Anyone 03-05 upgrade to a Rev-Up engine?
Old Jan 13, 2008 | 02:11 PM
rcdash's Avatar
rcdash
Originally Posted by phunk
You guys are solid in your thinking, but!! What about controlling the HR motor with the older harness and ECU. When doing a motor swap, the cleanest way is to try and keep the same harness, extend or shorten any plugs needed, etc... If the crank and cam triggers patterns are the same, the 03 ECU would never know which engine its running.... the problem is then taking control of the added stuff. I have seen some guys try and just split the throttle signal to a pair of TBs... does that really work?
Going this route has some advantages but to keep you from pulling all your hair out in the process, I would opt for a standalone ECU that can control dual throttle bodies. Not sure if the FCON can. Haltech and ProEFI units both don't control drive by wire as "standard". If you can get the aftermarket ECU to control the drive-by-wire (including dual throttle bodies), then I think this project would be quite feasible.
My understanding with the HR 2nd throttle body is that it only opens mid rpms and higher (not open all the time). I believe I read this is done to preserve low throttle driveability but permit increased flow when needed. So it's not as simple as just having each throttle body mimick the other. I could be remembering incorrectly (or be misinformed).
Old Jan 13, 2008 | 03:44 PM
Netko350Z's Avatar
Netko350Z
Originally Posted by Nexx
phunk, you've already dumped enough money into the Z as is, can you really justify another 10k to do a swap that might net you another 30whp? nope.... if you really want more power, upgrade the turbos and up the boost and get another 200whp that way. but then again you really want a daily 700+ whp car? 500+ is enough, dont get greedy.
OK que the scene from The Fast and the Furious...
He needs NOS!!!
Old Jan 27, 2008 | 12:24 PM
JS04's Avatar
JS04
^^^^bump...I wondered this as well. I got ahold of a rev up engine, i was just going build the short block and switch everything over but if I just build the whole engine and get a standalone then could I just swap the engine over?
Old Jan 27, 2008 | 12:34 PM
__jb's Avatar
__jb
Z + Rear Seat
See Hal's post above.
It looks like the answer is yes, with a Haltech.
Old Jan 27, 2008 | 03:57 PM
Voboy's Avatar
Voboy
why not try to get your hands on an exterra or pathfinder 4.0vqde?
Old Jan 28, 2008 | 05:48 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
I believe the answer is yes, with the Haltech only. The other standalones do not offer cam timing contol, and the stock ecu is not going to control exhaust cams. You would need to source the 4 connectors required (ex cam control x2, ex cam position x2) and run those wires back to the Haltech Platinum. I can provide the pins and pinout for the Haltech side.
Hal
Old Jan 28, 2008 | 01:48 PM
JS04's Avatar
JS04
^^^Ahh ok. So in a nutshell this will work but I need the 4 connectors to be put on the stock ecu and then then get the pins for the Haltech. Then plug everything up correct?
Old Jan 28, 2008 | 01:56 PM
Dynosty's Avatar
Dynosty
Close, yes. The 4 connectors will go to the motor (2 to cam pos sensors, 2 to cam control), and then wires from them will run straight to the Haltech.
Old Jan 28, 2008 | 01:59 PM
JS04's Avatar
JS04
Oh, ok. Nice.
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
