TXS Boost control solenoid clicking at idle.......
Old Sep 3, 2007 | 07:49 AM
QuadCam's Avatar
QuadCam
Default TXS Boost control solenoid clicking at idle.......
I noticed some sort of clicking coming from under my hood last night when I was pulling into the garage. I popped the hood and whipped out my high-tech listening device (length of vacuum hose shoved into my ear. )
What I deiscovered was the TXS BCS was cycling. it was clicking away and you could hear the air coming out of the vent port.
This doesn't seem right at all! THE BCS shouldn't be doing anything at idle, I wouldn't think. Why would the UTEC be pulsing the ground trigger at idle or other non-boost conditions?
anyone who has one, will you check yours?
thanks,
Andrew
Old Sep 3, 2007 | 08:21 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The ones we have done...all pulse at idle.
Old Sep 3, 2007 | 08:24 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
are you sure its not a loose bolt in your head rattling around andrew??
Old Sep 3, 2007 | 08:33 AM
QuadCam's Avatar
QuadCam
that is a serious possibility!
Old Sep 3, 2007 | 08:34 AM
QuadCam's Avatar
QuadCam
hmmm.....I've never noticed it before. Maybe, it's been doing that all along.
Old Sep 3, 2007 | 09:20 AM
Sharif@Forged
Forged Performance
yeah, I noticed it right away when we installed them...sounded like valve tap or something. The solenoid was working correctly, and we had no issues, so I didnt even bother checking it out further.
Old Sep 3, 2007 | 09:44 AM
redline350ZZ's Avatar
redline350ZZ
Do these things fail open or shut? And open is good right?
Old Sep 3, 2007 | 09:57 AM
QuadCam's Avatar
QuadCam
it should fail in the shut position, which is what you'd want. Shut would not allow any boost signal to the top wastegate ports.
Old Sep 3, 2007 | 10:00 AM
redline350ZZ
I thought you would want it to send signal so the WG opens?
Old Sep 3, 2007 | 10:08 AM
QuadCam's Avatar
QuadCam
the side port on the wastegate is the port that opens the wastegate under boost. the boost lines going to the side ports come before the BCS. if the BCS were to fail in the open position, your have boost sent to the top and side ports, eseentially cancelling eachother out...and the wastegate would be held closed due to the internal wastegate spring. Can you say OVERBOOST!?!?!?!
Old Sep 3, 2007 | 10:24 AM
redline350ZZ
I guess I'm a little confused, normally with no BCS the Turbo will send a reference of what it is putting out to the WG. A BSC modifies that signal to keep the WG closed longer so that you can permit more exhaust to go to the Turbo and achieve more power right? So I would think that if the BCS were fully open it would be like it was not even there and the WG would perform based on the spring inside it.
Or do you have 2 lines hooked up to the WG with a BCS?
Old Sep 3, 2007 | 10:33 AM
redline350ZZ
I see a picture from the old MRC thread and I think I got it now.
Old Sep 3, 2007 | 10:59 AM
QuadCam's Avatar
QuadCam
I am utilizing both ports on the wastegate.
you are thinking of a bleeder type boost controller which lowers the boost signal send to the side port of the wastegate.
Old Sep 3, 2007 | 11:05 AM
Sharif@Forged
Forged Performance
+1...
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
