Insanely High Fuel Pressure
Old Oct 1, 2007 | 07:29 AM
HoldThisForMe's Avatar
HoldThisForMe
Default Insanely High Fuel Pressure
Help! hovers around 90 psi at idle! I cant boost at all because it goes extremely lean...
At idle afr's around 14.5 so thats normal but god the fp is 90psi!!!
Could it be the afr going bad? fuel pump going bad?
I have the AAM fuel return system
440cc injectors
walbro 255
greddy tt kit
when unplugging the vaccum from afr there is really no change in pressure.
could that much pressure actually cause my lean condition under boost???
im totally out of ideas here
Old Oct 1, 2007 | 07:36 AM
Quamen's Avatar
Quamen
Have you tried adjusting the FPR?
While I am sure that the diaphragm in the aeromotive can handle 90psi it wasn't intended for it like a Kinsler.
Old Oct 1, 2007 | 07:45 AM
HoldThisForMe
Yea i have tried but you can take the bolt completely off and it does nothing
Old Oct 1, 2007 | 07:53 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
the gauge is messed up..
Quamen's Avatar
Quamen
Have you checked for kinks in your return line?
Old Oct 1, 2007 | 07:55 AM
HoldThisForMe
Audible...thats possible but how often does a gauge like that go out?
no kinks in the lines.
I still understand why im so lean tho...you would think with that much pressure id have to much fuel.
Old Oct 1, 2007 | 08:01 AM
Quamen's Avatar
Quamen
I would have to agree with Audible that your gauge may be bad if you are running lean which would seem like not enough fuel pressure.
Old Oct 1, 2007 | 08:04 AM
HoldThisForMe
I'll see if i can swap regulators and see what happens.
Old Oct 1, 2007 | 08:26 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
If your FP is that high, assuming you are using a Walbro then it may not be able to flow enough fuel for your setup:
@ 40psi - 60gph ~720bhp
@ 90psi - 37gph ~444bhp
Old Oct 1, 2007 | 08:42 AM
go-fast's Avatar
go-fast
kinsler
Old Oct 1, 2007 | 08:51 AM
Quamen's Avatar
Quamen
Kinsler=$$$
We use one on our Porsche 928 to control the 95psi system pressure!
Old Oct 1, 2007 | 10:44 AM
go-fast's Avatar
go-fast
Kinsler=$$$
sweet....ever play with hilborn?under 2k!
Old Oct 1, 2007 | 11:51 AM
QuadCam's Avatar
QuadCam
check to make sure your fuel pressure gauge isn;t grounding outon something. I had that happen on my old gauge. When I would accelerate hard, the engine would rock over and the end of the fuel pressure sensor would ground out on the chassis. the result was that it would give me a false pressure reading. My gauge would show the fuel pressure skyrocketing upwards of 90 psi.
now, the lean isssue; I don't know what that is. could be a pump issue, or a tuning issue. Firstly, figure out your fuel pressure issue.
EnjukuRacing
Sep 30, 2015 06:55 AM
