HELP, One loose harness plug, cant find location
Car is a 2006 5AT G Sedan
Plug is light blue and has a small bracket attahec near the plug and is in the upper rear of the motor. It comes off the sub harness that the knock sensor plug us on. I thought it was maybe somthing for the intake manifold but I cant find anything for it. Ive been looking for a while, very frustrated, moving on to other things for a bit. Any help is appreciated.
Did you install the aftermarket shielded knock sensor wire that a lot of us installed a few years ago ? If you did , the one hanging could be the original stock one . Does the car run ? have CEL's ?
EDIT
I see yopu have a 06 . Dont think you would have done the above
Never mind !
EDIT
Never mind !
Don't trust the colors on the diagrams. It has to be either the knock sensor, evap, or coolant temp. Those are the only single/small connectors in that area. Let us know.
It was the ks sub harness, sometimes you just gotta get comfy on a creeper and hang out until you geterdun!
Thanks to all the helpfull folks who responded!!!
Tochigi_236
Sep 27, 2015 03:40 PM
