Z going into limp mode
Old Jan 27, 2008 | 01:45 AM
lve2xlr8's Avatar
lve2xlr8
Thumbs down Z going into limp mode
Z went into limp mode in the rain tonight. There was no cell but I did the ecu reset procedure and it went away but then when I drove a couple hours later it did it again. I did some research and common problems were the throttle body and the ss box. Is there any way the rain would have caused this?
Thanks in advance
Ps I'm vortech supercharged with plenum and 3.12 pulley
Old Jan 27, 2008 | 10:35 AM
Hexxum001's Avatar
Hexxum001
I can't really say what's going on with your car but moisture got into my ignition system because of all of the rain and blew 2 of my coils. I'm Vortech SC'd too.
Old Jan 27, 2008 | 11:23 AM
Everybodywildou's Avatar
Everybodywildou
Do you have a stock hood? And my Tuner was having the same problem with my car! I'm gonna sell my SS box and get a Utec.
Old Jan 27, 2008 | 11:28 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
My car has been going into limp mode, but I belive it just my thottle body getting tierd. You can buy a redone throttle body at some nissan dealers for $150. Supercharged just bought one for his G not long ago, or ebay has them for $99. Easy fix IMO.
Luie
Old Jan 27, 2008 | 11:55 AM
Everybodywildou
Luie
Never heard about this before. Anyone else have this problem?
Old Jan 27, 2008 | 11:57 AM
eagletanggreen
Got Track!!!!!
This problem is more commen than you might think, do a search and you'll be surprised on what you'll find on this issue.
Old Jan 27, 2008 | 12:10 PM
Everybodywildou
Just did a search and I'm surprised myself. Is it normal that there is no CEL though? And is there any way to be sure its the TB?
Old Jan 27, 2008 | 03:05 PM
rcdash's Avatar
rcdash
There might not be a CEL light on, but if you don't at least read the stored codes in the ECU (before resetting it), you won't have a clue as to what caused it... Cipher is a great tool for this kind of thing.
Old Jan 27, 2008 | 05:24 PM
str8dum1's Avatar
str8dum1
hmm, when my car went into limp mode, you most definately couldnt clear it with the pedal ecu reset. i had to unplug the battery for a few hours. and even that had to be done 2x.
Consider yourself lucky, that you could reset the ecu easily and have it run.
Old Jan 27, 2008 | 05:45 PM
Hexxum001's Avatar
Hexxum001
Yeah, I have the stock hood. Your car doesn't have to be modded to have this problem. My friend's bone stock car had this problem too. Water got into his ignition system too. The car started misfiring and it was because he blew a coil.
Old Jan 27, 2008 | 06:04 PM
lve2xlr8's Avatar
lve2xlr8
well the car I'd now going into limp mode whenever I accelerate even semi-hard, I keep resetting it cuz I need to get home from la, the cell came on once but I cleared it so I coal drive I guess I'll hope for it to come on again... The only time I'll ever want it to
Old Jan 27, 2008 | 08:18 PM
str8dum1's Avatar
str8dum1
so whan you say limp mode, your car wont rev past 2k and wont go over 20 mph?
something is seriously wrong. i wouldnt just keep clearing codes and continue to drive it.
Old Jan 27, 2008 | 08:22 PM
Everybodywildou
You can go over 20mph in limp mode. You just can't rev past like 2500
Old Jan 27, 2008 | 08:29 PM
Hexxum001's Avatar
Hexxum001
That's weird that your car is going into limp mode but no CEL comes on. My CEL came on right away when my car went into limp mode. I got the P0300 code.
Old Jan 27, 2008 | 08:59 PM
Nforce1's Avatar
Nforce1
Im on my 2nd throttle body... 1 before my supercharger and just recently (2 months ago)
Old Jan 27, 2008 | 09:53 PM
Everybodywildou
Would the throttlebody's go bad if we use the coolant bypass? don't most aftermarket plenums have the coolant bypass?
Old Jan 28, 2008 | 04:56 AM
merlin3's Avatar
merlin3
you might want to check the big rubber grommet on the passenger side behind the battery. When I got my car the grommet had been pulle out and not installed properly so when it rained a ton my car would go into limp mode and would barely stay running.
Old Jan 28, 2008 | 01:22 PM
lve2xlr8's Avatar
lve2xlr8
Car is FIXED!!!! Okay so the idle was fluctuating on the car a lot even when the car wasn't in limp mode... So I decided to do all procedures on this page.... Right after I did it the car is fine again and the idle and throttle input is much smoother....
See the site below:
http://www.technosquareinc.com/350reset.htm
Old Jan 28, 2008 | 05:25 PM
eagletanggreen
Got Track!!!!!
I'am glad all is OK!
Just so you guys know I just bought a redone Throttle Body for $150 at the nissan dealer. No need to buy a new one at $450 plus.
Just a heads up for you guys that might be needing one soon.
Old Jan 28, 2008 | 06:42 PM
SpoilsofWar's Avatar
SpoilsofWar
^ Saw a brand new one on ebay today as well, it was listed for ~$250 IIRC
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
Vigman
Nov 17, 2015 04:34 AM
ddegrande21
Sep 6, 2015 11:15 AM
