Z Not Sounding Right. Couple Questions
Old Sep 28, 2007 | 03:12 PM
Barzten1's Avatar
Barzten1
Default Z Not Sounding Right. Couple Questions
First I noticed my Z was sounding like it was putting a little last week. Wasnt sure because I havent driven it in a few weeks and maybe I was hearing things. Then a friend mentioned it sounded different too out of the blue. Then today it was really noticable. The difference sounds like someone took of the air box on a stock car. Z is still boosting but Im not sure where to start looking.
Im thinking an IC pipe might be loose. Possible a crack in the headers (they are Stillen and it sounds like its coming from there). Also, what should my boost guage read when car is off, key is in and still off and when its started? Thanks for any insight.
Old Sep 28, 2007 | 03:36 PM
Ep3's Avatar
Ep3
does the engine sound off for example bad plugs.. different exhaust note or you have "extra noise" rattle or leak of some kind?
Old Sep 28, 2007 | 03:42 PM
Barzten1's Avatar
Barzten1
No rattling sound. Different exhaust note but more like its soming from the intake. The plugs should be ok. Changed them about 8 months ago and don't pile the miles on my Z. But I have been running rich for some time now.
Old Sep 28, 2007 | 03:46 PM
Ep3's Avatar
Ep3
do a compression test.. make sure all your cylinders are working properly? if you think its intake related check those pipes and clamps
Old Sep 28, 2007 | 03:54 PM
Barzten1's Avatar
Barzten1
Just took off the blower belt and it still doesnt sound right. Sounds like the intake has a deeper throatier sound.
Barzten1's Avatar
Barzten1
How do you run a compression test?
Old Sep 28, 2007 | 03:58 PM
Ep3's Avatar
Ep3
get a comp tester, heres a little info i found quick, oil and coolant looking good?
http://www.aa1car.com/library/compression.htm
Old Sep 28, 2007 | 04:21 PM
Barzten1's Avatar
Barzten1
Dropping it off at Dr Todds in the morning for some diagnostics. Also if everything is ok he's going to tune for the 2.87 pully.
Old Sep 28, 2007 | 04:46 PM
Barzten1's Avatar
Barzten1
I think its the blow off valve. Had my wife give it gas while I had my hand on it. I think its supposed to close when you give it gas. It stays open.
Old Sep 28, 2007 | 05:09 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Also check for exhaust leak. This could make the car suddenly louder as well...
Old Sep 28, 2007 | 05:11 PM
Ep3's Avatar
Ep3
well good luck hope its something minor!!
Old Sep 29, 2007 | 03:43 AM
Barzten1's Avatar
Barzten1
Got under the car to swap the bov and saw my HFC was cracked right on the weld.
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
codek
Sep 28, 2015 03:03 AM
samansharif
Sep 25, 2015 12:31 PM
