What about just upgading the rods and pistons?
Old Feb 17, 2008 | 09:13 PM
thawk408's Avatar
thawk408
Originally Posted by aggietsi
I recently read that the bearings are considered the weak point of a boosted car. Any merit to this?
There is more to the bearing story. Bearings to do a good amount of abuse on turbos cars. Thats why you make sure all your clearances are in spec and your engine is assembled correctly. If this is done and proper oil/oil changes are done on the car, then you shouldnt have anything to worry about.
The weak point in these motors IS the rods. This is common knowledge. You want merit, do a search.
Old Feb 18, 2008 | 11:03 AM
350zzzgunnar's Avatar
350zzzgunnar
Do you use the same clearences as OEM?
Old Feb 18, 2008 | 11:07 AM
thawk408's Avatar
thawk408
There is a range of the OEM clearances. I use on the far side of the range to help increase oil to the bearings.
Old Feb 18, 2008 | 11:13 AM
350zzzgunnar
Ok, my buddy is helping me out with that. He's a BMW and Nissan mechanic and has build quite a lot af race BMW engines but never any VQ35's. I'm shooting for 600rwhp so looking for inputs to check up on him
edit: spelling
Old Feb 18, 2008 | 11:18 AM
aggietsi's Avatar
aggietsi
I believe you, just wanted more input on the bearing issue. The VQ wouldn't be the first Nissan engine to have the rods snap when faced with FI.
Old Feb 18, 2008 | 11:33 AM
350zzzgunnar
Old Feb 18, 2008 | 12:34 PM
coachk's Avatar
coachk
Rods are definitely the weak link and most of you know I recently found that out 500whp was the magic # for me
Old Feb 18, 2008 | 01:58 PM
iknowitsfast's Avatar
iknowitsfast
Originally Posted by diwun67
All that money and you only want 375-400whp!? A stock block can handle that no problem...
i hear ya...I'd just like to play it as safe as possible. I just keep reading/hearing horror stories about blown engines and such, id rather not be the one posting one of those stories on here. lol
Old Feb 18, 2008 | 02:03 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
thats 500 through an automatic tranny too!!
Old Feb 18, 2008 | 04:40 PM
DanielW's Avatar
DanielW
Originally Posted by redman333
+1 thats what I've been running for the last 50k.
I love posts like this
Old Feb 26, 2008 | 10:29 AM
Azreen Khan's Avatar
Azreen Khan
I have just done my internal mods - installed Forged Piston, Rods, Main & Rod bearings, Cometic Gasket. Going for FI - JWT 530BB Kits - But the big problem now i didnt upgrade the Head & main Stud @ ARP - Pls comment . THx guys
My goal Target is Running 14Psi of boost.
Old Feb 26, 2008 | 10:37 AM
aggietsi's Avatar
aggietsi
Find a post titled "Oh Crap, head lift!" and see what kind of boost he was running
Old Feb 26, 2008 | 04:03 PM
thawk408's Avatar
thawk408
If the factory headbolts are installed properly and torqued per nissan spec you should be fine. They are stronger then people give them credit for.
Old Feb 28, 2008 | 03:24 AM
Azreen Khan
Are you sure it would be fine with JWT 530bb Turbo with 14Psi of Boost?
Anyway thanx for the info. Now Im running my car engine for at least 500-700 miles after installing Forged Piston, Rods, Main & Rod bearing. Then Can go for Boost n tune.
Old Feb 28, 2008 | 04:35 AM
buckeyeZ's Avatar
buckeyeZ
you could always go with a set from ARP if youre worried about the stock ones
Old Feb 28, 2008 | 08:06 AM
thawk408's Avatar
thawk408
Nothing is for sure. People have even lifted heads using the L17 headstuds, but most didnt torque them enough. Im pushing 19psi through mine and they are holding good. The L17 from what I have heard are only marginaly better then the stock headbolts. I know Jim from JWT is confident in the stock headbolts even on 800hp applications. IMHO its all in how they are isntalled.
Old Feb 28, 2008 | 08:08 AM
buckeyeZ's Avatar
buckeyeZ
^ +1......you could have the best headbolts in the world, if theyre not installed right it doesnt mean crap
Old Mar 2, 2008 | 07:54 AM
  #38
Azreen Khan
Thx for the lovely info - *phewww*
Your are pushing the the JWT TT to 19Psi?
Which JWT TT are u using 530bb or 700bb, 850bb?
What is the Maximum boost can we go for JWT 530bb?
Does it safe for the Turbo & engine?
Old Mar 2, 2008 | 08:54 AM
  #39
Zivman's Avatar
Zivman
Why did you choose cometic for your headgaskets? HKS and now cosworth offer infinitely better gaskets in their stopper style ones. Cometic is basically OEM.
Personally, I wouldn't trust OEM head bolts. IMHO, you can probably run 14 lbs on that setup, but I wouldn't get greedy and try for any more. I am running L19 studs on HKS stopper style gaskets and I would't push them further than 16 psi.
Old Mar 2, 2008 | 09:06 AM
  #40
rcdash's Avatar
rcdash
Zivman, how did you arrive at 16 psi as a max? InjectedPerformance w/ L19 studs went much higher with no ill effects reported to date...
