ARC catch can w/ Vortech SC
Old Nov 20, 2007 | 04:59 AM
G Thizzle's Avatar
G Thizzle
Default ARC catch can w/ Vortech SC
Did a search...
How would the set up on an ARC v2 catch can on the Vortech differ from N/A...
Basically, if anyone has this set up can you please advise on how and where you ran your lines to? Thanks.
Old Nov 20, 2007 | 05:04 AM
moog's Avatar
moog
If I'm not mistaken the ARC can has 3 hoses. Two that go on the passenger side (PCV valve & intake plenum) and one that goes on the driver side (breather). The passenger side will stay the same. The driver side will go to the Vortech air filter.
*thanks for the help yesterday Andrew...really appreciate it*
Old Nov 20, 2007 | 05:15 AM
G Thizzle's Avatar
G Thizzle
So one to the PCV valve and one to my SSV...my breather on the passenger side is not connected to anything right now and is dumping into the atmosphere... would that 3rd hose just go to that?
Will... did Mark help you out? what was the outcome...
Old Nov 20, 2007 | 05:32 AM
moog's Avatar
moog
yeah I would assume you would route the drivers side hose there.
My situation now:
https://my350z.com/forum/forced-induction/316120-at-check-light-flashing-car-won-t-start.html
I did talk to Mark and he was very helpful, but we weren't really able to get anywhere with diagnosing the problem. I had to leave my car at the shop and they're going to call a few contacts at the dealership today. I also brought my service manual on CD to give them later to see if that will help them in figuring it out.
Old Nov 20, 2007 | 05:40 AM
G Thizzle's Avatar
G Thizzle
well i hope it all works out bro...
Old Nov 20, 2007 | 06:10 AM
moog's Avatar
moog
thanks man, not stressin about it...ish happens when you mod the car. Not going to let it discourage me.
Old Nov 20, 2007 | 06:34 AM
G Thizzle's Avatar
G Thizzle
cool... you still going to make it down for IFO?
Old Nov 20, 2007 | 07:41 AM
moog's Avatar
moog
Not sure at this point...depends how everything works out w/ the car. I will try though.
Old Nov 20, 2007 | 07:52 AM
MUZZY's Avatar
MUZZY
ok... didnt read all the posts but here is how it goes.
the hose from the driver side case basically sucks in air and there is almost no bypass oil that will come out of that. case one is then connected to case 2 and then case 2 is attached to the manifold so all the bypass from both driver and passenger side come out of the passenger PCV valve. so connect one end to that and the other to your manifold. you do not need to splice into your driver side or to the vortech filter, this will generally just circulate air in the case and also might have a slight boost leak.
once again you do not need to connect to the driver side, because that is the inlet were air is drawn in and the passenger side is the discharge.
Old Nov 20, 2007 | 10:04 AM
G Thizzle's Avatar
G Thizzle
thanks muzzy... you wouldnt have any pics of your set up would you?
Old Nov 20, 2007 | 11:17 AM
jpc350z's Avatar
jpc350z
Don't know about the ARC v2 catch can but if it has a top hat with holes you'll need to close them up our it'll smell purrrrty bad in the cabin...The model.
Old Nov 24, 2007 | 10:02 PM
DSport G35's Avatar
DSport G35
bump for pics! what do you do about the drivers side catch can fitting? just leave it with nothing on? no little filter or anything? just vents?
what about TT cars?
Thanks
Old Nov 24, 2007 | 10:04 PM
Nexx's Avatar
Nexx
im sure this wont help but have you read the thread about the DIY oil catch can? it costs $20 or less and it uses very little engine space, very easy to do and very effective. i installed one with my vortech and it worked out very well.
Old Nov 24, 2007 | 11:39 PM
DSport G35's Avatar
DSport G35
Yes, i've been reading every catch can thread created within the past 3 years since 5am this morning. I would give the $20 setup a try but I already have the ARC V2 and I'm in the process of trying to fix/relocate/re-route all the lines correctly so I dont keep blowing crappy oil through my intake manifold.
Old Nov 25, 2007 | 11:11 AM
Nexx's Avatar
Nexx
i hear ya man, good luck.
NH01
East Canada
22
Sep 7, 2008 07:28 PM
Biochem7
Aug 17, 2007 10:46 AM
kevinapex
Apr 17, 2006 06:53 AM
