Si TRIM VORTECH.
Old Apr 24, 2008 | 12:33 PM
  #621
sentry65's Avatar
sentry65
the burninator
Originally Posted by JET MECH
yes to the first question. the cog's are closer together on the revup setup versus the non revup. i never ran the 2.87,34/28 it was the 3.12,34/28 that i ran. i think the 2.87,34/28 would be way to much boost for my stock block!!!
yeah you'd have to lower your redline with a 34/28 cog setup, but I think boost would be close to the same at that lower redline compared to reving to 6600 with the 32/28 cog setup
graphs look awesome BTW considering they were works in progress
Old Apr 24, 2008 | 11:06 PM
  #622
skaterbasist's Avatar
skaterbasist
You're 430 WHP was on the 2.87,32/28 setup, right?
Old Apr 25, 2008 | 05:12 AM
  #623
JET MECH's Avatar
JET MECH
yes that is correct!
Old Jan 30, 2009 | 10:02 AM
  #624
wenlipai's Avatar
wenlipai
hey Jet have you though about trying the 928 impeller? i'm planning to make an upgrade for my V2 SC (my setup are 2.87 34/28) and hitting 10psi at redline and making 370whp (conservative), and what do you recommend me? get a upgrade from Vortech to Si Trim 52000rpm or get te 928 impeller that has 60000 rpm? please can you recommend me? my goal is hit around 410whp
Old Jan 30, 2009 | 10:08 AM
  #625
Quamen's Avatar
Quamen
I hit 414whp on a conservative tune with my car at 10psi with the 928M impeller.
That was also at about 6500 rpms
Old Jan 30, 2009 | 10:27 AM
  #626
wenlipai's Avatar
wenlipai
WOW ! thanks, so i definitly go with 928 thanks
Old Jan 30, 2009 | 12:27 PM
  #627
str8dum1's Avatar
str8dum1
ya get that 928 and run it up to 7000 rpms. no one has done that yet.
Old Jan 30, 2009 | 12:55 PM
  #628
Quamen's Avatar
Quamen
I will be soon! My rods and pistons just got here today! Just ordered head gaskets, main studs and head studs!
Come this summer I am going to really wind the 928m impeller out and see what it can do on a dyno.
Old Jan 30, 2009 | 01:00 PM
  #629
Quamen's Avatar
Quamen
A Video of my initial testing on a stock block:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Qt8YDPGLmmQ&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Qt8YDPGLmmQ&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Feb 7, 2009 | 09:09 AM
  #630
wenlipai's Avatar
wenlipai
hey quamen how good is this one? http://www.superchargerrebuild.com/?page_id=6 ABEC-9 ceramich as it can reach to 65K i'm planning to do so
Old Feb 7, 2009 | 08:00 PM
  #631
Quamen's Avatar
Quamen
I have heard some decent things about their rebuilds and bearing kits.
Old Feb 8, 2009 | 07:46 PM
  #632
CaneZMD's Avatar
CaneZMD
So is anyone running the Si trim successfully on a non-revup vq?
I sent my Sc trim back to vortech for a rebuild and I'm considering having them change it to an Si trim. I have a non-revup and I'm installing a walbro, deatchwerks 600's and a utec.
I want to run the 3.12 pulley on the non-revup setup... anyone running this?
Old Feb 8, 2009 | 08:11 PM
  #633
str8dum1's Avatar
str8dum1
of course people are running it. it it worth 400$? i wouldnt do it again. i would swap for a T-trim or a 928 impeller that can handle 60k rpms.
Old Feb 8, 2009 | 11:22 PM
  #634
Mr_pharmD's Avatar
Mr_pharmD
I think the 928 might be cheaper compared to the T trim but I wouldnt recommend either if u running a stock block.
Old Feb 9, 2009 | 09:25 AM
  #635
Quamen's Avatar
Quamen
I don't see why you couldn't run either on a stock block. I hit 414whp on a stock block with the 928 impeller and a 3.25 pulley and a conservative tune. I was able to put down a 440whp run with more aggressive tune but I had old gas in and started to sputter up top so I stopped pursuingit.
I think when I calculated my blower speed I was at 39,000 or so. So in terms of capability, I have 20,000rpm's further to go which I will be doing on my built motor.
Old Feb 10, 2009 | 03:48 AM
  #636
CaneZMD's Avatar
CaneZMD
Well, the main poster has written pages about trying to get it to run without eating belts. Is there anyone running the Si trim without burning up belts? Are there any dyno's? How much more boost does it give over the sc trim on a non-revup motor?
My vortech is being rebuilt now and I'd like to upgrade it, but if that means burning through belts like the OP, then no thanks.
Old Feb 10, 2009 | 03:57 AM
  #637
Quamen's Avatar
Quamen
It sounds to me like someone should make a 10-rib upgrade for the rear instead of the cog belt. Then you at least wouln't have belt breakage and you would still have more traction than the six rib belt driving it will ever have.
Does anyone know the length of the cog belt?
Old Feb 10, 2009 | 04:40 AM
  #638
str8dum1's Avatar
str8dum1
my signature must not be posting....
Jet Mech was rigging a non-rev setup to fit his rev-up motor. any belt problems he was having was unique to his setup. I got maybe 1 psi more boost but 30* higher AITs and negligible HP difference (and often way less than other people's dynos)
That why I still stand with my previous post. 20/20 hindsight. Use the money and go with a T-trim upgrade.
Old Feb 10, 2009 | 07:03 AM
  #639
Mr_pharmD's Avatar
Mr_pharmD
I'm not saying u can't but I just think it's a waste of money if u are going to downgrade in the pulley size just to make a few extra whp down low and only peak around 400whp. The stock blower is well capable of making 400whp with the upgraded pulley so the cost out weighs the benefit at this pt. Also it's hard to say how long the stock non rev motor would last once u pass the 400 mark.
Workshop12
Mar 23, 2020 01:45 PM
Siqcology
Sep 18, 2019 01:45 PM
Tochigi_236
Sep 27, 2015 03:40 PM
hardkicks
Sep 20, 2015 12:28 PM
