usable street horsepower
Old Feb 16, 2008 | 02:57 PM
  #81
sentry65's Avatar
sentry65
the burninator
that's somewhat common R-compound knowledge though among the people that use R-compounds
Old Feb 16, 2008 | 03:21 PM
  #82
IIQuickSilverII's Avatar
IIQuickSilverII
yeah...it sounds very reasonable that anybody that knows that he is buying R compound tires, that he should know aoubt the temp.... thats why i said to jet...remember to heat them up too
  #83
IIQuickSilverII
Originally Posted by r0mey
word thank you JET
are you going with those tires too rome?
Old Feb 16, 2008 | 03:28 PM
  #84
sentry65's Avatar
sentry65
the burninator
you don't really need to heat them up though. Most of the modern dot-legal R-compounds still grip pretty well when they're not warm. They just grip a LOT more when they're hot AKA when tracked
I've never bothered to do burnouts with my R-compounds to get them warmed up. I've found that by the time my engine is warned up, the tires are pretty much good to go as well.
Old Feb 16, 2008 | 03:40 PM
  #85
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Originally Posted by Hal@IP
Why not have the best of both worlds - 450hp at lower speeds, 550 midrange, and 650 interstate?
I just finished testing wheel-speed based boost control in Haltech and it works quite well. You can run as low as wastegate for lower speeds/gears, and then ramp in as much boost as you want for higher speeds. This will be another free update, slated for next week.
Hal thats is exactly what I kinda have!
480 for DD, 560 a little fun, and the 700 race map (that I never use cuz C16 is to expensive ).
However we just re did my wastegate springs and low boost map and before I was making power to 6500rpms and then it would fall, Now I make power all the way to 7300rpms. Let me tell you that makes a big difference on how the car feels.
I have never had to use my low boost (once when I raced the Honda 954) when I am on the street messing around.
So to answer the question 500rwhp on a Dyno dynamics would be perfect for the streets.
Old Feb 16, 2008 | 03:47 PM
  #86
IIQuickSilverII
it sure helps that we live in arizona
Old Feb 16, 2008 | 03:52 PM
  #87
sentry65's Avatar
sentry65
the burninator
sure does
downside is, when it is cold outside, I think my R-compounds don't perform quite as well as normal high performance street tire. The compound is just too cold and hard to give you much grip
Old Feb 16, 2008 | 03:55 PM
  #88
IIQuickSilverII
yeah
i got no choice cuase for the power ill be putting down and what jet puts down... even if you get somethign nice like a PS2 Pzero...etc...it will jsut not get much traction
Old Feb 16, 2008 | 04:01 PM
  #89
sentry65's Avatar
sentry65
the burninator
yeah I think it's a compromise worth making here in AZ where it's only "cold" for about 2 months before going back into the 60-70's ...then eventually the 110's
Old Feb 16, 2008 | 05:00 PM
  #90
skr00ball's Avatar
skr00ball
Damn I think I need some FI...
EnjukuRacing
Sep 30, 2015 06:55 AM
Dymsi
Sep 29, 2015 11:32 AM
codek
Sep 28, 2015 03:03 AM
