Turbonetics (Open Wastegate)
Old Sep 20, 2007 | 04:54 PM
350zOnJuice's Avatar
350zOnJuice
Default Turbonetics (Open Wastegate) Dyno Results Posted!!!
I was thinking of running open wastegate on my turbonetics kit. What are the pros and cons and difficulty in doing/installing? I know I need some sort of blockoff plate, if so where can I buy it?
Thanks
Last edited by 350zOnJuice; Sep 25, 2007 at 01:49 PM. Reason: Dyno Results Posted!!!
Old Sep 20, 2007 | 04:56 PM
MIAPLAYA's Avatar
MIAPLAYA
Thanks
Well this has been discussed before but bottom line cons are its louder and you need to create some discharge pipe or point the wastegate in a direction where it won't melt everything around it when it opens. Pros, better flow from the wastegate, steadier boost pressure (supposedly), etc.
Old Sep 20, 2007 | 06:18 PM
350zOnJuice
^ does anyone have pics of the above on the turbonetics kit? I've been meaning do this but I want to have a couple more comments from you guys, let me know...
Old Sep 20, 2007 | 06:39 PM
MIAPLAYA's Avatar
MIAPLAYA
Jeremy at PF has done at least a few open dumps before. Perhaps you should contact him.
Old Sep 20, 2007 | 07:40 PM
Tekwon-V's Avatar
Tekwon-V
ugh, i do not recommend an open dump on a street car. it's just too damn loud.
Old Sep 20, 2007 | 08:31 PM
TayTaythatsme04's Avatar
TayTaythatsme04
DO IT ! ! ! I love scaring the S*** out of people as I drive down the street. You can actually use the TN piping and one of the pipes you can cut in half and then rotate it 180 and mount it. Then you have cut a little bigger opening in the under tray so that you dont melt the thing like MIA said.
Let me see if I have any pics. . . .
T
Old Sep 20, 2007 | 08:33 PM
Zridder19's Avatar
Zridder19
Hell yea I love my open dump!! You can scare the shzt outta people and it sounds badass!!
Old Sep 20, 2007 | 08:38 PM
TayTaythatsme04
here you go
Old Sep 21, 2007 | 02:34 AM
350zOnJuice
ok now I see somewhat what you did, now where do I get that pipe from... and correct me if Im wrong but the reason you use that pipe is to vent the hot air through a hole you open on the bottom black plastic not to melt them right???
o and thanks for the quick post of the pics and everyone elses responses
Old Sep 21, 2007 | 05:09 AM
TayTaythatsme04
that pipe is one from the TN kit. Its just cut in half. And Yes you have to make a hole in the undertray so that you dont melt thing.
T
Old Sep 21, 2007 | 06:41 AM
GQ 350z's Avatar
GQ 350z
Awesome! I wonder what Jeremy charges for the dump..
Old Sep 21, 2007 | 08:39 AM
350zOnJuice
Where is the TN pipe that I need to cut located? I would also assume that I need to gasket both the wastegate and the pipe I cut connected to the wastegate right.. and off topic 93 gas here is $3.20/gl what is everyone else pumping/price?
Old Sep 21, 2007 | 11:58 AM
redline350ZZ's Avatar
redline350ZZ
I wouldn't imagine it costing that much, heck after looking at it I could probably do it myself in a day.
Old Sep 21, 2007 | 12:39 PM
350zOnJuice
Im guessing this is the pipe you are referring to that you need to cut. Which is the pipe the wastegate exhaust goes connected to. What in the other end of this pipe and w.e. it is you need to block it off right?
The red line signifies where I think it would be cut judging from the picture posted
Old Sep 21, 2007 | 03:22 PM
VIZAGE's Avatar
VIZAGE
No, that's not the one you cut. That's the wastegate discharge pipe. That's the one you would put the block off plate on. First question to me would be, do you have the old style piping or the newer wastegate relocation pipe? I think that makes alot of difference if you have the old one.
So far as open dump. Go for it. I love it. Sounds so mean. I never get tired of it. I guess you'll have to make up your own opinion about it.
Old Sep 21, 2007 | 03:29 PM
350zOnJuice
Thanks, how can I find out if I have the old piping or new one? I have the graphite colored pipes not the silver ones if that makes any difference in determing if I have old ones or new ones. however from the above picture it does look like the one they cut. just my 2 cents...btw any audio on how the TN sounds with open dump?
Old Sep 21, 2007 | 04:09 PM
VIZAGE's Avatar
VIZAGE
See in the pic that TayTay posted. That's the old style piping for the turbine housing inlet. The wastesgate is mounted directly off the pipe. The newer pipe, know as the wastegate relocation is basically the same pipe with an added outlet that juts off that pipe to move the wasetgate further out. Then they also add another pipe, in the shape of a "U" that comes from the bottom the wastegate and attaches to the pipe you posted. That U pipe would be the one you cut and the pic you posted should be blocked off. This is how it's setup on my car. I hope this makes some since.
Now I could be a little wrong on the older style. And from what I can tell, you would have to turn the wastegate 180 degree's and attach a small downpipe to vent the hot gases away from other parts.
I'll be glad to discuss this with you further, to have a beter understanding. PM me your number and I'll call ya. I have free long distance.
Old Sep 21, 2007 | 04:11 PM
taurran's Avatar
taurran
Hopefully I'll have some vids of a REAL open dumped turbonetics setup soon.
Old Sep 21, 2007 | 04:15 PM
VIZAGE's Avatar
VIZAGE
I hear that!
Old Sep 21, 2007 | 04:26 PM
diwun67's Avatar
diwun67
I use my open dump to scare people that cut me off
