False High Oil Pressure
Old Aug 23, 2007 | 07:26 AM
fklentz's Avatar
fklentz
Default False High Oil Pressure
On my way to work this morning as I got on the freeway I noticed that my oil PRESSURE was at 120 psi. I pulled over to the side, at ilde it was at 60. I shut the engine off and the gage needle indicated 0, I then turned ignition on without starting and it was showing 60 psi.
Do I have a bad sensor or is there a way to re-calibrate the gage? I tried a search but I'm doing this on my cellphone and won't have internet access until I get back home this evening. Anybody have an answer?
Thanks...
Old Aug 23, 2007 | 07:34 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It's probably a bad gauge...seen that many times before. Replacing the sensor will not fix the problem....its the gauge.
spicerds's Avatar
spicerds
I had the exact same problem. Bad sending unit.
Old Aug 23, 2007 | 07:43 AM
stormcrow's Avatar
stormcrow
sounds like your car had a heart attack. i would recommend an EKG...
Old Aug 23, 2007 | 08:00 AM
fklentz's Avatar
fklentz
Default Where is the oil sensor located?
Old Aug 23, 2007 | 08:27 AM
jwttz's Avatar
jwttz
this happened to me but it was a bad oil press. sending unit. you might want to check that out.
Old Aug 23, 2007 | 08:53 AM
Kenk2's Avatar
Kenk2
Professional
What is 'standard' oil pressure supposed to be? I actually have no idea.. Any difference between NA and FI?
Old Aug 23, 2007 | 09:36 AM
jpc350z's Avatar
jpc350z
+1 Same with me..
Old Aug 23, 2007 | 10:44 AM
fklentz's Avatar
fklentz
Mine is about 30 at idle and around 60 at 70 mph flat road, this is when fully warmed up, full fresh oil Mobil 1 0W40.
Old Aug 23, 2007 | 10:53 AM
fklentz's Avatar
fklentz
I hope it's just the sending unit, the dealer charged me $99.00 for a new one, I wonder if I got one for a VQ Altima or truck would it work, I know it would be way cheaper.
Old Aug 23, 2007 | 10:55 AM
go-fast's Avatar
go-fast
by the oil filter,2 wire plug
Old Aug 24, 2007 | 12:23 PM
fklentz's Avatar
fklentz
Smile
It was the sending unit, a little bit of a pain to change due to cooling water for turbo's.
Old Aug 24, 2007 | 12:33 PM
Kenk2's Avatar
Kenk2
Professional
Thanks man appreciate it..
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
