 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
also that banjo bolt is a weird european spec.. my kit was missing one and i had to get a machine shop to custome make one..
Old Aug 22, 2007 | 02:11 AM
jining's Avatar
jining
WELL!! After buying 50 dollars in 12mm wrenches from sears, I finally found one that works! Everything is back on and it RUNS!! Hallelujah!!
Warmed up with no leaks on the jack stands, I will do another warm up leak test tommorow morning and then its off to the tuner! :0)
Its running extremely lean at idle like 17-18.. which I thought makes no sense since I have 650cc injectors but its running on a 550cc APS Base Map... but either way it should get me 15 miles to the tuner tommorow.
And... the gauges arent working but... still.. it runs at least!
Whew. *relieved*
Old Aug 22, 2007 | 07:38 AM
failsafe306
Good to hear.
Old Aug 22, 2007 | 08:07 AM
justusS's Avatar
justusS
Sweet, another boosted VQ in WA....hit me up for a drive sometime when you get tuned
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
