UTEC Vortech Map Needed
Old Nov 2, 2007 | 07:06 AM
eez's Avatar
eez
Default UTEC Vortech Map Needed
Does anybody have a UTEC map for a Vortech they are willing to share with me? I want to get the map on there and make sure I'm not running way lean anymore with all of the recent changes I have made (Walbro, UTEC and 440 injectors). Once I verify it's not running lean anymore it's going to SGP for tuning.
Old Nov 2, 2007 | 07:41 AM
Biochem7's Avatar
Biochem7
Regular
Contact Mark at SGP, he'll send you a base map.
Old Nov 2, 2007 | 12:04 PM
eez's Avatar
eez
I'm trying, but I think he is pretty busy today. I want to do some AFR logging this weekend.
Old Nov 2, 2007 | 12:30 PM
eez's Avatar
eez
anybody think the turbonetics base map from the turboxs site would work?
Old Nov 2, 2007 | 01:16 PM
Biochem7's Avatar
Biochem7
Regular
sure, my base map from Jeremy at PF was a turbonetics map adjusted for 650 cc injectors. Keep your RPMS under 3,000, your never in boost and shouldn't have any problems
Old Nov 2, 2007 | 03:18 PM
Floridaboy1605's Avatar
Floridaboy1605
You can run your stock ecu just dont make boost!!!!!! keep the revs low
Old Nov 4, 2007 | 04:41 AM
eez's Avatar
eez
Lady Jax, the map works good I am seeing 12-12.5 in the upper RPMs @ 7psi, which is much better than I was before. I figure I'm running a little lean with your map because my injectors are 100cc's smaller. Now I feel comfortable brining it in for a tune.
Thanks again for your help!!!
Old Nov 4, 2007 | 09:56 AM
harogts's Avatar
harogts
did you ever do anything about the fuel regulator in the tank, or your just running it stock with the 255 fuel pump.
Old Nov 4, 2007 | 10:11 AM
xav_350z's Avatar
xav_350z
guys i also need a base map for my vortech setup
(wallbro 255, 2.87 pulley, 650 cc)
10x!
Old Nov 4, 2007 | 02:33 PM
eez's Avatar
eez
nope, I didn't make any modifications to the fuel pump regulator.
Old Nov 4, 2007 | 07:09 PM
harogts's Avatar
harogts
ok, cool thats good to know. yeah im going to end up ditching the unichip and fmu. to much headache to get it tuned, closes shop for me is 2 hours away. i wish i would of got the tuner kit too now.
350Z_Al
Oct 29, 2020 07:44 PM
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
