Straight alcohol, not injection
Old Aug 21, 2007 | 09:17 AM
MacGuffin's Avatar
MacGuffin
Default Straight alcohol, not injection
Using alcohol as the fuel, not just as a fuel additive/supplement (as in water-methanol injection), has some real advantages in a FI application. Has anybody done a boosted VQ that runs on methanol, ethanol, or E85? Are any of the usual EMS even capable of handling these fuels, or would you have to go to something like MoTeC?
Old Aug 21, 2007 | 09:48 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Yes it does, but running meth is so rough you aren't going to see anyone running it in a street car. Having to flush the fuel system when you park it every night wouldn't be fun
Haltech would have no problem running a car on it, you are still just fueling and timing
Old Aug 21, 2007 | 10:17 AM
go-fast's Avatar
go-fast
if you duel fuel you can shut it down on gas ,would take only a very small tank and switch
Old Aug 21, 2007 | 10:18 AM
sentry65's Avatar
sentry65
the burninator
why not just get it all over with and go straight nitromethane?
Old Aug 21, 2007 | 10:25 AM
go-fast's Avatar
go-fast
with nitro the cops smell you down the street!you could always throw 10% on top for special nights.
Old Aug 21, 2007 | 10:42 AM
DMK's Avatar
DMK
E85 is definitely something I am interested in. Some Evo guys have already done it and are running great. I think all you need to change are injectors, fuel pump and lines. Great thing about E85 is that it is like running 110 Octane for your car and your car is SMOG exempt(Great for CA cars). Also cost less thank a gallon of Premium.
Old Aug 21, 2007 | 10:46 AM
TENGAI's Avatar
TENGAI
Hmmmm. E85 sounds promising. Anyone else with any info on this?
Old Aug 21, 2007 | 10:49 AM
go-fast's Avatar
go-fast
i wouldn't try to use it for economy,i think you will be dissapointed,fuel consumption goes way up.
Old Aug 21, 2007 | 10:50 AM
sentry65's Avatar
sentry65
the burninator
that would actually be a bad-*** thing to do
switch to E85, and use straight water injection instead of water/meth, and ultimately have a cooler, safer, higher power car
be emissions exempt, and be cleaner on the environment
right now I'm paying $6 a gallon for 101 octane race gas and doing a 50/50 mix of that with premium, so I'd end up saving money in the long run
Old Aug 21, 2007 | 10:52 AM
DMK's Avatar
DMK
Ya, fuel consumption will go up about 30%, but its around $2.00 a gallon for the fuel and it is like running 100+ octane fuel. I think its up to 105, not 110, my mistake. Also, I think Meth injection won't work with E85. Not too sure about water.
Old Aug 21, 2007 | 10:57 AM
sentry65's Avatar
sentry65
the burninator
why wouldn't it work? does evaporation in the intake not take place with an engine running E85? Does meth no longer burn? I'm skeptical about it not working
Old Aug 21, 2007 | 11:00 AM
go-fast's Avatar
go-fast
you will double the amount of fuel used
Old Aug 21, 2007 | 11:01 AM
sentry65's Avatar
sentry65
the burninator
I've read it's 30-42% more
this would suck as a track fuel like for road courses
you'd have to bring a million gallons with you to the track unless they start selling it there
Old Aug 21, 2007 | 11:04 AM
go-fast's Avatar
go-fast
it would work but youre combo would have to be so radical for it to be needed.
Old Aug 21, 2007 | 11:05 AM
MacGuffin's Avatar
MacGuffin
Fuel consumption would not go up about 30%.
It all depends on what baseline performance you are starting from, but ethanol's advantages in detonation resistance and latent heat/charge cooling mean that you can typically run both higher compression and closer to stoichiometric AFR than with gasoline. That means that fuel consumption would not be much more than with gasoline, and it could even be less if the gasoline configuration was high-boost with very rich AFR.
Take a look at the Saab BioPower. Not exactly a high-performance car, but it does give you some idea of what can be done with turbo ethanol.
If you look beyond the practical to current laboratory efforts, the combination of very high static compression ratio (around 19.5:1) with low boost (around 6 psi) and a lot of EGR (with its own flow control solenoid and intercooler) can actually get you fuel efficiency running on ethanol that rivals diesels.
Old Aug 21, 2007 | 11:09 AM
go-fast's Avatar
go-fast
yeah,alcohol is around 6 to 1 af.not sure what the offset of 15% gas has with e85
Old Aug 21, 2007 | 11:28 AM
MacGuffin's Avatar
MacGuffin
Just looking at AFR or btu/gallon doesn't tell anywhere near the whole story.
Let me give you a specific datapoint to illustrate -- not to claim that the same ratios would apply to a VQ running E85.
2005 Saab 9-3 had a 2.0l turbocharged engine burning unleaded gasoline. It produced 175 hp and 195 lb-ft. Fuel economy with the manual transmission was 23 mpg city, 34 mpg highway.
2007 Saab 9-3 BioPower has a 1.8l turbocharged engine burning E85 (it can also burn regular unleaded, but these numbers are for E85.) It produces 175 hp and 195 lb-ft (25 more hp and 18 more lb-ft than when burning gasoline.) Fuel economy with the manual transmission is 22 mpg city, 39 mpg highway.
Old Aug 21, 2007 | 11:33 AM
go-fast's Avatar
go-fast
2007 Saab 9-3 BioPower has a 1.8l turbocharged engine burning E85 (it can also burn regular unleaded, but these numbers are for E85.) It produces 175 hp and 195 lb-ft (25 more hp and 18 more lb-ft than when burning gasoline.) Fuel economy with the manual transmission is 27 mpg city, 47 mpg highway.
thats a great example but i was under the impression that this thread was about performance with alcohol not turning my car into a prius
Old Aug 21, 2007 | 11:44 AM
MacGuffin's Avatar
MacGuffin
Try to pay attention.
If anything, the comparative fuel economy numbers will be even better for high-performance turbo engines. You are likely running far richer AFR in a high-boost gasoline engine than does the 2.0l Saab. That is because you are using the excess gasoline not only for fuel, but also for charge cooling. Because of its latent heat advantage and inherently lower AFR, using ethanol or E85 means that you don't need to run a richer AFR than is needed for either max power or max efficiency (depending on which you are trying to achieve) just to achieve charge cooling -- you essentially get charge cooling for free with ethanol!
Old Aug 21, 2007 | 12:10 PM
DMK's Avatar
DMK
I got the 30% number off of a website, which states that it is around there. I am assuming they were referring to comparable A/F ratios with gasoline.
Evo guys running E85 stated that straight Meth won't work, I don't know the exact reason why.
