Boost and fuel issue (vortech)
Old Sep 11, 2007 | 09:33 AM
jaspendlove's Avatar
jaspendlove
Default Boost and fuel issue (vortech)
I read the vortech posting and couldn't seem to find the answer. I have seems some ideas that I will need to do like:
Test the VAC lines
I need to change COG tensioner pulley to the correct set up
Make sure the gauge is reading right
Here is the issue:
I cant seem to get it past 5lbs with the 3.12 pulley. When I get to the point of redlining the rpm's, the fuel pressure gauge peaks out at 100 psi. Any suggestions on how to get the 8lbs and this fuel psi crap? Any other suggestions would be helpful so I can get them done all at once would be great.
This is what I have done to the car:
Voretch SC-3.12 pulley
750cc injectors
Random Tech high flow cats
Vibrant exhaust
Thanks
Old Sep 11, 2007 | 09:38 AM
jpc350z's Avatar
jpc350z
Test the VAC lines
Here is the issue:
750cc injectors
Vibrant exhaust
Thanks
What are you getting on dyno power wise? A/F ? An open exhaust will lower your Boost but up your power..
Old Sep 11, 2007 | 09:40 AM
iStan's Avatar
iStan
ZR
Check for leaks at the couplers?
Old Sep 11, 2007 | 09:50 AM
jaspendlove
Last time I did it, I was at 330rhp. Thats before the cats and the 3.12 pulley. I also have the Utec, but not installed yet.
Old Sep 11, 2007 | 10:15 AM
04treefiddy's Avatar
04treefiddy
to resolve some of the fp issues, do the turbonetics mod. Go to there site and drill out the regulator in the pump assembly and remove the yellow piece.
Are you still using the stock fuel pump? If so ditch it and get a walbro. Then you can remove the aux pump. and run the walbro and fmu. If you are going to use the utec, you can remove the fmu too.
Old Sep 11, 2007 | 10:29 AM
jpc350z's Avatar
jpc350z
The FMU is not necessary when you remove the Aux fuel pump...It feeds it..
Old Sep 11, 2007 | 10:49 AM
jaspendlove
I have the walbro. Just not installed yet. I will get it in real soon through
Old Sep 11, 2007 | 11:18 AM
Matt at PF's Avatar
Matt at PF
Vendor - Former Vendor
After you fix the fuel system install the utec and get a good tune Those injectors are rather large...
Old Sep 11, 2007 | 07:47 PM
jaspendlove
Anybody know of a good place here in Utah for a tune n the Utec?
350z82
Oct 1, 2015 06:25 PM
