Si TRIM VORTECH.
Old Jan 28, 2008 | 07:18 PM
  #221
JET MECH's Avatar
JET MECH
in a good way i am sure!
Old Jan 28, 2008 | 07:49 PM
  #222
str8dum1's Avatar
str8dum1
ya in a god way. i dont think there are very many people at all with built motors and probably almost none with the Si. you'll most likely be limited by belt slip. Hopefully, not until you see 17+psi
Old Jan 28, 2008 | 09:29 PM
  #223
Hexxum001's Avatar
Hexxum001
Yes, finally we will start seeing some numbers for the Si.
Old Jan 29, 2008 | 05:40 AM
  #224
Floridaboy1605's Avatar
Floridaboy1605
Hey guys im delayed until tomorrow because of the weather here its a little icy so im going down tomorrow!!!!! Big numbers Big numbers no whammy no whammy STOP!!!
Old Jan 29, 2008 | 05:44 AM
  #225
sentry65's Avatar
sentry65
the burninator
let us know what the temp is when you dyno. That might change your numbers a little
Old Jan 29, 2008 | 06:13 AM
  #226
Floridaboy1605
What i will do tomorrow is after we are done i will have dave at function post all the numbers up for you guys on this thread.. that cool with all you!!
Old Jan 29, 2008 | 06:17 AM
  #227
Barzten1's Avatar
Barzten1
subscribing
Old Jan 29, 2008 | 06:19 AM
  #228
jouvert00's Avatar
jouvert00
Did you upgrade the Intercooler with the build? and do you have a revup or non revup motor?
Old Jan 29, 2008 | 07:05 AM
  #229
sentry65's Avatar
sentry65
the burninator
yeah an intercooler upgrade IMO is probably a good move with the psi numbers these guys will be seeing
Old Jan 29, 2008 | 07:19 AM
  #230
jouvert00's Avatar
jouvert00
^^ Even on my stock motor i saw quite a bit more tq from 5k to redline with my I/C upgrade.
Old Jan 29, 2008 | 07:51 AM
  #231
Floridaboy1605
Im on a rev-up an a bigger i/c is my next item on a long list!!
Old Jan 29, 2008 | 08:29 AM
  #232
JET MECH's Avatar
JET MECH
please let us know what your serp pulley size is and cog pulley sizes are....this will make a big difference on numbers it will make on the dyno. i have a rev-up engine, but the non rev-up cog setup with the 2.87 pulley.
Old Jan 29, 2008 | 08:17 PM
  #233
Hexxum001's Avatar
Hexxum001
Bump for some Si trim dyno #'s!!
Old Jan 30, 2008 | 05:32 AM
  #234
Floridaboy1605
T minus 7 hours until she's on the dyno.
Old Jan 30, 2008 | 08:51 AM
  #235
jouvert00's Avatar
jouvert00
Good luck!!
Old Jan 30, 2008 | 03:08 PM
  #236
jksstar's Avatar
jksstar
hows it going? I'm looking forward to seeing your #s and what kind of boost its making.
Old Jan 30, 2008 | 04:35 PM
  #237
str8dum1's Avatar
str8dum1
He should definately be much above 15 psi.
I just logged 14.8 psi at 6450 rpms.
A little street tune also improved my A/F. Still needs some work between 5300 to 5700 rpm. I'm seeing 100% IDC (AF holds pretty steady, but "thats all shes got captain) now with 650cc injectors and some shift knock when I let off and get back on it. So I can imagine with a built motor, there might be fuel delivery issues at redline.
Attached Thumbnails Si TRIM VORTECH.-vortech-si-14.8-psi-1-30-08.jpg   Si TRIM VORTECH.-idc-with-street-tune-1-30-08.jpg   Si TRIM VORTECH.-vortech-si-log-comparison-street-tune-1-30-08.jpg
Old Jan 30, 2008 | 05:56 PM
  #238
Floridaboy1605
OK guys i just got back from a long day i made 369 on a dd at 12 psi i was only running a 2.87 and stock rev-up cogs but i will post the full story tomorrow!!!!!
PS i didnt wait for the motor to cool down after the tune or i would have alot higher number!!!
Old Jan 30, 2008 | 05:58 PM
  #239
str8dum1's Avatar
str8dum1
You have a rev-up motor? So stock cogs are 34/32 (as corrected by Jet Mech- 34/28 would be huge with a 2.87!!)
what rpm did you see 12 psi? I'm seeing 12 psi with a 2.87 and stock non-revup cogs (32/28) at 5700- 5800 rpms. Cant wait for the story !
Hopefully you'll have A/F, boost, Hp and torque charts! We love pictures!
Old Jan 30, 2008 | 06:13 PM
  #240
JET MECH's Avatar
JET MECH
stock rev up cogs are 34/32. i know because i changed mine.
