Vortech Guys Help! *With PIX*
Old Sep 24, 2007 | 10:11 AM
HEGONE's Avatar
HEGONE
Default Vortech Guys Help! *With PIX*
Hey guys, as some of you may know, I got my Vortech SC installed about 3 weeks back. I posted a week back with an issue I was having with my belt screeching. I got that fixed with a new Gates belt and have no problem until this morning after work when I turned on my car.
The new problem is that I HAVE A HORRIBLE FUEL LEAK!! Its coming from the aux Fuel pump that I got with the vortech Kit. Here are some pictures I took.
I haven't driven it hard at all. I turned it on after work and when I left the parking lot I could smell gas. I then pulled over and took a look underneath and saw FUEL SPILLING OUT LIKE CRAZY. It seemed like it was spurting out from the in and out line of the fuel pump! I had a half a tank of fuel and after driving about .5 miles I was all out of fuel!!! My wideband A/F gauge said I was running insanely rich (7.4 A/F) when I first smelled it, even at idle it wouldn't change from 7.4-7.6 A/F... Then when I got into the gas station it was just sitting totally lean (20.9 A/F) and it would change! I have no idea how this would happen. I then pulled into a gasstation and had to call a flatbed to get my car back home! It was a very bad day for me today and I have no answer to any of my questions. Could this be the fuel pump, fuel lines??? Any info is helpful! Thanks
~Manny
Old Sep 24, 2007 | 11:41 AM
eez's Avatar
eez
I would check the lines for cuts/holes and maybe tighten down the clamps.
Check the connections going in and out of the FMU I had one pop off and fuel spewed everywhere (passenger side fuel rail). I know the aux pump is on the driver side, but I guess it could be running down outside of the lines.
I had to zip tie my FMU connections together so they wouldn't disconnect.
BTW maybe you should post more pics hehe j/k
Old Sep 24, 2007 | 11:46 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
thats a lot of pictures, i forgot what i was looking for...
Old Sep 24, 2007 | 12:10 PM
DMK's Avatar
DMK
Make sure the clamps on both ends are tight. And look for cuts in the hoses.
Old Sep 26, 2007 | 07:36 PM
HEGONE's Avatar
HEGONE
FIXED! Thanks Guys!
Old Sep 27, 2007 | 01:14 AM
abyss's Avatar
abyss
Soo...what was the problem?
Old Sep 27, 2007 | 02:02 AM
Jay'Z's Avatar
Jay'Z
He tightened it up..
Old Sep 27, 2007 | 06:41 AM
THE TECH's Avatar
THE TECH
More than likely. It's usually the simplest fixes.
Old Sep 28, 2007 | 12:37 AM
HEGONE's Avatar
HEGONE
The fuel line was pinched up against a bolt. Rerouted the line with a new hose and everything is perfect. Thanks felloz!
Obadabot
Jun 18, 2023 11:31 PM
Alexreyes
Sep 30, 2015 11:30 PM
