need info on issues w/ turbo oil seals
Old Oct 18, 2007 | 10:21 AM
chris'smax's Avatar
chris'smax
Default need info on issues w/ turbo oil seals
Now that my car is nearing completion of my turbo kit (barring anymore crazy a$$ problems which i will DEFINETLY get in to later) i have started thinking about and researching typical problems that could arise from my twin turbo setup.
The one potential problem i am worried about is the blowing of the oil seals in the turbo. This problem worries me not only because it is expensive, but also as a result of my research on turbonetics and the fact that my SFR kit is using Turbonetics turbos. Now this is not intended to be a bashing session, but it seems as though alot of other car forums have had their fair share of problems w/ oil seals on the turbonetics turbos. From what i have seen most of the failures seem to occur in the ball bearing turbo units. To my knowledge the ceramic ball bearing turbos operate at a higher temperature than the typical journal bearing turbos ( due to the fact that ceramic gets very hot very quickly). With mine being non ball bearing is there less of a chance of seal failure? What measures can be taken to ensure decent life span of the turbo?
Thanks
Chris
Old Oct 18, 2007 | 01:10 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
worry about issues as they happen. it makes life a little easier...
Thanks
Chris
Old Oct 18, 2007 | 01:22 PM
VIZAGE's Avatar
VIZAGE
You can say that again. I hate to think of any problems before they happen. Most likely it will be the opposite.
Old Oct 18, 2007 | 01:26 PM
chris'smax's Avatar
chris'smax
thanks guys, but my past experiences has left me a little on edge.
Hell ask Sharif about how my luck is.
Old Oct 18, 2007 | 01:29 PM
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
Chris,
We are doing a couple things to my car right now and my ball-bearing turbos have 30K miles on them and no blowing oil and no shaft play.I was pretty stoked.I expected a little shaft play but these things are like brand new.
Old Oct 18, 2007 | 01:43 PM
chris'smax's Avatar
chris'smax
Originally Posted by TurboTim
Chris,
so do you think by using the oil scavaging pump it is helping to prolong the life of the turbos. I guess this method is superior to that of the turbonetics single turbo setup's drain back setup?
apex locator
Jul 23, 2021 02:27 AM
Dr.Paulyy
Jul 29, 2019 07:45 AM
Vigman
Nov 17, 2015 04:34 AM
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
