Robert_K's JWT TT Build Thread
Old Nov 27, 2007 | 02:34 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
So running 9lbs I'll be good w/ the JWT 190lph & stock injectors?
Old Nov 27, 2007 | 02:44 AM
WA2GOOD's Avatar
WA2GOOD
Yes, for around 9psi, you should be just fine with the supplied JWT TT kit fuel system, FMU, fuel pump, and stock injectors.
Old Nov 27, 2007 | 03:08 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks.
Old Nov 27, 2007 | 07:27 AM
iStan's Avatar
iStan
ZR
Btw, there are less expensive oil coolers out there. You kinda pay alot for a name with the Stillen. I pieced mine together using Summit and a local race car parts store.
Old Nov 27, 2007 | 08:14 AM
arizzee's Avatar
arizzee
I already have a wideband. Can you post pics of you gauge set-up please?
I put the controller and display in the navi cubby but you could put the display on the dash between the center cluster and the tri meters (I plan to add a second display in that spot as its a better line of sight location).
Old Nov 27, 2007 | 09:28 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks! Gonna add that to my list;
- JWT 530BB Twin Turbo Kit
- Cosworth Intake Plenum (Pre-ordered already)
- JWT Clutch/Flywheel Combo
- Defi 60mm BF Series Gauges: Boost Gauge, Oil Temp Gauge, Defi-Link Control Unit Defi-Link Display, Defi Fuel Pressure Sensor, Water Temp Sensor &, Defi-Link Indicator II
- CF A-Piller Dual Pod Set
- TXS DTEC Map Sensor
- Perrin Boost Solenoid
- Cusco Oil Catch Can
- Stillen Oil Cooler
Old Nov 27, 2007 | 09:37 AM
Abishop's Avatar
Abishop
I say, do the injectors and fuel pump while your already installing everything else, thats just my 2 cents.
Old Nov 27, 2007 | 09:55 AM
Devil Z's Avatar
Devil Z
+1 . . . 450cc injectors will be better for over 400rwhp.
Old Nov 27, 2007 | 10:14 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
OK... Just called my shop/tuner (MAC Autosport). I read him my list and dicuss my goals/need/wants. This is what we came up with:
1. JWT 530BB Twin Turbo Kit
2. JWT Clutch/Flywheel Combo
3. RC 550cc Injectors w/ clips
4. Walbro 255lph Fuel Pump
5. Defi 60mm BF Series Gauges:
- Boost Gauge
- Fuel Prssure Gauge
- Defi-Link Control Unit
- Defi-Link Display
- Defi Oil Temp Sensor
- Defi Water Temp Sensor
- Defi Link Indicator II (maybe?)
6. CF A-Piller Dual Pod Set
7. TXS DTEC Map Sensor
8. Perrin Boost Solenoid
9. Stillen Oil Cooler
10. Cusco Oil Catch Can
Old Nov 27, 2007 | 11:15 AM
DanielW's Avatar
DanielW
me want jwt TT
Old Nov 27, 2007 | 04:59 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Get one!
Old Nov 27, 2007 | 06:10 PM
DanielW's Avatar
DanielW
one day, but for now I've gotta build the tranny cuz its going out and then i wanna build the engine before i go tt
Old Nov 27, 2007 | 06:24 PM
Cube's Avatar
Cube
Ahhh sorry to hear that Daniel Yet another ST goin TT
What's wrong with the tranny?
Oh and btw, what justification does MAC give for upping the injectors and fuel pump for your goals?
Old Nov 27, 2007 | 08:05 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Cube: Really didn't get too in depth about it. Calling Colorado from Kuwait isn't the cheapest phone call.
Old Nov 28, 2007 | 03:23 AM
DanielW's Avatar
DanielW
the tranny is starting to slip i think i went to long without a vb upgrade. it sti;ll does great on full throttle shifts but on partial throttle its mushy sometimes
Old Nov 28, 2007 | 11:34 AM
Abishop's Avatar
Abishop
your a baller, don't worry about it.
Old Nov 30, 2007 | 12:51 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Ordering the JWT Clutch & Flywheel tomorrow (Friday). As well as the following gauges;
- Defi-Link Control Unit (DF05002)
-Defi 60mm BF Series Gauges (Imperial & White)
-- Boost Gauge (DF04303)
-- Fuel Pressure Gauge (DF04303)
- Defi-Link Display (DF05101)
-- Defi Oil Temp Sensor Set (PDF00908SS)
-- Defi Water Temp Sensor Set (PDF01006SS)
- Defi-Link Indicator II (DF04303)
- Dual Pod A-Pillar
Thanks Darren & Intense!
Old Dec 4, 2007 | 05:34 AM
  #38
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Deatsch Werks owners; Did you order your injectors from Deatsch Werks direct or is there a vendor? Thanks.
Old Dec 4, 2007 | 05:44 AM
  #39
z350boy's Avatar
z350boy
As mentioned I have the TXS Tuner Wideband. What is a thermostat sandwhich adapter for the oil cooler?
Originally Posted by Ahsmo
Rather than run oil through the oil cooler all the time the thermostatically controlled sandwhich adapter opens when the oil reaches a certain point. This has many advantages...
IMO a thermostatically controlled sandwhich adapter for the oil cooler is critical. The purpose of an oil cooler is to reduce the temperature of the oil, however you don't want the oil to become too cool as this may cause the oil to lose effectiveness. That is why having a thermostatically controlled sandwhich adapter is so important. Just my 2c
Old Dec 4, 2007 | 09:58 AM
  #40
XKR's Avatar
XKR
Oh, any recommendations for a turbo timer? I had a Blitz on my old Evo 8 and like it. Is there a DIY wiring diagram for installing a turbo timer for the 350Z?
Blitz for sure. Its small and can be placed anywhere. Just hit my bardomain page....there is a picture of it there
