Any doubters of IC sprayers LOOKS ;)
Old Aug 22, 2007 | 03:11 PM
  #41
failsafe306's Avatar
failsafe306
:sniff-sniff:....I smell shit.
Old Aug 22, 2007 | 03:17 PM
  #42
IIQuickSilverII's Avatar
IIQuickSilverII
]:sniff-sniff:....I smell vrt
  #43
RA11325's Avatar
RA11325
Could someone clarify this for me: When you use an I/C sprayer, do you spray your entire run? Or do you just spray the I/C before your run?
Old Aug 22, 2007 | 03:22 PM
  #44
failsafe306
I would assume the entire run.
Old Aug 22, 2007 | 03:24 PM
  #45
IIQuickSilverII
+1 on that assumption
Old Aug 22, 2007 | 03:27 PM
  #46
failsafe306
What are you, my shadow or something? LOL j/k man
Old Aug 22, 2007 | 03:47 PM
  #47
denverinfiniti's Avatar
denverinfiniti
You only spray BEFORE the run.
Ok well heres the dyno. From looking at it more i COMPLETELY agree some nitrous entered the system how I'm not sure. I checked over the car today and all the connections are tight. ONLY thing I can think of is when the person sprayed the car was running with the big fan in front of it. So the charger must've sucked up some of the gas. The A/F was super lean at the start then level'd out.
Only thing I'm saying now is once the nitrous is gone its gone. The power should;ve dropped off after it was gone if that was a factor past the initial start of the pull. Cause there was defaintely somethin. The TQ and HP jumped big time at the beginning.
Sorry the quality's not that great
Old Aug 22, 2007 | 04:12 PM
  #48
Jay'Z's Avatar
Jay'Z
Nice!
Old Aug 22, 2007 | 04:20 PM
  #49
failsafe306
Makes me wonder if anyone is running a supercharger with nitrous on here, hmmm......
Old Aug 22, 2007 | 05:13 PM
  #50
denverinfiniti
^^ Well all I can say is I SWEAR, the nitrous was only used for about 5 seconds before the run. I stood next to the car and watched the guy run it, he never touched the button again. When I take the car back to have it tuned with the methanol running, I'll have him shut the car off before he sprays the IC. Then start the car again to make the run
Old Aug 22, 2007 | 06:24 PM
  #51
supra crazy's Avatar
supra crazy
There is no way in hell it will add 100whp
Originally Posted by denverinfiniti
At the beginning of the run the A/F was pretty lean but then it went down to mid tens. I know for a fact that the meth. was disconected cause I unhooked the line.
Umm you do realize how dumb that sounds....1 if you diconect the line after the pump it will spray meth all over your engine
2. If you disconect it befor the pump meth will leak out of the tank.
Old Aug 22, 2007 | 06:55 PM
  #52
denverinfiniti
^^Fair enough. Should've said I disconnected the power source to. Disconnected the feed line so that anything left we didnt get out of the tank wouldnt get sucked into the intake
Old Aug 22, 2007 | 07:48 PM
  #53
THE ROADSTER's Avatar
THE ROADSTER
Originally Posted by abyss
You and your tuner are on crack if you think cooling granted you 100+whp. If thats true I'm moving to Alaska.
mabey Antarctica, you will gain another 100whp.
Old Aug 22, 2007 | 08:55 PM
  #54
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
is VRT your tuner?
Old Aug 23, 2007 | 04:45 AM
  #55
Audible Mayhem's Avatar
Audible Mayhem
My350z
copied from my driver post...
NO WAY is this possible, i have cars on my dyno EVERY day. we have sprayed nitrous on and in every thing possible.
this is total BS, some is either A: really messing with you or B: trying to push a product here.
the MOST that we have ever seen, and this is coming from me personally, is a 15 whp gain when we emptied a 5lb bottle on the IC, engine, piping, turbos, EVERY part.
this is total BS and i will give you $1000 dollars if you can do the same thing on my dyno...
EDIT, it would take a 80 shot to give you those numbers sprayed directly into the intake. nitrous would cause and instant jump in tq and hp that you dont have. i think the guys were messing with you at the shop and gave you someone elses graph...
PLUS 460 hp on an AUTO on the stock block isnt happening either
__________________
Old Aug 23, 2007 | 04:50 AM
  #56
Alberto's Avatar
Alberto
Cranky FI Owner
What kind of dyno was this on? Looks like one of those interpolated dyno's, like Scotts Performance had (Dastek dyno) claiming 700+whp on standard APS kits, and we all know they are BS, unreliable and hamsters can spin those rollers to produce 500whp
Old Aug 23, 2007 | 05:02 AM
  #57
booger's Avatar
booger
This is basic proof you're BSing about the whole thing . With the nozzle used in the Snow Perf. W/M kit , nothing is going to get sucked into the intake from that nozzle . You were busted in your first statement about diconnecting it . And now busted again with your second statement . Give it up .
Old Aug 23, 2007 | 05:05 AM
  #58
Ruthless18x's Avatar
Ruthless18x
+1
Granted there is a dyno sheet, there is still no way, and the OP having FI should be smart enough to realize that is wrong.
  #59
booger's Avatar
booger
__________________
Besides the 460whp not happening...the 430trq. isnt happening even more .
Old Aug 23, 2007 | 06:28 AM
  #60
IIQuickSilverII
