bogging issue under boost.
Old Oct 28, 2007 | 10:04 AM
scshay's Avatar
scshay
Default bogging issue under boost.
hey guys i have a vortec sc kit on my car just last night for the first time i have this issue now.
when i punch the car or floor it my car bogs over 4.5 rpm and it wont accelerate its weard almost like tractin come on feels the same but no lighs blinking or anything.
i can rev above 4.5 rpm if normal driveing but if i want to pick up fast this keeps happing. im wondering if it could be a traction control problem? cause i did just put differnt size tires on the rear and there a bit smaller then stock.. however this heppend even if i turn traction control off.
anyone have any ideas?
ps no check lights came on and the car seems great under normal driveing.
where should i take it do u think its a super charger problem or should i go to the dealership?
Old Oct 28, 2007 | 10:18 AM
IntenseFab's Avatar
IntenseFab
Intense Motorsports
i can rev above the normal driveing but if i want to pick up fast this keeps happing. im wondering if it could be a traction control problem? cause i did just put differnt tires on the rear and there a bit smaller then stock.. however this heppend even if i turn traction control off.
Sounds like it's too rich, do you have a wideband?
Old Oct 28, 2007 | 10:20 AM
scshay's Avatar
scshay
no no wideband.
how would it all of a sudden be to rich though?
the car has been great for 58k and i havent changed anything and now out of nowhere this.
Old Oct 28, 2007 | 10:24 AM
IntenseFab's Avatar
IntenseFab
Intense Motorsports
no no wideband.
Have you looked into mechanical issues, like boost leaks, spark plugs, maf, etc.?
Old Oct 28, 2007 | 11:34 AM
scshay's Avatar
scshay
havnet looked into anything yet just started happing last night.
wouldnt a idiot light come on if it was something like that or wouldnt it not run so good undernormal driveing either?
thanks for the help though.
Old Oct 28, 2007 | 04:25 PM
scshay's Avatar
scshay
just took the car out again there is nothing i can see wrong with the car
looks good drives fine untell i floor it could this be something with the vdc systom? or is it another problem?
Old Oct 28, 2007 | 06:05 PM
scshay's Avatar
scshay
is there anyway to tell if its to rich with out a wideband?
Old Oct 28, 2007 | 08:23 PM
350Z400rwhp's Avatar
350Z400rwhp
Are you turning your VDC off? If you turn it off and it still has the problem it should take that problem out of the picture. You really need to invest a few hundred dollars and take it somewhere to get it tuned, you could be running way rich or way lean who knows. Of course this isn't going to be a noticable issue under normal driving when the pressures in your engine are much less. Now that you have a $6000+ supercharger yes you should invest $250 in a AEM Air/Fuel gauge! A boost gauge wouldn't hurt either. This could also be a simple as something hooked up wrong or left unplugged, that's always the fun part of doing something that major to your car
Old Oct 28, 2007 | 08:26 PM
350Z400rwhp
Usually if it is running way too rich there will be fuel on your rear bumper after driving it around for awhile. But a gauge is the only way to really tell.
Old Oct 28, 2007 | 09:54 PM
scshay's Avatar
scshay
thanks alot.
i have had the car tuned though it has been done befor would it all of a sudden just start runing rich from weather change? or something its been runing great for a cupple years now and i havent changed anything so i dont think i could have messed with the tune.
thanks for the hints though ill check some of that out however i dont think its rich cause the exhaust smells fine and there is no black stuff on the exhaust or bumper.
Old Oct 29, 2007 | 05:37 AM
jpc350z's Avatar
jpc350z
thanks alot.
Look for a boost leak ..
Old Oct 29, 2007 | 06:18 AM
JMS71585's Avatar
JMS71585
Could your belt be slipping on the supercharger? Maybe the belt is loose and needs to be tightened, therefore your car "bogs" under hard acceleration? I did extensive research on Vortech's S/C because i was once interested in getting one and read about belt slippage. Maybe check your S/C belts...
Old Oct 29, 2007 | 08:54 AM
zzz's Avatar
zzz
I had this exact problem. I changed the spark plugs and that didn't help. I tightened the belt and it was still there. It went away one day after I went to autozone and had them check for codes because I thought I didn't tighten the gas cap enough. They found a different code. Can't remember what it was but I had them reset it and now the car is running fine again. I haven't gotten a check engine light since. So I would suggest having your codes checked just in case.
Old Oct 29, 2007 | 10:43 AM
hr2burn's Avatar
hr2burn
Are you using a UTEC for engine management? Sounds alot like issues I have...
Old Oct 29, 2007 | 12:39 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Just to clarify, you have been running with this SC for about 58k miles.
Old Oct 29, 2007 | 01:45 PM
moog's Avatar
moog
What is your exact setup? supporting mods? engine management?
Does it happen in every gear?
Old Oct 29, 2007 | 02:33 PM
scshay's Avatar
scshay
no i dont have a utec
i have the ss box that came with the vortec supercharger kit
as far as mods i have headers and the 9lb pully and 1 degree coller spark plugs and a exhaust that it for mods
as far as how long i have hasd the sc on the car its been about 40000kms (25000 miles.)
Old Oct 29, 2007 | 02:34 PM
scshay's Avatar
scshay
i did ceckc the belst seemed to be fine
however it did just start after i go gas from a full sever station so mabey my caps not on right.
Old Oct 29, 2007 | 03:02 PM
DVFlyer's Avatar
DVFlyer
Speed of White
My dad had a similar thing with the Vortech on his Firebird. It was a slipping belt. He described it more like the car was shutting off, than a bog, though.
Old Oct 29, 2007 | 04:09 PM
scshay's Avatar
scshay
well its weard its not like the car is shuting off it just loss of power wont go anywhere
so i hope its just the belt.
