ForgedPerformace Greddy TT / JWT 850BB comparison Test
Old Aug 29, 2007 | 11:41 AM
  #101
doug's Avatar
doug
Originally Posted by D350Z10
That is a HUGE advantage how much was the kit easy to install? Thanks Doug
https://my350z.com/forum/showthread....231581&page=15
Old Aug 29, 2007 | 11:44 AM
  #102
Alberto's Avatar
Alberto
Cranky FI Owner
I posted pics and a review of the kit-nice to know you read the thread
Old Aug 29, 2007 | 11:56 AM
  #103
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Originally Posted by TENGAI
My bet's on 'Berto if both run @ 15psi...
Take a look at the two dyno plots:
He's got him through every RPM point. The trend continues all the way to 6k RPM when they both hover at about 530 whp. The 3.3 "might" be a factor in slowing him down a notch, but I wouldn't bet the farm on it. Either way, it should be close.
Alberto @ 15psi
eagletangreen
Dynojet same STD correction as DD less than 5 hours after DD tune-13 and 15psi runs
Dont compare the those dynoes, they are differnt as the DD has much more load, use the Dj we both got on!
When he dynoed he was on the old DD, when I dynoes it was on the new all wheel drive DD on shootout mode so there my be a little diffrence. This was just brought up to me. It gets better and better.
Also took the brake fuse out and guess what? Brake boost baby!
Also I know this might be a small factor but it was no $hit 103 degrees outside much more in side, when I dynoed.
Old Aug 29, 2007 | 12:05 PM
  #104
dutchboy's Avatar
dutchboy
Originally Posted by Alberto
As you can see that 3.3FD is not really slowing me down, as I hit 4th shortly after hitting it
It most definitely doesn't look to be slowing you down, cool vid.
Old Aug 29, 2007 | 12:07 PM
  #105
bboypuertoroc's Avatar
bboypuertoroc
+1 on not comparing dyno numbers. Only thing that's really comparable is the power curve, not the actual numbers.
Old Aug 29, 2007 | 12:11 PM
  #106
doug's Avatar
doug
i could have sworn someone tried that and it didn't work
Old Aug 29, 2007 | 12:13 PM
  #107
eagletanggreen
Got Track!!!!!
I have not tried it above 40mph. I go check later
I Pm KP to see if he can overnight me one!
  #108
Alberto's Avatar
Alberto
Cranky FI Owner
Luie-if you go down the "airstrip" with that fuse pulled you wont have brake lights, I dont recommend it...I dont plan on brake boosting every race I want to do some without and 2 with, I wont brake boost you to death dont worry...
Old Aug 29, 2007 | 12:15 PM
  #109
eagletanggreen
Got Track!!!!!
Yeah your right safety first. How long did it take you to wire up?
Old Aug 29, 2007 | 12:23 PM
  #110
rcdash's Avatar
rcdash
You can just cut the "right" wire and it will do the same thing. You will eventually throw a CEL code, but if you have a way to reset it then no biggie.
(or if you put on quick disconnects so it's easy to reconnect - OR you put a manual switch on that line) - it will work as well... The KP module allows you to not have to think about it and have it always active.
I think if you can both brake boost, it will make things very interesting...
Old Aug 29, 2007 | 12:27 PM
  #111
Alberto's Avatar
Alberto
Cranky FI Owner
Took about 10 min
Old Aug 29, 2007 | 12:40 PM
  #112
eagletanggreen
Got Track!!!!!
Took about 10 min
Very nice!
Old Aug 29, 2007 | 01:29 PM
  #113
eagletanggreen
Got Track!!!!!
HA HA HA!
Brake boost mod on the way (next day air!)
Thanks! KPtechnologies
Got to keep it even
We need to make this a "Pay per View"
Old Aug 29, 2007 | 02:03 PM
  #114
Alberto's Avatar
Alberto
Cranky FI Owner
LMAO-the things Luie will do to "keep up"
Brake boost module $40
Next day air $20
New twins set-up $
Look on Luie's face after the race = PRICELESS
Sorry I just had to...
Old Aug 29, 2007 | 02:07 PM
  #115
diwun67's Avatar
diwun67
And the poop talk begins
Old Aug 29, 2007 | 02:08 PM
  #116
Alberto's Avatar
Alberto
Cranky FI Owner
Default j/k
Gotta sling some poop to make Luie grab those gears like he should
Now for saying that my punishment will be that I lose by 4 cars
Old Aug 29, 2007 | 02:11 PM
  #117
mario23's Avatar
mario23
Oh you know I'm subscribing!!!
Have fun guys...
Old Aug 29, 2007 | 02:22 PM
  #118
bboypuertoroc
There's worse things as far as punishment is concerned.
Tony (will not say)
  #119
superchargedg's Avatar
superchargedg
Damn Noobs
Iam def going to be there for this one,im cutting out of work early as soon as bert lets me know when and where.
  #120
Alberto's Avatar
Alberto
Cranky FI Owner
You and your man love in jail thoughts...
