Vortech w/3.12 pulley only 6lbs?
Old Sep 10, 2007 | 06:22 PM
G35asian's Avatar
G35asian
Default Vortech w/3.12 pulley only 6lbs?
Whats up everyone, I got a situation here. To start, I just installed my vortech kit this past Friday and everything has been going smoothly for the most part. For reference, here is my setup:
- Stock block
- Vortech tuner kit with 3.12 pulley
- Utec with tuner reg wideband
- deatschwerks 650cc injectors
- walbro 255lph fuel pump
- megan racing headers
- intense resonated test pipes
- hks hi-power exhaust
- aps tallboy plenum
Whats happening here is that I am only making a little more then 6 lbs at redline. I know that with the 3.12 pulley I should be making at least 8lbs. So far I have done a boost leak test (connected a capped coupler with an air compressor connection to pressurize the motor) that showed no leaks and made sure the belt was tight so there is no slip. What else could it be? Any suggestions will help.
Thanks
Old Sep 10, 2007 | 06:33 PM
jksstar's Avatar
jksstar
I don't have a Vortech but from what I have seen posted on here that mods like headers, test pipes and so on, will make less boost on the Vortech.
Old Sep 10, 2007 | 06:36 PM
jksstar's Avatar
jksstar
Originally Posted by sentry65
- as you add higher flowing exhaust/headers/cats or test pipes/cams/plenum/etc the boost pressure will go down but power will go up. You're interested in power, not the psi number. Lower psi IMO is healthier on the engine than really high psi. As you add higher flowing parts, that will shift the power in the powerband to reduce low end power but increase high end power.
https://my350z.com/forum/showthread....59#post3746559
Old Sep 10, 2007 | 06:47 PM
G35asian's Avatar
G35asian
Yeah, I understand that, but I know for sure it is not suppose to drop it 2-3 psi. Maybe 1 psi max.
Old Sep 10, 2007 | 06:58 PM
Nexx's Avatar
Nexx
looks like you live in arizona too, you get less boost with superchargers in hotter weather.
Old Sep 10, 2007 | 07:04 PM
booger's Avatar
booger
What kind of boost gauge do you have ? Have you put it on a dyno to compare your gauge with the one on the dyno ?
Your right 6psi is to low...I could see it on the stock pulley . When you preasurized the system ....did you include the BOV and intercooler ?
Old Sep 10, 2007 | 07:13 PM
Triji's Avatar
Triji
I am in AZ as well and just went for a drive. It was still 102 outside and I boosted to 8.4 w/ 3.12, HKS, SSV, stock headers, Kinetix RTP's, stock FMU, and SS box. I see as much as 8.8 when I really get on it.
I'm 5AT... He is 6MT
P.S. my damn fuel pump's still running... LOL... Battery disconnected atm.
Old Sep 10, 2007 | 07:26 PM
Blackbird CPV35's Avatar
Blackbird CPV35
turn your car off and read the boost gage on the utec. Mine says -1 psi with the car off because the calibration is off, and I thought it was a boost leak for about 2 months
Old Sep 10, 2007 | 11:43 PM
G35asian's Avatar
G35asian
Alright guys, I figured it out. I did another boost leak test and I had a leak from the MAF sensor housing. Also, my belt wasn't as tight as it could be. So I fixed the MAF housing with some paper gasket and tightened the belt. I was never so happy to see 8 psi . I am averaging right around 8 psi right now which is where it needs to be since its hot out and since I have a full header back. Now off to the dyno in the morning! I'll post up some numbers when I get back.
Thanks for the help!
Old Sep 11, 2007 | 04:58 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
congrats on figuring that out!! i hate boost leaks..
Old Sep 11, 2007 | 09:25 AM
Triji's Avatar
Triji
Congrats Julian!
Looking forward to see what you will be putting down!
You tuning at UMS right?
Old Sep 11, 2007 | 11:09 AM
FranksBAG's Avatar
FranksBAG
i think vortech has been having welding problems. My vortech also had a boost leak found it when i engaged my meth injection. Where the hard piping meets the the MAF sensor the weld doesnt let the connection become tight. remedy take off piping and grind weld boost leak fixed. I hope
Old Sep 11, 2007 | 12:09 PM
booger's Avatar
booger
Hey Frank
How about making a post about this Vortech car you have . So far I have read that it has the 2,62 pulley with a wastegate and elec boost controler . And now W/M injection . How about showing us this car ????????
Old Sep 12, 2007 | 04:31 AM
jpc350z's Avatar
jpc350z
Originally Posted by booger
Hey Frank
+1
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
