remove rev limiter, control fuel voltage
Old Nov 29, 2007 | 11:37 PM
doomsdaydonkey's Avatar
doomsdaydonkey
Default remove rev limiter, control fuel voltage
Hi,
Please forgive me if this has been addressed before, if so please send me the thread cause I have sifted through a load of irrelevant stuff to get to the point where I am posting this...
I have upgraded my fuel system, two walbro pumps with a custom fuel return system using 700cc injectors, problem is at low rpm's its so rich .... how does one get into the stock ecu to turn down the acceptible voltage, as soon as we try trick it into less than 0.8 it starts doing its own thing...???
the rev limiter on the stock ecu needs to be changed as well, i have installed upgraded springs and when it hits 6400 rpm or so it turns the dash into a xmas tree...
i have the following:
aps twin turbo kit
huge downpipes
unichip ---
if anyone knows anything that can assist it would be great... i need to know how to get into this stock ecu and change the settings... loads of guys talk about moving the rpm limiter... how... with a fcon or haltech the issues remain the same...
any help will be appreciated...
thanx in advance
Old Nov 30, 2007 | 12:56 AM
doomsdaydonkey
am also looking into a way of getting what i want without tapping into the standard ecu... both options r cool..
Old Nov 30, 2007 | 01:28 AM
Devil Z's Avatar
Devil Z
Better engine management?
Old Nov 30, 2007 | 03:29 AM
ARLETOS 350Z's Avatar
ARLETOS 350Z
Do you think tha upping the rev limiter to 8000rpm the oil pump will work?
Old Nov 30, 2007 | 05:00 AM
QuadCam's Avatar
QuadCam
what EMS are you running? The UTEC allows you to change the revlimiter on the regular VQ35 engine (non-revups).
Old Nov 30, 2007 | 06:58 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Yes, we and others have been over 8000rpm many times.
Old Nov 30, 2007 | 06:59 AM
Dynosty's Avatar
Dynosty
What is your base fuel pressure at idle?
Old Dec 4, 2007 | 09:41 PM
doomsdaydonkey
howzit,
my fuel system has been upgraded and I have the revup oil pump...
guys, the unichip is cool and am going to be the highest registered dyno on this forum using it... after the run in, am basically asking if anyone has any idea what can be used to get into the stock ecu...
DO U KNOW... the haltech is going to have the same issue with the rev limiter and thats a kick *** EMS....
ideas and help appreciated...
Old Dec 5, 2007 | 05:13 AM
Dynosty's Avatar
Dynosty
The Haltech Platinum would allow you increase the rev limiter as desired.
Old Dec 5, 2007 | 08:58 PM
doomsdaydonkey
hi,
my mates got the haltec and apparently the only way round that one is to increase the fuel when it cuts off, its a patch fix and am hoping i can do the same.... no direct interface into that one...
do u know if the uprev product might help in this kinda situation?
Old Dec 5, 2007 | 09:14 PM
IntenseFab's Avatar
IntenseFab
Intense Motorsports
Hi,
aps twin turbo kit
huge downpipes
unichip ---
thanx in advance
Why dont you start with trying an adjustable fuel pressure regulator? You should be able to control everything you need to and command less injector ontime if you're controlling fuel pressure.
Oh I just read you are on your stock ECU.... Are you able to control the Unichip?
Buy an Aftermarket ECU and it should solve you're issues
Old Dec 9, 2007 | 10:12 PM
doomsdaydonkey
hi,
I have a fuel regulator... the unichip handles the upgraded 700cc injectors. The issue comes when one turns the voltage down on the unichip, as soon as one goes past .8 the stock ecu comes in and says no buddy, its to low and changes it right... am looking at uprev for a solution on this right now... power performance have got 350z's with 880 whp running on the stock ecu which they tune... imagine if the market went that route in the first place...
a way round the rev limiter is also to install a cable throttle, this is only applicable if the EMS that is in the car runs the injectors seperately from the stock ecu...
pray for binary to b good to me
Old Dec 10, 2007 | 10:29 PM
mrg1981's Avatar
mrg1981
You said you would be the highest registered dyno on the forums...more details on that, please?
Old Dec 11, 2007 | 01:50 AM
doomsdaydonkey
thats unichip dyno high... would not imagine I could half the highest dyno here...
Old Dec 22, 2007 | 08:34 AM
doomsdaydonkey
hi...
the unichip is not going to help me here... det is happenin often, have had loads of issues and am looking at a haltech ... cant hold boost either ... need to try those forge things again
Old Dec 22, 2007 | 12:51 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you cannot alter the rev limiter on a stock ecu with your current setup without sending it out for a reflash
your best bet, far and away, is fitting a proper engine management system that has the features you need, and has the resolution to make the most of a forced induction setup. A unichip is not that piece
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
