Can you use emanage with a vortech
Old Dec 13, 2007 | 08:02 AM
turtle1678's Avatar
turtle1678
Default Can you use emanage with a vortech
Hey guys I am new to FI and I was wondering if I could use emanage with my vortech, I already have it Im just wondering if I should have it put on.
Old Dec 13, 2007 | 08:05 AM
moog's Avatar
moog
Yes you can use it.
Old Dec 13, 2007 | 08:11 AM
turtle1678's Avatar
turtle1678
why do shops say that you shouldnt use it with the vortech I thought it was good to use I have everything for it
Old Dec 13, 2007 | 08:43 AM
moog's Avatar
moog
Ask the shops why...can't really answer for them. It's a piggy back engine management system to adjust fuel and timing, which is what you would need to tune the car. Do you have the Split Second box for the Vortech? or was it a tuner kit?
Old Dec 13, 2007 | 09:57 AM
THE TECH's Avatar
THE TECH
The emanage can't control the fuel pump for the kit IIRC.
Old Dec 13, 2007 | 10:20 AM
turtle1678's Avatar
turtle1678
All I have it the Standard Timing Black box that you splice into the ECU
Old Dec 13, 2007 | 10:32 AM
THE TECH's Avatar
THE TECH
That's the Split Second box.
The standard emanage blue is a waste of money. If you have the ultimate, then feel free to put it on. If not, just keep the SS box.
Old Dec 13, 2007 | 10:33 AM
moog's Avatar
moog
The split second box should be fine for tuning the car.
Old Dec 13, 2007 | 10:58 AM
turtle1678's Avatar
turtle1678
Cool thanks guys
Do you think that I can put this kit on myself I picked it up used and got the charger rebuilt by vortech, there was nothing wrong I just wanted it cleaned up. Everything looks great and its not missing anything, is it hard to do I have a few people that can help out.
It even has the harness to tap into instead of just the ECU wires and an oil pan spacer. Everything seems like it will be easy to do because its all still connected together.
Old Dec 13, 2007 | 11:02 AM
robbycolli's Avatar
robbycolli
I run the emanage ultimate and vortech. Works great!
Old Dec 13, 2007 | 11:38 AM
moog's Avatar
moog
Is it *hard* to install depends on your level of mechanical skill. That being said...I think anyone can install it with the given directions and enough time. An extra set of hands is always good to have.
Old Dec 13, 2007 | 12:53 PM
turtle1678's Avatar
turtle1678
Sorry "Hard" isnt the term that I wanted to use, I know connecting everything will be a breeze because half of it is already done I just need to tap into my fuel lines and add my spacer, mounting the bracket and the belts my take some time, but as far as tuning I hook up the box and is that it or do I have to do something else, will it function properly. I plan on getting a tune done but will I be able to drive it right away?
Old Dec 13, 2007 | 01:16 PM
THE TECH's Avatar
THE TECH
It will depend if the box has been tuned already since you say you got it all used. I would say to be safe, no WOT runs until you get it tuned. No telling what kind of tune was on there for someone else's car.
Old Dec 13, 2007 | 01:24 PM
turtle1678's Avatar
turtle1678
What does that box control?? Im new to all this FI
But as far as install everything looks straight forward, are there any special tools that I will need, and with the FMU is there any tuning that needs to be done?
Old Dec 13, 2007 | 01:33 PM
moog's Avatar
moog
The Split Second box controls fuel, timing, and the auxiliary fuel pump.
350Z_Al
Oct 29, 2020 07:44 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
