can you have a supercharger and twin turbo on a 350z?
Old Nov 26, 2007 | 07:27 PM
thatoneguy's Avatar
thatoneguy
Default can you have a supercharger and twin turbo on a 350z?
read topic.
Old Nov 26, 2007 | 07:31 PM
hwood's Avatar
hwood
Should my girlfriend throw some fake ******* on top of her fake *******?
Old Nov 26, 2007 | 07:33 PM
myladyz33's Avatar
myladyz33
u can put a s/c and a rear mount turbo
Old Nov 26, 2007 | 07:39 PM
rhynesimpson's Avatar
rhynesimpson
Why can no one ever give a straight up answer?
Old Nov 26, 2007 | 07:44 PM
aarantes's Avatar
aarantes
Maybe you should try it and let us know what happens
Old Nov 26, 2007 | 07:45 PM
MUZZY's Avatar
MUZZY
YES
but pointless
it will only boost as high as the highest boost
simply 14lb tt + 9lb vortech dosnt = 33lb of boost
it = 14lb of boost or even less
think about it this way.... ur air is like trafic and boost is the speed limit.
if a car going 14mph hits a car going 9mph how fast will the 2nd car go after impact? it cant go faster than 14mph.
also works oppositly if 9mph car hits a 14mph car (theory) it will only ever go 14mph or less but it be less damage on the 14mph car. like its only a 5mph colision instead of a 14mph colision basically puting less stress on the blower
Old Nov 26, 2007 | 07:48 PM
Nexx's Avatar
Nexx
Originally Posted by MUZZY
YES
but pointless
you seriously answered his question? wtf!?!?!?
MUZZY's Avatar
MUZZY
there are sequenchal TT setups like the supras and rx7's i beleive..... they work like this.....
2 turbos, one small one big one boosts like 14lb and another 24lb
the only reason for this setup is that the 14lb (14mph car) builds boost/spools faster, delivering a better power curve to the power band. basically the small turbo works in low range rpm and the bigger turbo takes over in the top end. giving it a great power band. hence bigger single turbo cars take way longer to reach their power level and spool up.
now you can do a TT setup into a vortech or something, but in superchargers generally its hard to get high amounts of boost for example there are tons of problems to even get 14lb out of a vortech, compared to turning a *** on a TT setup so your TT setup has to be less than 14lb, but the time it takes to spool up, the supercharger is already spooled..... hence why some ppl like superchargers over turbos.
In the end I would just get supercharger + nitrous, or a good TT setup
Old Nov 26, 2007 | 07:53 PM
thatoneguy's Avatar
thatoneguy
Smile superturbo
o.
Old Nov 26, 2007 | 07:54 PM
MUZZY's Avatar
MUZZY
im boered and ice today
Nexx's Avatar
Nexx
Originally Posted by thatoneguy
what if you have the supercharger spool up in low rpms, then have a modified exhaust system that turns it off then switches to the turbo at high rpms?
Old Nov 26, 2007 | 07:56 PM
MUZZY's Avatar
MUZZY
you can posibly feed a supercharger blower setup feed a STS turbo kit, but that requires $$ and the supercharger barely boosts at low rpms, ur best bet is a sequenchal TT setup or toss in some NOS to meet your power curve demands.
if you all are just fooling with me...... and come up with stupid questions im just going to move alonge
Old Nov 26, 2007 | 07:59 PM
thatoneguy's Avatar
thatoneguy
Default o.
if u had to estimate a price how much would this cost? and are they available for the 350z?
Old Nov 26, 2007 | 08:01 PM
thatoneguy's Avatar
thatoneguy
Default yeah.
were not fooling especially me. i know nothing about cars but im learning.
Old Nov 26, 2007 | 08:04 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
with the right amount of money its possible.
Get a twin srew type sc thatll mount on top of the plenum and couple it with a greddy tt kit and youll be good to go. A stillen would boost 8psi throughout the rpm band and the greddy would kick in at around 3500rpm.
tuning it and making it work will be a pita, but its possible. Set aside 30k for a project like this. Might as well build the motor, spend 10k + on parts and a ton on labor.
Old Nov 26, 2007 | 08:18 PM
Escobar's Avatar
Escobar
yeah, I don't think it will ever be cost effective. Im sure many other people have thought about it and will probably never do it.
Old Nov 26, 2007 | 08:42 PM
Barzten1's Avatar
Barzten1
Totally un related but I have some friends fabing out a twin charged 5.0 Mustang. They are hoping to run 45lbs of boost.
Old Nov 26, 2007 | 08:54 PM
Escobar's Avatar
Escobar
let us know how that goes
Old Nov 26, 2007 | 09:01 PM
joe645733's Avatar
joe645733
ahhhh hahah, ****, u made me tear hahah. that was the funniest thing.
Old Nov 26, 2007 | 09:04 PM
terrasmak's Avatar
Usually its a blown thru turbo when people set it up. Yes its possible, a tuning and plumbing nightmare.
