I know there is so many on this, but not with the addition of this... help?
Old Sep 22, 2007 | 10:54 PM
uknowuhaetit's Avatar
uknowuhaetit
Default I know there is so many on this, but not with the addition of this... help?
Ok first off i have to say this site is the most handy tool in the world....thanks to everyone that pitches in. So on to the problem i have drove my Z and done many oil changes on it for quite some time, so why this comes up now idk? But i was doing the normal oil change on it 5 quarts and a filter, changed the procharger oil. had it all ready for the show next week now i can't go.... I drove it to work a day before the show and all of a sudden when i get ready to leave for lunch i started it and smoke started pouring out the exaust white smoke, and then it quit hasn't done it again since then and now my oil pressure is running 120 when i get on it to boost. and also high at idel. So i figure okay maybe the sending unit went bad, but that doesn't explain why the smoke poured out of the exaust hardcore for like 4 min and then cleared up? no cel no anything out of the ordinary except that oil pressure? Any suggestions? Was it a cat maybe>? or bad plugs? to rich? it is spitting black specs on the ground when i rev it.
Old Sep 22, 2007 | 11:41 PM
kevin8086's Avatar
kevin8086
i would like to know about the black soot it spits on the ground also, mine does it at idle
Old Sep 23, 2007 | 07:31 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
May car does it also. Did it with my old set up and does it with my new set up. Very normal, I belive its built up condensation inside the pipes (I maybe wrong).
Old Sep 23, 2007 | 07:40 AM
Zivman's Avatar
Zivman
my guess is that your headgaskets are toast. The smoke pouring out the exhaust is coolant. You are seeing high oil pressure because of the coolant being mixed with the oil which has added too your oil level.
drop your oil again and see if it is milky
Old Sep 23, 2007 | 07:42 AM
westpak's Avatar
westpak
SFZCC
^ +1
Old Sep 23, 2007 | 07:57 AM
uknowuhaetit
will do, if so.... what does getting those replace run???
Old Sep 23, 2007 | 08:07 AM
Zivman's Avatar
Zivman
that basically = a full rebuild; so thousands of dollars
A lot of labor. Motor needs to be pulled, all timing components, heads and cams need to be removed. Heads checked and most likely machined, block checked for straightness, and on and on
First make sure you know what the problem is before worrying about how much it's going to cost
Old Sep 23, 2007 | 08:57 AM
Jay'Z's Avatar
Jay'Z
Originally Posted by 98MODMTR
My guess is, once you find out the problem, uknowuhaetit
Wow, that is ironic..
Old Sep 23, 2007 | 09:21 AM
diwun67's Avatar
diwun67
white smoke is definitely coolant, I'd say it's a blown headgasket
Old Sep 23, 2007 | 11:12 AM
uknowuhaetit
thats pretty funny^^^^ yeah oh well i had a good time with it..
Old Sep 23, 2007 | 12:42 PM
VIZAGE's Avatar
VIZAGE
I have the black soot also lying in my garage floor. I take it as normal.
Old Sep 23, 2007 | 09:38 PM
Weqster's Avatar
Weqster
Water will drop oil pressure. thicker oil increased oil pressure because its harder to push through the oil galleries.
headgaskets dont just decide to leak and then unleak. If a headgasket was blown and causing smoking, the smoke will not stop. As the engine warms up, the clearences increase (in terms of gasket leaks) and more smoke will appear.
<guess>
My guess is possibly a pro-charger related issue. u may have used the wrong oil/diff oil and cold oil = higher then normal oil pressure = oil in exhaust and slight white smoking.
Do u have any other symptoms? Anything unusual during the oil change? High oil pressure would mean u used a fairly thick oil.. thicker then normal?
Weqster's Avatar
Weqster
black soot is condensation/fuel + carbon deposits blown from the exhaust. usually during startup. nothing to be worried about.
Old Sep 24, 2007 | 03:44 AM
rcdash's Avatar
rcdash
I've had fuel come out as white smoke - when my injectors were stuck open on one bank due to a faulty utec. Just giving you some hope. The rising oil pressure doesn't sound good...
ablaine
Nov 29, 2016 10:13 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
nanotech
Oct 2, 2015 05:02 AM
