name that vortech issue/sound....
Old Sep 12, 2007 | 11:04 AM
jpc350z's Avatar
jpc350z
Originally Posted by CUxtopher
sound goes from a chatter to a whine/whirr undle normal driving. Also, bracket seems to have a vibration to it.
Any luck locating the source? The bracket vib could be energy going into it from the source..
Old Sep 12, 2007 | 11:25 AM
DMK's Avatar
DMK
Interesting how these bearings are failing on a consistent basis for Vortechs. Mine had less than 3k miles on it when I had to replace it.
Old Sep 12, 2007 | 11:28 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
did vortech not cover it? Link to your thread?
Also, did you watch the third video in my links? Our startups sound similar. I didnt rev mine much. Did you happen to drive with yours any?
Old Sep 12, 2007 | 11:32 AM
DMK's Avatar
DMK
They want you to send the unit back to them for analysis. Just order the two bearings and replace it yourself. I didn't want to wait for them to get it, analyze it and send it back to me. Probably 2-3 week minimum. I posted up a link to a semi-DIY a while ago, but the install is straight forward if you look at it. Just remove the bolts surrounding the jackshaft and take it out.
http://g35driver.com/forums/showthread.php?t=110392
Old Sep 12, 2007 | 11:39 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Damnn. 2-3 weeks is weaksauce!
Going to read the install and see what i think.
Are your bearings doing fine now?
Old Sep 12, 2007 | 11:41 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
One thing tho, my system gets real quite if you take the cog belt off. I figure its because the bearings are under minimal load. The guy from g35 mentions there was still a noise.
Video 2 from my first post is with the cog off. Nice and quiet
Old Sep 12, 2007 | 11:47 AM
DMK's Avatar
DMK
Mine had no noise when I took the cog belt off.
Old Sep 12, 2007 | 11:49 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Ah, so it still could be the jackshaft.
Any pics of your old bearings? He said the oil turned to a sludge, id like to see some pics of that up close.
Old Sep 12, 2007 | 12:41 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Ordered the bearings and washer today. roughly 45 bucks shipped. Will install next weekend.
Anyone have the part number for the cog tensioner pulley? Think i could get a replacement at napa?
Old Sep 12, 2007 | 08:52 PM
Mr_pharmD's Avatar
Mr_pharmD
which bearings are u guys reffering to? the 3 idler pulley on the jackshalf?
Old Sep 13, 2007 | 04:39 AM
jpc350z's Avatar
jpc350z
I believe the cog tensioner pulley # is Dayco 89003 (smooth idler).. NAPA supposed to have..
Old Sep 13, 2007 | 05:12 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
the ones in the cog pulley. Its the jackshaft, the only shaft that has a 6rib pulley on one side of the bracket and the cog pulley on the other side.
Old Sep 13, 2007 | 06:46 AM
Mr_pharmD's Avatar
Mr_pharmD
so if i replace the cog pulley it will come with the bearings or will i have to order that seperately? Or is the cog pulley ok and only the bearing in the jackshaft needs to be replace. WHere did u purchase yours from?
Just to be clear... is it the cog pulley that u replaced or is it the one next to it that's smooth?
Old Sep 13, 2007 | 06:55 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
im just going to replace the bearings. Yes, that is the pulley im talking about.
I ordered mine from vortech. Call them and ask because i dont know the answer to the question.
Old Sep 17, 2007 | 06:50 PM
G35asian's Avatar
G35asian
Sounds to me like the bearings in the actual supercharger housing has gone out. This just happened to me a couple days ago with only 300 miles on the kit . That screeching noise is the turbine wheel rubbing on the compressor housing. I bet if you take off the filter you can see the scoring from the wheel on the housing. I removed my supercharger yesterday and will be sending it to vortech tomorrow to be repaired under warranty. I guess this is just a part of the FI game . Let me know if you have any questions.
Old Sep 17, 2007 | 06:56 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
got any vids?
Old Sep 17, 2007 | 09:17 PM
Triji's Avatar
Triji
Yeah, I saw G35Asian's blower and when you turn the pulley on the back end you could hear the metal scraping and the bearings rattling around in the blower itself... I can't believe that happened after 300 miles... I have 40K on my blower and she has been a tank!
I would check your blower as well before just getting into the jackshaft bearings.
Old Sep 17, 2007 | 10:01 PM
  #38
G35asian's Avatar
G35asian
Yeah, once you remove the cog belt, spin the cog pulley on the supercharger itself and listen for any noises. It should spin freely with no noises. If not, then your supercharger went out like mine .
Old Sep 18, 2007 | 06:35 AM
  #39
ML2000's Avatar
ML2000
Man, sorry to hear that your having problems with your new vortech setup. Let me know if there is anything that I can do.
Matt
Old Sep 18, 2007 | 06:45 AM
  #40
Cux350z's Avatar
Cux350z
hatersgonnahate
I think youre right, sadly. My vortech made noises from day one, i even spun it a bit before i installed it.
Well, i went out and pulled the filter off and sure enough, the blades have some deformation on the tips and i could see from scrapped metal on the housing. Looks like ive got to send it back to vortech. I think this might have been a day one issue.
I still believe my bearings went out as well, they make the same noise as the other guys video.
What was your turn around time?
Thanks matt for the offer! Ill pm ya.
