APS Oil Pan Plug Thread Stripped!
Old Feb 29, 2008 | 02:12 PM
  #41
Abishop's Avatar
Abishop
will you still be able to thread it in with the lever and stuff attached?
Old Feb 29, 2008 | 02:15 PM
  #42
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
only one way to find out...and if not, its certainly no big deal to grind the surrounding fins easily, since aluminum won't put up much of a fight
Old Feb 29, 2008 | 04:22 PM
  #43
anotheraznguy's Avatar
anotheraznguy
hey adam, you should start carrying these as well for the lazy people
Old Feb 29, 2008 | 08:37 PM
  #44
Abishop's Avatar
Abishop
yea, i know what ya mean, taking that pan off is such a ***** i cracked off a fin in the process!
Old Jan 9, 2009 | 01:11 PM
  #45
ian350zdon's Avatar
ian350zdon
mine is striped and I try unbolting it but all it does is spin spin spin but wont come off. Im leaking oil cause of this!!
Old Jan 9, 2009 | 01:50 PM
  #46
ToastZ's Avatar
ToastZ
If you cannot get the bolt out, then drop the oil pan and take it to a machine shop. They can remove the bolt and then install a helicoil for you. You will not have this problem again with the helicoil installed.
Old Jan 9, 2009 | 02:01 PM
  #47
RED RIDER's Avatar
RED RIDER
Thanks for the info guys..I've had a fumoto on my 1 ton dually for over 250K miles..never had an issue and never has it ever opened on its own..thanks for posting the pics with the part number! I just ordered one for my Z with the aps pan...
Old Jan 9, 2009 | 02:33 PM
  #48
Jay'Z's Avatar
Jay'Z
I hope I don't have this problem........
Old Jan 9, 2009 | 02:47 PM
  #49
ian350zdon's Avatar
ian350zdon
dont think helicoil will do good for my aps oil pan mine sits rather too low
Old Jan 9, 2009 | 11:52 PM
  #50
acg's Avatar
acg
I did the exact same thing, the bolt would not come out so we took the oil pan off and did it that way, we then put a helicoil in and it has been good ever since.
Old Jan 9, 2009 | 11:54 PM
  #51
ian350zdon's Avatar
ian350zdon
hmm i guess im buying a helicoil thanks acg
Old Jan 10, 2009 | 08:44 AM
  #52
coachk's Avatar
coachk
ian...I have the Fumoto on my APS pan with no issues.Here's a pic
Old Jan 10, 2009 | 09:08 AM
  #53
ian350zdon's Avatar
ian350zdon
wow that looks great. I just bought one and a local shop is doing it for me.
Old Jan 12, 2009 | 09:30 AM
  #54
ian350zdon's Avatar
ian350zdon
update!! Just received my quick oil drain valve and it was stock thread size!! Called the company and they are sending me a 16mm thread size and give this one for free.
Old Jan 18, 2009 | 10:59 AM
  #55
RED RIDER's Avatar
RED RIDER
CRAP..I made the same mistake! I ordered the -103 and it won't fit the APS pan!! So its a 16MM thread that is the correct size for the APS????
Old Jan 18, 2009 | 11:08 AM
  #56
ian350zdon's Avatar
ian350zdon
they put in the 16mm and works fine. Wont fit directly and they had to rethread to a bigger and works perfect
Old Jan 18, 2009 | 12:58 PM
  #57
coachk's Avatar
coachk
You need the F-106 which is 14mm x 1.5 thread pitch.
The APS drain plug that comes with the APS pan is a 14mm. The OEM pan is 12mm. So long as the drain hole in the APS pan has not been stripped you can use the 14 mm Fumoto.If it is stripped, tap the hole out and go with the 16mm Fumoto
I replied back to your PM
Old Jan 18, 2009 | 01:25 PM
  #58
ian350zdon's Avatar
ian350zdon
Correct. I did the exact thing.
Old Jan 18, 2009 | 03:06 PM
  #59
RED RIDER's Avatar
RED RIDER
thanks coach! Got your PM..preciate it..
Old May 13, 2009 | 08:00 AM
  #60
BrianLG35C's Avatar
BrianLG35C
Which one did you get?
http://www.quickoildrainvalve.com/Se...10&Search.y=11
